Question about Gigabyte 7VM333M-RZ (GA-7VM333M-RZ) Motherboard
Problems with playing games
My name is Belal and I'm having problems with my motherboard playing games because of the RAM slot.First i putted a 512 MB DDR ram to one slot it was working fine then i put another 512 and then the games become stucked or the keyboard and mouse doesn't respond.maybe because of my 350W and 4A power supply or it has something to do with my AGP card.
  • AZE160 Oct 01, 2008
    how much can it run?
    both are DDR400
  • 158 Answers
There was a prblem in your ram, what is the mghz of your old ram and new ram give coniguration of your pc
Posted on Sep 29, 2008
  • syed mujahed
    syed mujahed Oct 01, 2008
    the new ram you are installed its not working please change it, it have warranty you have to send it to service center they can replace your ram
I'm finally found my system info can some tell me how much memory Im running on 512.00mb ? :(
you have a 512 mb card in the ram slot which gives you an effective ram of around 480 mb
it is random memory and is a storage space which the cpu uses to move data around while it does it's job
if you want to increase the ram then there should be a spare ram card slot next to the one you have so you can install another ram card of exactly the same value to double the ram memory
in some instances ( like game playing ) it can increase the speed of the computer
Oct 19, 2015 | Computers & Internet
I am a gamer and p5vdc-mx has only agp slot and i want 1gb vga card but it is harder to find in agp slot i find only pci express x16 cards can i use riser card to convert agp to pci e x16
Hello
I dont think there are any agp to pci ex riser cards.As pci e x16 is part of the motherboard circutry.
There are pci to agp riser cards.If your going to be playing some of the latest games.Most games in the past 3 yrs require a pci x16 vid card.
I suggest geting another motherboard,chipset,and memory.Along with a Pci e x 16 card min 512mb.
Sep 07, 2011 | ASUS P5VDC-MX Motherboard
Will 9500 GT either 512 mb or 1 gb work on intel la crosse D865GLC board..?? it has 3 pci slots 32-bit long..
Yes you can.
For 512 Mb RAM you can use a single 512 Mb memory module or two 256 Mb memory modules.
For 1 Gb RAM you can use a single 1 Gb memory module or two 512 Mb memory modules.
Apr 13, 2011 | Intel Desktop Board D865GLC (MBIND865GLC)...
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
Problems with 3 brand new PC 133 512 MB RAM in Netvista 6794
That last RAM probably is good. Many motherboards have problems using many different memory. All of the memory you have should be at least identical to ensure that they work. When RAM run at different speed or require a little more voltage, they will not let your motherboard boot. You can try mixing up the order you put the RAM in. Try putting the last RAM in the first slot by itself, the motherboard should boot. Then try the rest.
Also, whenever you add or change hardwares, you should clear the CMOS/BIOS settings.
Jan 06, 2010 | IBM (49P1599) Motherboard
I have problem about ram
If the manual says this motherboard support up to 1 GB RAM, you cannot put 2 GB. You can put 2x 512 GB RAM or 1GB RAM
Also try to upgrade your bios, maybe a better bios version supports more than 1 GB RAM.
Aug 24, 2009 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
I have installed 1 GB + 512 MB DDR II RAM, but it read only 1G I have just bought the Corsair 1GB RAM (DDR II 667 MHz, 6400), and installed it in the slot 1 of my motherboard, but it only read as 512 MB. (...
Nowadays, motherboards supports only a selected number of RAMs. You have to read the manual and select from the given models. I am not talking about DDR2 or 667MHz. The manual will state the manufacturer (ex. Kingston) model no (KVR667XXXXXX) etc. Only those stated in the manual will work correctly with your motherboard.
Aug 14, 2009 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
How can i increase my ram in intel desktop board 815
Hey,
Ram can not be increased as it is a hardware component in the computer, you can install more ram or upgrade the current ram modules that are inside the computer.
Feb 24, 2009 | Intel Motherboard
Need suggestion
there is an agp card for 512 but that is high as agp goes you will spend anywhere from $100.00 to $400.00 for the card depends on frame rate pixel pipelines stc
I like evga, msi, mid price range but good warranty
Oct 17, 2008 | Intel Motherboard
Upgrade from 512MB to 1GB
The specs on the memory are correct, so you purchased the correct type of memory for this motherboard. If your getting no video when you power on with the 1gb stick, I would be willing to bet the 1gb stick is bad. Can you return it and try another stick?
Mar 15, 2008 | ASUS P4B266 Motherboard
Gigabyte 7VM333M-RZ (GA-7VM333M-RZ) Motherboard Logo
54 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
