Question about FarPoint Spread For Windows Forms (F02 013F) for PC
Seltext Hi I am usin farpoint spreed sheet in my appliccation . i want to select a text in a cell using selstart and sellength property . i could not set these properties . why and how to achive this ?
Farpoint tabpro 3.1.10 key
Hello
You need to buy the key at their own site or from app store.
Apr 10, 2014 | FarPoint Tab Pro 3 (TAB01) for PC
Ink level
In the Printers Folder, right click on the HP Deskjet 3845 Icon, select Properties, look for a Maintenance Tab.
May 12, 2013 | HP Deskjet 3845 InkJet Printer
Everything I print is to small to read, what can I do?
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr16
Aug 13, 2009 | HP Officejet 5610 All-In-One InkJet...
I had data on sheet one and for same the text format on another i want to copy data in the sheet having text format for particular cell reference which is there on first sheet
Try using "Paste Special". Select the data you want to copy. Position your cursor on the new sheet. Select Edit / Paste Special. Try the "Values and number formats". If that doesn't copy all the formatting you want, on the second time select "Formats". I often do this as a two step process: do a normal cut and paste, then go back and do a "Paste special" selecting "Formats" to get the formatting correct.
Jun 26, 2009 | Microsoft Excel for PC
How to shortlist combobox items at runtime ?
Each time a letter is typed by your user, re-query from the 50 and return ONLY those meeting what your user typed. Clear and re-populate the ComboBox. Also - Set the Sorted property to True!
Mar 30, 2009 | Microsoft Visual Basic 6.0 for PC
Printing problems
When you go to your Printer from Control Panel/Printers and Faxes and then right click your printer and select Preferences or Properties, you have the ability to setup the features that will be in effect system wide for all programs.
Check to see if you don't have, "Fit to One Page" selected. Or, more than One Page per Sheet.
In some software programs that retain your previous preferences in the software program itself check those settings too. Open your software, such as Word. Drop the File Menu down and choose Print and then the Properties button in the subsequent pop up. There may also be some options presented in this initial pop up interface for "Fit to One Page" or how many pages per sheet.
The only other question I would ask of you is "What is the font size you are using in your software program?"
Check all the other settings at this time to see if something was selected in error that is causing the text to print in a manner that conflicts with your document properties.
If when you are in and looking at these optoins you have a question or become confused by the options, send me a comment using the Comment Text Area below. I will receive an email alert shortly thereafter and will respond as soon as I am free and able as I may be in the middle of working with someone else, so please be patient. We are here to help you get your problem Fixed.
This problem will have nothing to do with how your printer was installed or a USB cable that runs from the printer to the PC. It has to be Program Specific or in the pinter settings.
So, if you want to solve this problem and work via our email notification process with me, I will work with you until I fully understand the nature of your setup and software so we can solve this together.
OK?
Regards,
Worldvet
Nov 11, 2008 | HP DeskJet 932c InkJet Printer
What function can make a text/string BOLD?
Try selecting a cell and right click, Format cells, Font - Bold the text the way you want it to appear in that cell and then let it be the value you want to appear when you select that cell as a solution to a "What If" statement.
I build training spread sheets that let people generate pre-programmed answers to various data entries. Answers appear like magic.
Glad to be of assistance - please rate the posting - I can learn from you.
Oct 26, 2008 | Microsoft Office 2003 Basic Edition...
Some useful but free porgrammes for Iphone
here is a list of appliccations
http://www.iphonetower.com/applications/
Mar 31, 2008 | Apple iPhone Smartphone
Excel text boxes
If you are talking about deleting the text boxes at a time that have been inserted to your cell of excel worksheet, plz follow the steps.
STEP-1
1. Open your excel sheet where the textboxes are inserted.
2. You can click one of the text box (do not click in the cell).Now press control and select the other ones with the mouse.
3. Now press the delete key and your box will be deleted.
else if you want to delete all at a time follow this.
STEP-2
1. Open your excel worksheet that contain text boxes. Now right click on the blank area of Menu bar (At top right corner area). 5e70363.jpgChoose Drawing tool bar if not selected. Now from the drawing toolbar (above the TASK BAR) choose the --> (arrow mark) at bottom left corner of the drawing bar.
c72d4bc.jpg 2. Now your mouse pointer will be changed to arrow shape. Now click on the bigining of the excel sheet and drag till the page end without releasing your mouse button. Now you will see all the text boxes will be selected.(No text will be selected, Only objects will).
466bdaf.jpg dcf40c0.jpg 3. Now press delete key and all your text boxes will be deleted at a time.
Hope it works, otherwise mail mei will give you the screen shots.
Feb 16, 2008 | Computers & Internet
Printing fuzzy / bleed text with fuser saying needs changing soon!
Hi the blurring maybe down to the machine needing a color registration. Press the menu button then press either the up or down arrow to Maintenance press enter or # the using the up down keys again select color registration enter or # then print registration sheet once printed select M Y C or B and input the number that is on the printed sheet that corresponds to the straightest line. Once you have done this exit and try printing.
If that doesn't work then within the driver on the computer under printers and faxes right hand click on the printer select properties. Within properties you will be able to change the graphic mode please try this.
The fuser unit will need changing as they only have a life span there are no benefits to resetting as you will need to change it anyway. If you do not change the fuser then it will break leaving you with a bigger problem.
I do hope the above works for you.
Thanks J
Dec 05, 2007 | Ricoh Aficio AP3800C Laser Printer
Computers & Internet Logo
74 people viewed this question
Top FarPoint Computers & Internet Experts
David Payne
David Payne
Are you a FarPoint Computer and Internet Expert? Answer questions, earn points and help others
