Question about Motorola Mobility RAZR V3
When i hit the setup home screen button on my razor it says still loading try again later, same situation when i try to personalize the home screen, the phone is working fine but i would like to use this feature, this has been happening for 4 days now , new phone, help please
  • kristigirl19 Dec 28, 2008
    I have the same problem & my MMS isn't working either. Trying to fix it myself instead of spending usless hours on the phone with their tech but it looks like I may need to bite the bullet! criminey.
    Brigadier General:
  • 7,752 Answers
The phone's firmware needs to be reflash on teh phone to correct this issue
Posted on Oct 05, 2008
  • d3blossoms Jul 08, 2011
    and what is the process for this . . .who or what is teh phone
Dell Inspiron 530s/531s desktop, Win. Xp home...Windows stops responding at the ''Loading Personal Settings'' cannot boot in safe mode.
try to boot in "Last good known configuration settings" by restarting your pc and then press F8 before windows appear and then select the boot option i mention above. if this not work since you said that it can't boot to safe mode, your other option is to repair the windows or else reformat it. when you repair the windows you must have windows xp home edition cd installer, you load it to your cd/dvd rom and then restart your pc and press F2 or DEL button before windows appear in order to go to setup bios settings. in bios settings, you choose boot order setup and setup first priority to cd/dvd and press F10 by saving the changes and then press any key when you see the prompt so that it can boot up to windows xp home cd installer and then follow screen instruction that you arrive to windows repair option.
Mar 27, 2010 | Dell Inspiron 530 Desktop Computer
Will not load past the "DELL" loading screen when you turn it on..wtf is wrong with it?!
hmm
ok try turning the computer on soon as you see any life at all hit f8.
or it maybe Shift f8 on yours. you may have to try both. but hit f8 you will see the advance menu screen. on advance menu screen select last known good configuration.
allow the computer to boot. if it gets to desk top perform a system restore to before the problem started. if not you will need to shut down again . boot the computer again as soon as you see any life . you will need to enter setup. you can do this by turning on computer soon as you see any life hit f1 or f2 or delete. it will be 1 of those keys that will get you into setup. in setup you will look to the upper left corner you will see where it says load default settings.
click on load defult settings. agree to it by clicking yes or by typing a Y.
now you will want to save your settings and exit the bios. the save and exit will also be there with load default button. click on save and exit.
allow system to boot.
Hope this was helpful.
Nov 17, 2009 | Dell Inspiron 1525 Notebook
How do I delete all from camera
Press the "Home" button then "Playback" on the touch screen, then press "Menu/OK."Hit the "Delete" option on the touch screen. There will be three options. Press the left arrow button on the touch screen until the icon which looks like a stack of papers is highlighted. Press "Menu/OK" again. It will ask "Delete All Image?" Hit Yes. The end!
Oct 05, 2009 | Vivitar ViviCam 8025 Digital Camera
Pavilion EZ4125 will not boot past the HP boot seletion screen.
Did it give you any blue screen error. Did you try booting from the CD. Its definitely something to do with the OS. Load the CD and run the setup and try to repair the OS.
Feb 12, 2009 | HP Pavilion ze4125 Notebook
Dell laptop latitude x300 won't boot up
Your laptop hard drive is probably damaged from the fall. The reason why diagnostic test after memory fails is that it’s trying to load from the “Diagnostic Partition” which is located on your hard disk drive. You could try to remove and reseat the hard disk drive and see if that works, otherwise you’ll have to take the drive to a local computer repair shop to see if they can retrieve any data.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Microsoft Windows XP Home Edition
Motorala razor camara problems
master reset the phone..
menu/settings/initial setup/master clear/master reset/ security code 000000
Jan 03, 2008 | Motorola Mobility RAZR V3
Setting up home screen problem
If you completely power the phone off, pop out the battery for a few seconds, and then try again after powering it on, you should be able to set this up.
Dec 04, 2007 | Motorola Mobility RAZR V3
Razor phone pictures
yes take the phone into your provider and have them check it out for you.
Aug 30, 2007 | Motorola Mobility RAZR V3
Error message
i have 160 songs loaded and get about to the last 12 being loaded and it errors out on me aswell. sprint says they have an update to the music player, i just got it and it is now worse. does anyone know how the phone loads mp3's. (alpha,size?!?! exc,exc)
Mar 18, 2007 | Motorola Mobility Razor Behind-the-Head...
Motorola Mobility RAZR V3 Logo
100 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
