Epson DFX 5000+ Matrix Printer
Problem for Epson DFX 5000+ Matrix Printer
Epson DFX-5000 printer
By jessie25 - usenet poster
printer that has a paper out problem. When I load the paper on the front tractors it will feed properly and go on line. After starting the printer, it will run for about a quarter of the page and go off line. The printer will then default to the rear tractor feed. We have replaced the paper out sensor on the front tractor feed and the TOP of form sensor which has not corrected the problem.
Solution #1
posted on May 30, 2006
Not Rated)
Mini Me
Rank: Apprentice
Rating: 0%, 0 votes
Epson DFX 5000 and 8000 printers have very touchy sensors. Try the tractor select sensor aswell as the paper sensors on both tractors. The interlock switches can also cause various faults. Make sure all sensors toggle properly.
Was this helpful?
Yes
No
Solution #2
Not Rated)
lawyer
Rank: Apprentice
Rating: 0%, 0 votes
I had a very similar problem on a Canon. I am unfamiliar with that Epson model # but the Canon was an ink[bubble] jet. The problem turned out to be a bad ink cartridge believe it or not.
Was this helpful?
Yes
No
Popular Solutions for Epson DFX 5000+ Matrix Printer
Questions and Unsolved Problems for Epson DFX 5000+ Matrix Printer
Do you recommend Epson DFX 5000+ Matrix Printer?
Answer
Answer
Business inkjet acts like it is out of ink but it is not--only prints magenta. Cleaned contacts with... (More)
Answer
i wanted to pause a job and since then i cant print anything
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Epson DFX 5000+ Matrix Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
