Question about LG Cell Phones
Text message defaults to numerical entry I want alphabetical is it changable
  • 50 Answers
Click and hold star (*) button for some seconds
Posted on Sep 29, 2008
I can't write text messages in my nokia e66 mobile, when i write a letter that i needed but it writes something garbage, how i fix it?
you might be in dictionary mode
* just try to press # sign to either you want a numeric,standard alphabet or dictionary mode.
Jun 10, 2011 | Cell Phones
1) Contacts details entry - how do you enter uk postal codes which are alpha numeric, when the zip code field only permits numerics via a pop up entry number pad, other tah entering in the city field, eg...
1. In your Input method, under Settings>Locale and Text, you probably are using Samsung Keypad.
- There is a 4th column on the numeric keypad. Press the [?#+] key until it displays the alphabet characters.
2. Unfortunately, at the moment, there are only two available display options - Firstname and Lastname.
Hope this helps.
May 06, 2011 | Samsung Galaxy Tab Tablet PC
How to undo predictive text v3
Welcome to Fixya. If you want to undo the preddictive text just follow the guide below.
1. From any text entry screen (ie. when you are writing a text message), press the top center button, the one above the directional wheel.
2. Press on Entry SetUp
3. Select the Primary Set Up or Secondary Setup by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
ITAP: it's a built-in software which predicts the word you are typing. THIS IS PREDICTIVE TEXT
TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter F press the number 3 button three times.
Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
To change from one mode to the next you can select it by pressing the top center button from a text entry screen, and Press on Entry Mode. Shortcut: you can press the # key on your phone when you are writing a message and you will see abc1 for your primary mode, 123 for numeric; @ for symbols; and abc2 for your secondary mode.
If you have questions please let me know. Thanks for using Fixya.
Apr 04, 2011 | Motorola Mobility RAZR V3
How to turn t9 off on a moto razr??
Selecting a Text Entry Mode
Multiple text entry modes make it easy for you to enter
names, numbers, and messages. The mode you select
remains active until you select another mode.
Press # in a text entry screen to select one of the
following entry modes:
Primary Your primary text entry mode .
Numeric Enter numbers only .
Symbol Enter symbols only .
Secondary Your secondary text entry mode .
Jul 13, 2010 | Motorola Mobility RAZR V3
How to change from predictive text on my razr 3i
Press # in a text entry screen to select an
entry mode
1 Your Primary text entry mode can be set to any iTAP® mode or tap mode(indicated by 1).
2 Your Secondary text entry mode can be set to None, or set to an iTAP
mode or tapmode (indicated by 2).
123 Numeric mode enters numbers only.
@ Symbol mode enters symbols only
Jul 13, 2010 | Motorola Mobility RAZR V3i Cellular Phone
I have a motorola v545 and want to turn off the predictive text help!
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None.
Text-Entry Methods:
iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it.
TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key.
TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key.
Text-Entry Modes:
Primary - You can set your Primary entry mode to any iTAP or TAP entry method.
Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode.
Numeric - Enter numbers by pressing the number keys.
Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select.
To set the text-entry mode or method:
  • From a text-entry screen, press Options.
  • Scroll to and select Entry Setup or Text Setup.
  • Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
Nov 15, 2009 | Motorola Mobility RAZR V3
Turn off predictive texting
try this:
While starting a text message, hit the menu key and see if it brings you to a text entry menu ... Select alpha, numeric, word, ... you usually can switch around while writing the message via the menu.
Jun 03, 2009 | Samsung J700 Cellular Phone
Copied Email is double spacing
Check if you have text or html formatting set as default. Outlook 2003 Service Pack 3 contains numerous formatting bug fixes. What service pack are you running?
Mar 20, 2009 | Microsoft Office Outlook 2003 for PC
First, hit the 'Message' button in the upper-left -hand corner. Select 'New Message'. Select 'New Short Msg'. An empty screen for inserting text will now be displayed. At this point press the top middle button (the one with the line on it like this -). Now the 'Message Menu' should be displayed. Scroll down to 'Entry Setup' & select it. Press the 'Change' button in the upper-right-hand corner when 'Primary Setup' is highlighted. Scroll down to 'TAP English' and select it. Now you are done. ('I TAP English is the setting for predivtive'. 'TAP English is the setting for manual').
Apr 23, 2008 | Cell Phones
Help! I feel dumb. How to set predictive text?
To Change Default Text Entry:
Settings <left soft key>
All Msg <1>
Entry Mode <5>
Chose WORD to default to Predictive Text.
Hope This Helps.
Dec 29, 2007 | LG enV VX9900 Cellular Phone
Cell Phones Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
