Question about Amana Heating & Cooling
My portable air conditioner Model # AP077R, is not functioning correctly. I just opened it last night and now it is malfunctioning. Once plugged in, it will act as if it is cycling between blowing air, then stopping, and starting again. I can not turn it on or off. It runs through this cycle by itself and the only way to stop it is to turn it off. Do you have any suggestions, or is it just defective?
    Scholar:
  • 121 Answers
Yes it sounds defective from fatory and should be exchanged.
Posted on Sep 29, 2008
I have the Amana portable 3 in 1 air conditioner model #ap077r. It works fine but air only comes out of the right half of the fan vent. Is this how it is supposed to be and if not, how can I fix it?
It probably has 2 evaporator fans and one has failed. (I couldn't find your model on the Amana site, so I don't have any additional information.)
Jun 20, 2014 | Heating & Cooling
Unit-runs-for-an-half-hour-then-cuts-off
  • Website: http://www.amana.com/'
  • Support Phone: 1-866-616-2664
    or maybe check timer settings
  • Aug 05, 2012 | Amana AP077R Portable Air Conditioner
    After years of perfect operation the water reservoir tank needs to be emptied every few hours. Is is almost a gallon of water each time. The normal time was always every other day ...at most once a...
    12k BTUs will condense a gallon an hour easily, sounds like the problem is with a probable self-evaporating portion of the condenser. If so either the inner workings of that unit are dirty/malfunctioning or the exhaust duct is not getting proper airflow. If you're mechanically inclined I'd recommend pulling the unit apart and cleaning the condenser parts. If not perhaps try attaching a permanent drain hose to the drain plug. Definitely check the exhaust duct either way.
    Sep 22, 2011 | Amcor ALTL-12000E Portable Air Conditioner
    I have no cool air! Please help!
    Here is a tip about troubleshooting your air conditioner...
    There are many things that can cause your air conditioner not to cool...
    AirConditioner Trouble - Review the Possibilities
    heatman101
    Jul 23, 2011 | Amana AP077R Portable Air Conditioner
    Has water leaking out of the back of the system?? Is it suppose to have a drain hose to it??
    It has to have some way to get rid of condensation. There should be a hose fitting or nipple located on it somewhere.
    Jul 20, 2011 | Amana AP077R Portable Air Conditioner
    I'm looking for the product manual for the Amana AP077R Portable Air Conditioner?
    how to down low the instruction manuel on this product amana APO77R air conditioner
    Jul 17, 2011 | Amana AP077R Portable Air Conditioner
    Amana ap077r IS LEAKING WATER FROM THE BACK
    Find the evaporator condensate drain and check that it is routing water into the pan
    Jun 22, 2011 | Amana AP077R Portable Air Conditioner
    My AMana AP077R portable air conditioner was plugged in but turned off. Alarm went off, checked drain...no water to drain. Unplugged, plugged back in...an hour later, alarm went off again.
    Kathy, it sounds as if you are using a hose to drain the water to a floor drain.
    If that is the case, do the following after turning the unit OFF & unplugging it:
    1. Disconnect the hose from the unit and check the hose for clogs.
    2. If none are found in # 1, the clog is in the unit's hose connection and/or internal tubing.
    3. Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers, though) insert the Zip Tie carefully into the hose connection on the unit and push it in, until you reach a bend in the tubing. You must gingerly work it past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. Then slowly pull it back out while rotating (twisting) it. This will dislodge any clogs. As you reach the end of the exiting Zip Tie, be prepared for some water to follow.
    Hop this helped you to troubleshoot and solve the problem. Please let me know.Thanks.
    Jun 16, 2011 | Amana AP077R Portable Air Conditioner
    Amana ap077r one button on remote doesnt work, how can i fix, i can press all the buttons on the remote and they work except the down button. do i need a new remote or is there an easy fix to this problem.
    You can fix the problem of the failure of the contact within your remote. First of all you need to understand that there is CARBON contact underneath the pad that you press. Carefully remove the remote control, use a sharp knife to carefully open without damaging. Take the pad and the remote control PCB out of the cover. carefully using a good cloth clean the PCB and the carbon dots under the pad. if you happen to see any maiture/ sweat tugged inside, use a hair dryer to slowly heat up to remove and dry. Now identify the defective pad. You can get to buy the carbon dots but if have any old calculators/ remote that is lying arround, carefull cut off the carbon dot and using a good glue stick it to the problem pad. If your PCB tracks are intact and if the Remotecontroller IC is alright then you have rectifed the fault. Hope my advice helps.Good day
    Jul 08, 2010 | Amana AP077R Portable Air Conditioner
    Amana Portable A/C Model#AP077R Remote control worked twice and then stopped working. Replaced batteries twice but no luck. Any suggestions?
    I have a similar problem. The remote works for 5 to 10 minutes then no longer works. If I take the batteries out of the remote for 10 minutes (or longer) and reinstall them, the remote will again work for 5 to 10 minutes. I got a replacement remote from Frys and it behaved the same way.
    Jul 06, 2008 | Heating & Cooling
    Heating & Cooling Logo
    104 people viewed this question
    Top Amana Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Bill Long
    Shehu Pro
    Shehu Pro
    Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
