Question about Canon PIXMA MP160 All-In-One InkJet Printer
Printing is grey - too pale - Canon PIXMA MP160 All-In-One InkJet Printer
  • 1 more comment
  • jrs4217 Sep 29, 2008
    The black cartridge is full. Setting to +4 makes no difference.
  • jrs4217 Oct 04, 2008
    How do i check that i have not selected "economy print"?
    I am getting faint copies with clean machine and full tank.
  • 1,800 Answers
Clean the printer head and the cartridge nozzles then run the alignemet software if this not help the cardridge is faulty this sometimes happend when the cartridge are exposed to humidity.
best regards
plz do aret this post
Posted on Oct 04, 2008
  • Canon Master
  • 6,487 Answers
Do a printhead alignment/cleaning and that should correct this problem...
Hope that helps........
Posted on Sep 29, 2008
    President:
  • 2,712 Answers
Check the printer properties and make sure you have not selected "economy" print.
  • Swilin Sampson
    Swilin Sampson Oct 05, 2008
    The most important thing is DO NOT USE GENERIC OR REFILLED CARTRIDGES. USE ONLY GENUINE INKS. Using non-original inks will only cause damage to your printer and more headaches in the long run. These days printers come with certain sensors to determine if the ink is original or not..Also ensure that you have properly installed the cartridge in the correct slot.
    Open the printer properties. Depending on your make and model, the properties can differ. Usually in Canon, the following is the procedure:
    1. Open any document.
    2. Click on File > Print. This will bring up the printer properties box.
    3. At the top right corner, next to your printers name, click on the "properties" box.
    4. On the next window, towards the middle, you will find "Print Quality". Make sure it is not set to fast or economy (depending on your model). Set it to either Standard or Normal.
    5. If you are printing only B&W documents, you could try Grayscale printing. Check the grayscale box and see it this helps in any way.
    6. Try a deep clean from the "maintenance" tab in the printer properties.
    Should all this fail, you will most likely have to change the printhead. This will require servicing.
    Hope that helps!
    Please don’t forget to rate or "Accept" the solution if it
    helped you in any way, or leads you to a fix.
    Thank you for using FixYa!
    IrishDruid
    Genius:
  • 1,269 Answers
You're running out of black color. Check the black cartridge or replace it.
  • Michael Galve
    Michael Galve Sep 29, 2008
    Go to Printer properties under Printers and Faxes and deselect the Print to Greyscale option under Color Management or Printing Preferences.
Samsung clx 3185 printing is all faded, colors and black
When you go to print, your printer driver should have quality options. Make sure you're not using "economy" or "draft" mode. Try "quality" mode.
Jan 19, 2015 | Samsung Office Equipment & Supplies
Imacwill not print word
Is there a printer installed on the iMac?
Is your account allowed to Print?
Dec 11, 2011 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
Black and white pics print out in grey pink and pale yellow?????
tour color cartridge is empty
try change it with a new one or refill it
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
May 09, 2010 | HP Officejet 5610 All-In-One InkJet...
your color cartridge is empty try refill it your self
Mar 17, 2010 | HP Officejet 5610 All-In-One InkJet...
Printing problems with epson stylus 800
you should replace the ink cartridge or you can clean it by using tape and peeling it off of where the ink comes out
Jul 21, 2009 | Epson Stylus Photo® R800 InkJet Printer
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
CLP-300; new black cartridge; prints, results are grey,
I suspect the problem is common. The Imaging unit requires a Black developer to be replaced. you may approach samsung service center for this.
Jan 01, 2009 | Samsung CLP 300 Laser Printer
CARTRIDGE IS INSTALLED PROPERLY
Clean the rollers, reinsert the ink cartridges and reset the printer. Take a test page to ensure that everything works fine .
If you still have problem remove the print head and check the base whether it is clogged with ink. Clean it and place it properly and plug back the power chord to printer and take a test page .
This will solve your problem .
Nov 24, 2008 | Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
32 people viewed this question
old marine
old marine
