Hi.
This is a common problem with some Nikon models.
In this case, the D3200 normally shows this error mesage due a broken part in the shutter system or mirror box.
Check if something is blocking the in-built flash to pop up or if it is stuck.
If the flash is stuck press the flash pop-up button and try pulling it up simultaneously.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: - 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert only a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: - 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: - 1. Turn off the camera. 2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
you have a picture upside down if u turned a picture on ur computer put memory card in computer and turn picture how u took it decode error will go away
