Question about AEG Dishwashers
AEG favorit 60860 - does the safety valve on the water inlet hose need to be set vertical or can it be set at just under horizontal.
4 Suggested Answers
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
  • 174 Answers
SOURCE: how can I reset an i30 (flood control) error?
you have to mopp up any water in the base of the machine. this can be caused by a leak . a sagging pressure pipe to the pressure switch can do it as well. you can tie it up to stop the sag. its at the front behind the plinth area.
Posted on Jul 22, 2010
BElectric
  • 1140 Answers
SOURCE: THE anti flood device has
The answer is that you don't reset the anti-flood device. The anti-flood device re-sets itself when there is no risk of a leak. I don't really understand why you emptied the salt tank . . . ?
I cannot help you any further than this as you haven't specified your brand and model of dishwasher. If you can post these, I will try try to help further - if it's a model I support.
Posted on Oct 17, 2010
  • 500 Answers
SOURCE: Hi there, Do you have a
Hi ntalbany,
The Part Number is 8996461335607.
It can be found here:
http://www.apart4u.co.uk/dishwasher-drain-hose-aeg.html
Hope it helps :-)
If you found this solution helpfull, please rate my answer.
Posted on Apr 27, 2011
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher?
It should first be checked for correct water inlet hose with safety valve. After connecting the double-walled water inlet hose, the safety valve is next to the tap. Therefore the water inlet hose is only under pressure while the water is running. If the water inlet hose starts to leak during this operation, the safety valve cuts off the running water and the draining pump in the dishwasher is switched on. If the inlet hose with safety valve working correctly than could be some of following faulties.
  • The door of the dishwasher is not closed properly.
  • Mains plug is not plugged in.
  • House fuse in defective.
  • In the case of dishwasher models with start delay
    timer: A start delay is selected.
If you look at the lower electrical diagram then you can see that all electrical components are located in a circuit inlet valve which can be also faulty.
  • ON/OFF Switch
  • Door switch
  • Program controller (Timer)
  • Pressure switch
  • Inlet valve
  • Float switch
  • Wiring between all this components
Dado
Sep 15, 2015 | AEG Dishwashers
Aeg 60870 dishwasher water not getting in. Error code.10
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Dado
Oct 04, 2014 | AEG Dishwashers
Dado
Oct 04, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Aeg favorit dishwasher not filling with water
Dado
Sep 05, 2014 | AEG Dishwashers
How to connect incoming power cable live and neutral to AEG FAVORIT 60860 dishwasher?
I think it is best to connect power cable directly to the interference filter where is normally connected.
The interference filter is connected in the terminal board parallel to the mains feed. See below pictures:
Dado
Apr 07, 2014 | AEG Dishwashers
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
My dishwasher aeg favorit 50870 not use hot water(not do hot water)
If the water isn't getting hot, then either the water inlet valve that opens the hot water is faulty or the heating element that heats the machine may be bad.
Sep 29, 2010 | AEG Dishwashers
How can I reset an i30 (flood control) error?
Jul 22, 2010 | AEG 24 in. Favorit 60830 Free-standing...
Our AEG Favorit Sensorlogic dishwasher has had no power to it
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
Mar 26, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Dishwashers Logo
124 people viewed this question
Top AEG Dishwashers Experts
paul
paul
sonic boom...
sonic boom...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
