Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printer problem When you power on goes through all the normals.. but the scanner will go all the to right side and knocks oj right side of printer, and will not go to left at all!! I had to power on and un plg about 30 times to get the scaner to the left side, then When I turned on, went slowly to right and started knocking again....But not getting any errors. when try and print/ says busy.???????. I have followed the solution given by sillygirl but the problem still there, pls help.
My scanner will not move at all when powered up
Posted on Sep 29, 2008
HP Officejet J4550 All In One Reset Button
Hp printer/scanner J4550
1 day my parents did not power off my printer, they simply unplugged it so they can plug it into another room that had a phone jack so that they could fax something to the bank. ( too lazy to get a extra phone cable or just drive to the bank.. ) well anyways , they moved it, and plugged the power cable in.. as soon as they hit the power button, it went... CLICK CLICK CLICK CLICK CLICK... for about 1 minute.
it would let them auto print a blank sheet of paper.
but it would not let them access the fax or scan options.
the printer said read the manual ect...
its an old printer.. no manual...
But.. what i noticed is that.. this click noise was not really printer related. what it was ... was actually the scanner !
If you open the scanner door ( the top part of the printer)
you will notice that on the right side.. when you hear the clicking
its actually the scanners light wheel machine bounceing back n forth on the right side. about 1 minute after you open the door, then the light turns off and the scanner lazer wheel thing moves to the left. I noticed that on the right side.. there was some white plastic dust... you will notice how there is a line going across that kind of looks like a coat zipper with the plastic tringle's / line .
well 1 of the triangle's broke... so its like a broken coat zipper.. and the printer can't get the scanner lazer thing to the right side of the printer, so it kind of gets stuck... so basically... you need a new printer :( or if you are a plastic specialist.. or can find some type of plastic replacement, you would be able to melt some plastic or glue something idk..
well anyways, i just wanted to share my store.
the clicking on my printer came from the scanner lazer light not being able to reach the right side of the printer box b/c of a missing tringle plastic thing on a plastic line.
like i said, you could try to re-melt some plastic their, but it wouldn't last all that long... metal would work, just has to stay in the shape of the other small triangles.
( best option is to just buy a new printer )
you can get them for like 40 to 50 $ at wal-mart and they normally even come with ink...
Jun 04, 2012 | HP OfficeJet 6110 All-In-One InkJet...
My HP 2350x all-in-one printer won't scan. I get ''scanner failure'' when I try to scan. Scanner clicks and shuts off at end of scan. What's the fix?
Hai
I request you to remove the power cord of the printer and remove the ink cartridges from the printer and clean the contacts of the ink cartridges.
Then power off the printer and wait for 5 minutes and then reinstall the ink cartridges and then the power cord else please refer the weblink provided below on scanner failure patch.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-32845-1&cc=us&lc=en&dlc=en&product=422002
Jan 02, 2010 | HP PSC Photosmart 2355 All-in-One Printer
Getting printheads to left side of printer to
Press and hold the resume button - the one on the right hand side
Sep 24, 2009 | HP OfficeJet Pro K8600 Printer
Scanner
try disconnecting the printer, uninstalling the software via Add/Remove Programs[remove all HP OJ 6110 and old HP driver installs], Shutdown and restart, leave printer disconnected, then try installing the software again but wait for the installation software when to tell you to connect the printer.
Try this link if you do not have the software handy,
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-001&h_query=oj+6110&submit.x=0&submit.y=0
Check the label on the back/bottom of the printer for the exact sub-model to match with correct driver.
Oct 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner Knocking against Right side!!!NO Errors
Make sure that the printer is plugged directly into the wall outlet and not into a power strip / surge protector. A change in expected voltage can produce very bizarre behavior. Once plugged into the wall, if you are still experiencing the problem, I suggest an on-line chat with HP. It's free.
Aug 05, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark x75 printer/scanner
This printer/scanner, hooks up to the computer via USB. The USB cable goes into the back of the printer on the right hand side (opposite side from the power supply). The status blinking could indicate either; 1. No paper 2. No or very little, ink.
May 25, 2008 | Lexmark X75 MF All-In-One InkJet Printer
HP OJ 7410 Allin1 not printing
try removing the printer, and re adding it. Sometimes when printer drivers go kaput, they don't drop cleanly. Also, check your power arrangement, as printer drivers are notoriously suspect to power glitches, just like modems.
Got backup?
Feb 07, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Having trouble when i turn on my printer
I understand that you are receiving Scanner failure error.
Please follow the below given instructions to get the issue resolved.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Let us power cycle your All-in-one to remove any static electricity in your All-in-one.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Please try installing the below patch and check for the result:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14037-3&lc=en&cc=us&dlc=en&product=90809&os=228&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter
If the issue persists, try resetting the All-in-one to factory defaults by following the below given instructions:
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Cancel and the Right Arrow while plugging in the power cord.
Continue holding until it displays S Full Reset message in the front panel of the All-in-One.
This should resolve the issue.
Regards,
Lawrence
Jan 28, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
