Question about Hyundai ImageQuest L70N 17" LCD Monitor
Hyundai imagequest l90d+
The monitor continuously powers itself on and off, and the power button doesn't work to turn it on. However, if i press two buttons, one after the other, such as power and menu, it comes on. I also can't turn it off with the power button. Any ideas?
  • 558 Answers
The small board that handles all the buttons sounds as if it has gone bad you should be able to get a replacement on ebay
Posted on Nov 13, 2008
Hyundai L90d+ has internal speakers. There is one cord connecting on the back to two positions next to each other. Using vga port for connection to computer. How to connect speakers to computer? I...
Plug the headphones/speakers into the computer. Go into Control Panel -> Sounds and Audio Devices -> Audio Tab -> Sound playback -> Select your headphones from the drop-down list. Voila headphones/speakers that work.
Sep 14, 2011 | Hyundai ImageQuest L90D 19" LCD Monitor
The power switch on my Hyundai B90A monitor won't turn the monitor on, but when I press the volume buttons or the menu button, the monitor comes on for a few seconds and then turns off again
you have got problem in the switch circuitery of your monitor.there is nothing that you can personelly do,,, you have to take it to the service centre of hyundai,,
Oct 20, 2010 | Hyundai ImageQuest B90A 19" LCD Monitor
Monitor won't turn on, light flickers amber to blue
your monitor have some hardware issue.so pls checked it from monitor expert.
Aug 25, 2009 | Hyundai ImageQuest L90D 19" LCD Monitor
Blue tint
Check the pins on the end of your vga cable from the monitor to make sure that the pins aren't bent.
If they are not bent then it could be a problem with the monitor itself. Try resetting the defaults on the monitor itself and see if the problem goes away if it does then your set.
If the problem still exists then try a different known good working monitor on the computer. If you still get the same problem then its a problem with the video card. If the problem goes away then you know its a problem with the monitor and would need to be replaced.
Jun 02, 2009 | Hyundai ImageQuest L90D 19" LCD Monitor
I need to know how to reset my monitor to factory defaults
Factory Setting & EEPROM Initialization Method
Factory Setting Method
- Connect the signal cable and power cable to the LCD monitor.
- Press Power switch with pressed MENU key.(Menu key + Power key).
- Then, a User can change the factory setting value in OSD menu.
- Save changed value and Turn off the power s/w.
- Turn on the power, adjust the screen.
Apr 15, 2009 | Hyundai ImageQuest 19 L19T LCD TFT 19" LCD...
Screen says video mode not supported
can you hook your old monitor up and change the resolution to 1280x1024? If so, you should then be able to use the L90D
Mar 23, 2009 | Hyundai ImageQuest L90D 19" LCD Monitor
Hyundai L90D+ Monitor Problem
Same problem L90D...clicking, flashing, not coming on. I just ordered a new monitor, but would love to know if this can be corrected.
Dec 17, 2008 | Hyundai ImageQuest L90D 19" LCD Monitor
Automatically turns off and on withing 2 secs
the power button board is electronically fried you need a new one
May 07, 2008 | Hyundai ImageQuest L50S 15" LCD Monitor
My Monitor
Ok? first what you need to do is to hibernate your computer. You can do that by pressing the power button as long as you need for the computer to turn off. Then you turn your computer back on and press the power button ON THE MONITOR twice but you MUST do this really fast. Then what you need to do is to find a circuit breaker on the back of your computer. switch it to the off position then turn it back on. Then turn your computer on. This should fix your problem.
Dec 31, 2007 | Hyundai ImageQuest L70N 17" LCD Monitor
Monitors goes black - Hyundai Q17
I had the same problem some time ago.
After dismateling the power-supply unit it apeared that there was en crack in a solderjoint at one of the power transistors. This transistor has 3 legs (TO220 I believe), from which the middle leg had a solder crack, probebly due to thermal stress. Just resolder and it worked again....
Its worth a try I think.
Succes,  Wim Steenhuis.
Oct 04, 2006 | Hyundai ImageQuest Q17 17" LCD Monitor
Hyundai ImageQuest L70N 17" LCD Monitor Logo
249 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
