Question about Acer Aspire 4520-5582 Notebook
Acer aspire 4520 just won't turn on
It was working fine then it just cut off ,thought it was unplugged it wasn't then when removed the battery and put it back in as you have to do sometimes and rechecked the cord it still didn't come on and won't come on. I hear a clicking noise but no power goes to the machine no light no anything. I have had for about 9 months doesn't seem that it would be the battery.
  • 2 more comments
  • sam_fixya Nov 04, 2008
    I have the very same problem.My acer's about a year old.When you try turning it on the light flicks for a second & you hear a strange clicking sound.My friend who has the same notebook also had the same problem. It seems to be a common problem in this series.
  • Anonymous Nov 07, 2008
    I
    try to turn on my NOTEBOOK and nothing happens. I try and I try. until
    it ignites. it is very difficult. every time I took over in the
    ignition. I can not be done.
  • Anonymous Feb 14, 2009
    I have the same problem any one got there's fix yet?
  • Anonymous May 25, 2009
    Same problem. Tried new battery, new power cord. Wont even say its plugged in
I have the same problem after 3 months of using it, sent it to acer, they replaced mother board and poof 9 months later, doing it again, cant get any one on the phone from acer
Posted on Feb 27, 2010
  • call4insuran Feb 27, 2010
    tried new power cord, new battery still lights flicker and thats it
You should have 12 months guarantee when you bought the laptop so i'd take it back to the shop you purchased it from. Otherwise if it is the battery then you can buy a cheap replacement on ebay.
Posted on Sep 29, 2008
2 Suggested Answers
dleemacc
  • 281 Answers
SOURCE: my acer aspire one notebook won't take a
Hi there, I tried this and when all is said and done I now have a paper weight.This is one for the pros.First thing you need to keep track of all the screws because there are different lengths and different diameters and if you put a long one in the wrong place you can fry the motherboard.What happened when I opened the case it was like opening a book except there was a 1/4 inch connector ribbon that only let me open the case 1/2 an inch.I broke the connector and the end of the ribbon.Never did find parts that fit.You can buy the ribbon in bulk but I only needed 12 inches.( I would buy a dead laptop for parts) but for me I won't try this again.Everything is so cramped and easy to break Its really hard not to break something.A shop will charge any were from $100.00 to $150.00.By the way this is a pretty common problem with this Notebook.Do you know how to solder? Because to fix this that's what you need to do, to fix this,there is a small part on the edge of the motherboard that will need to be replaced. http://www.youtube.com/watch?v=8sdbv3tdttk http://www.youtube.com/watch?v=5p7YkhvcLaE&feature=related This is part 2 and is at the link above.Thank You for choosing FixYa.........Darryel
Posted on Aug 22, 2011
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Oct 24, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
My Acer aspire 4520 windows vista laptop is locked. can someone helph me? to change my user name and password. I forgot my password.
Hi there, this may work, try this.
Take off laptop battery, remove power cord, turn laptop upside down.
Just take off screws on the covers you see, which let you see HDD, Memory,Wireless card,.... ,
take off the cover or check on line for service manual for your specific model on how to remove the plastic cover/ covers, which is covering the CMOS battery which is some time wrapped up with yellow tape. Just remove the battery by holding on the white connector which attached to the motherboard with black and red wires. Gently pull from the motherboard.
Now without the CMOS battery, connect power cord and turn on the laptop, it should turn on. Now turn off , remove the power cord, check voltage on battery , it should measure very close to 3volt (2.5 to 3.0 volt), otherwise get a new one, connect the battery, put back covers, and now you set a new password.
Aug 25, 2011 | Acer Aspire 4520-5582 Notebook
Why my acer aspire 4520 suddenly cant be switch on after a power cut of and my laptop shut down immediately?
this is happening cause it wasnt turn off proper and it is stuvk in a loop ..try to get all power off including battery .put it back and power it ..if it does the same you will have to open it and remove the ram memory and the bios battery and put them back and will work ..
Jun 02, 2010 | Acer Aspire 4520-5582 Notebook
I have an Acer Aspire 4520 and the batter will not stay charged and it keeps shutting down even though I have it plugged in. Please help.
Hi there, please perform power drain first. Take out the battery and unplug the power adapter. Press and hold the power button for 30secs. Put the battery back in, plug in the power adapater then turn on the computer. If same issue will occur then you need to replace your battery.
May 16, 2010 | Computers & Internet
Acer aspire 4520 does not power up despite fully charged battery and wall adapter turned on. power light blinks for a moment and all other indicators turn on and immediately go off. What could be the...
Remove ur battery & clean it with water and put it in to ur laptop then press 5 minutes ur power button Then ur laptop get started .
Note : Wash ur battery with clean water .
Mar 26, 2010 | Acer Aspire 4520 Notebook PC
My acer aspire won't power up
Try to connect your PC with the battery on the power outlet if it lights and charge normally. If the lights still orange, try to open the hard disk case and pull it out then try to put it in place again. If still doesn't go, try the memory card and clean it.
But I suspect that the battery has been overly charged. Try to look for another battery of the same model if it works with another and new battery.
Thanks
Nov 27, 2009 | Acer Aspire 4520-5582 Notebook
Acer 4520 woun't turn on
More than likely it's the motherboard.
You can try resetting the bios by unplugging the cmos battery and the main battery for 5 minutes.
But it's a long shot.
Jun 19, 2009 | Acer Aspire 4520-5582 Notebook
I have an acer aspire 4520. it will not come on.
Well I don't know if this will work for you or not but I got an acer 4720-4538 and when mine won't come on I take the battery out for a second and it it works. Comes right on for me.
Apr 26, 2009 | Acer Aspire 4720 Notebook
Acer aspire 4520 webcam
This is not your fault, if their sound and their video is messed up then it is either the audio quality or it is because of their camera/audio setup. Hope I Helped!
Jan 28, 2009 | Acer Aspire 4520-5582 Notebook
Acer Aspire 4520 display off suddenly without warning
please clarify this sequence of events: "on AC power,it seems to be working fine. But the problem occurs when I try restart it on the next morning"... was it restarted next morning on AC power or battery...which one?
Aug 26, 2007 | Acer Aspire 5100-5033 Notebook
Acer Aspire 4520-5582 Notebook Logo
1,955 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
