Question about Konica Minolta DiALTA Di183F Copier
Caution 2nd side cover is open
Hi, we moved the copier on the weekend and now there is an error that the second side cover is open when it's not. It won't let me use it while it has this error. Any ideas??
  • andreawo Sep 29, 2008
    Hi Schmoody68
    Thanks heaps for your help. You've pretty much confirmed what I thought might be the issue. Thought can't clearly see it so maybe something has completely fallen off? We live about 50km from our service centre so I might take some macro photos of all the cover parts and email that to the tech to be sure before we get him to come all the way out here. Thanks again :) Andrea
  • Anonymous Jan 19, 2009
    We had a similar problem with the 2nd side cover notice displayed. We tried to find a pin that may have been missing and instead we found a small black swith inside when we pressed it the error message turned to "paper jam open second side cover"
Hi Andeawo, It sounds like while moving the copier, you may have broken or bent a door interlock switch or the door actuator that depresses that switch. On the door that showing ajar, look for a small pin (could be plastic or metal) and see if it's bent or broken. If that appears fine, slowly close the door and look for a small hole where that pin would go through and depress the interlock switch. Once located, look to see if the switch is misaligned or broken. I'm thinking that one of these 2 items is the culpret.
Been a copier tech for 12 years and have seen my share of both. Let me know what you find...
Posted on Sep 29, 2008
Unable to print 48
Clean the plastic encoder strip thoroughly
In order to access both ends please follow these steps
1. After the error message is displayed on the LCD or display, open the scanner cover, so the print head is visible.
2. Press and hold the Stop/Exit key for 5 seconds. The print head will move to the middle.
3. Unplug the power cord from the power outlet.
4. Use a clean lint free cloth dampend with a bit of alchohol and clean both sides of the encoder strip thoroughly. Move the print head from side to side to allow access for cleaning of the entire encoder strip.
Feb 25, 2014 | Brother MFC 6490CW InkJet Printer
Printer wont acknowledge ink loading
Make sure you are using genuine Lexmark cartridges. Refilled cartridges won't be able to register ink levels. If you are using original supplies, it could be just a slight cartridge communication error. Try the steps below:
  1. Make sure the printer is on. Open the printer cover.
  2. The carrier should move to its loading position. Open the latch and remove the cartridges.
  3. Close the latch.
  4. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-insert after 10 seconds.
  5. When the printer turns on, re-insert the cartridges. Close the printer cover.
  6. Check on your computer if ink level is acknowledged.
  7. Try to print a document to verify that the problem is fixed.
Dec 18, 2011 | Lexmark Z2300 InkJet Printer
Scanner error 5
Follow these steps:
1) Switch off the printer
2) Open the upper cover where the scanner is
3) Clean the white stripe, which is on top of the scanner "home"
4) Open the right side cover - it has two screws that hold it in place
5) Switch on the printer
6) On start up, put the upper cover back on the scanner
7) Then the scanner starts moving, unplug and plug back in several times the green, blue, yellow, red connector which is up on the upper left side of the metal cover
8) Then the error should go away
Good Luck
Nov 09, 2011 | HP Office Equipment & Supplies
Hi Just wonder if you could help me i have a lexmark x3480 it has suddenly decided to display cover open and is not switching off at the control panel. The cover is not open and sits flush what is it...
It could either be due to a stuck cover sensor or the cartridges in your printer. Please follow the steps below to fix the problem:
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Rebrick (pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark X3480 All-In-One Printer
My canon MX340 won't print, saying there is a printing error 5200. I tried unplugging the printer and turning it off, but it still won't work
I will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see if that fix the problem.
Jul 11, 2011 | Canon PIXMA MX340 Wireless Office...
Please help we are changing the toner on our copier machine and got an ERROR MESSAGE: used toner case is full.
the waste toner box is located beneath the front cover ( the cover that has Canon and model number ).
Open toner cover and you will see one screw wich you need to remove.
Then, on left side of toner, on top of the front cover, few milimeters from edge is second screw wich you need to unscrew. Usually is covered with white/grey cork made of rubber.
then remove cover, by pulling it in left side then towards you.
Big white box is waste toner container wich you need to clean/empty it.
Hope that helped!
Jul 26, 2010 | Canon ImageRUNNER 3235 Black and White...
Hi how do i move the cartridge motor to the left hand side of the printer, to get the cartridges out? thanks
The cartridges should come to the center when you open the cover, if not, try powering up with the cover open and when they come to the center, unplug the power. If they are not moving from the right, there is an error code that needs to be repaired first.
Sep 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Lexmark X5495,Error 1203, Says Clear Carrier Jam
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 7 Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
Apr 15, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 18, 2008 | OKI Electric Industry C3520 Laser Printer
Mfc-7220 Back Cover Open
This one made me crazy, but I finally figured it out. Turn the machine around so that you are facing the back. Open the back cover. Pull down the second smaller roller cover inside the machine. If you look closely at the second smaller cover, on the right hand side (closer the the inside of the machine), is a very thin round piece of plastic that is only half the length of the smaller cover. There are 2 thin plastic tabs attached to either end of this round piece of plastic. Gently shift this over so that the 2 plastic tabs can now go into the space provided for them. I had to move mine over only 1/4 inch.
Jan 03, 2008 | Brother MFC-7220 All-In-One Laser Printer
Konica Minolta DiALTA Di183F Copier Logo
801 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
