Dell GX260 will not power on.
I have a Dell Optiplex GX260That was given to me, When i turn it on the push on/off button turns amber and the little light below it is green. I get no picture on screen, the motherboard has a light beside the power supply that is amber... I tryed the 4 lights on the back thing and i odnt know if im doing it right or not, but nothing lights up. What i am doing is just pressing the on/off button and looking for the lights but nthing happens. The fan is turning on. The boy that had it before me took the processer out but he put it back in... Please help.....
  • Computers & ... Master
  • 16,806 Answers
Here is the service manual:
Note that there is no mention of the diagnostic lights. The big issue here is the removal of the processor. It is not a good idea to remove it unless the person really knows what they are doing. A lot can go wrong. If I were you, I would check the processor to make sure that there are no bent pins and it is inserted correctly. The grease they use on those to transfer heat is important. If it is not put back on or is not correct, then the processor can overheat. Another basic thing you can try is remove all the things attached to it, take out the ram etc. Leave the monitor connected though and see if it boots up with nothing attached, including the drives. If it does then you start putting things back one at a time to see if you can isolate what the problem device is.
Posted on Apr 29, 2017
  • 3940 Answers
SOURCE: An old Dell Optiplex gx260 just won't turn on
Possible failures are:
  1. Powersupply failure
  2. Motherboard failure (Check the capacitors for popped ones)
  3. Front I/O Panel
Posted on Sep 01, 2008
  • 395 Answers
SOURCE: Workstation POST
POST measn power on self test. It happens as soon as you switch the system on and the CPU runs the BIOS POST code. During POST the screen is initialised and then you may see some text and messages. Before the screen is initialised, the speaker may beep with error codes to tell you that something is wrong. e.g. two long - one short beep. Different sounds  means different things.
Do you have a specific problem?
Posted on Nov 13, 2008
  • 102 Answers
SOURCE: where can i find a free download of audio device for dell optiplex gx260?
go to dell .com and lok for your computer and the drivers
Posted on May 01, 2009
  • 331 Answers
SOURCE: dell optiplex gx260 NEEDS A PASSWORD TO BOOT HELP :'(
can you get into the bios at all
Posted on Aug 05, 2009
  • 1851 Answers
SOURCE: Need recovery CD for Dell OptiPlex GX260
Here you go - not free but you know it will work with no Trojan or virus.
Posted on Mar 30, 2010
Hello! I have a dell optiplex gx260 pc i am having a problem that my pc does not boot it does not show any screen nor any beep its backlight light orders are A OFF B Yellow C OFF D OFF i have...
If the power LED is flashing amber, there may be an issue with the power supply, if it is solid amber then the motherboard itself (or if it has an expansion card in a slot, maybe the card)
Jun 08, 2011 | Dell OptiPlex GX260 PC Desktop
My dell gx 260 is not booting .no disply.the diagnose light b is amber what is solution .
Try to remove the battery, hold on power button for about 50-60seconds, then plug-in the charger and turn the laptop ON, see what happens
If it started, unplug the charger, plug-in the battery, and start the laptop again.
Please tell us your results
Good Luck
May 15, 2011 | Dell OptiPlex GX260 PC Desktop
Start button flashing
It depends on the color, if it's green or amber. This may indicate the computer is in sleep mode. Press the power button to see if you can turn on the pc. If it doesn't press and hold power button for five seconds. You may give more details. I hope this helps
Mar 10, 2011 | Dell OptiPlex GX260 PC Desktop
Optiplex GX 260, the computer is turnibg on but
Is the power LED flashing Amber or Solid Amber? What do the diagnostic LED s on the back of the chassis indicate?
Jun 13, 2009 | Dell OptiPlex GX260 PC Desktop
Power light not turning green just amber.not a power flactuation problem
There are a few things you will have to do. First, remove any newly installed card in the PCI socket if any. Try to re-sit the memory chip modules, that's removing and re-installing them. If they are two, try replacing one after another. Thirdly, try another VGA card incase you using the onboard one. Finally, swap your monitor. It must work. Good luck
May 26, 2009 | Dell OptiPlex GX260 PC Desktop
Computer boots up when plugged in,monitor powers down
hi there.......
it is the memory it has to be matched with the actual fsb of the cpu if its slower then it wont switch on.....
and some dell pc's wont work with 1gb sticks so accertain which ram is compatible with the motherboard
Feb 24, 2009 | Dell OptiPlex GX260 PC Desktop
Dell Optiplex Power-on Problem
An Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc...
Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 18, 2009 | Dell OptiPlex GX260 PC Desktop
Yello power light, dell
1st remove all PCI cards, see if anything changes.  If no change\:
If the power LED is solid AMBER, replace the motherboard
If Flashing AMber, replace the power supply
Sep 08, 2008 | Dell OptiPlex GX260 PC Desktop
  3. Front I/O Panel
Sep 01, 2008 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
