HP PSC 1210v All-In-One InkJet Printer
Problem for HP PSC 1210v All-In-One InkJet Printer
Wrong Printer Cartridge error
By Jbm3r2003 on Sep 29, 2008
I have verified I have the right one, I have two of these printers and both are saying the same thing.. Please help.. Is there a way to reset the printers?
Solution #1
posted on Nov 02, 2009
Not Rated)
jacobssr2000
Rank: Apprentice
Rating: 75%, 1 votes
I had the same problem and I called where I got the ink refilled. They said the ink refill was bad and had to take it back to get another one. Problem was solved
Was this helpful?
Yes
No
Solution #2
posted on Jun 23, 2009
Not Rated)
printertony
Rank: Guide
Rating: 80%, 5 votes
If you are receiving the erro messages on both the printers then its clear that the cartridge is faulty. However please perform teh following steps:
1. ‘Turn on the power’ to the unit and raise the ‘cartridge access cover’. The cartridges will move towards the ‘center’.
2. After the carriage (the cartridge holder) stops, unplug the ‘power cord’ from the back of the unit. This will keep the cartridges from moving back to the ‘capping station’.
3. Remove the cartridge(s) from the carriage.
4. Using a soft, clean, lint-free cloth or a cotton swab lightly moistened with distilled, filtered, or bottled water and gently clean the ‘face’, ‘edges’ and the ‘electrical contacts’. (Change to a clean cotton swab as needed).
CAUTION: Be careful not to touch the ink nozzles on the bottom of the print.
5. Inside the All-in-One, clean the contacts in the print carriage with a slightly dampened soft, clean, lint-free cloth. Allow the electrical contacts to dry completely.
The information provided above is also available in a graphical format at:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?&cc=us&docname=bpu01831
NOTE: Clicking the link may give an error indicating it is ‘Invalid’. If this occurs, copy the ‘first half’ of the link followed by the ‘second half’, exactly beside it, in the ‘address' field of the ‘browser’ you use.
Note: Please do not insert the cartridge before performing the steps given below.
Check if the issue is resolved. If the issue persists, please perform a power-cycle on the unit.
1. Unplug the power supply from the wall outlet.
2. Unplug the power supply from the back of the printer.
3. Wait at least 20 seconds, then plug in the supply back into the wall outlet.
4. Plug in the power supply back into the printer.
5. Press the power button to turn the printer on.
Verify the results.
Was this helpful?
Yes
No
Solution #3
posted on Jun 19, 2009
Not Rated)
Techie Roy
Rank: Wiz  HP Expert
Rating: 84%, 69 votes
Yes you can reset the printer using.
On the all-in-one front panel (this option is not available for the HP PSC 1300 series), press Setup , press 5 , and then press 3 . The all-in-one will reset to the factory defaults
Reset the all-in-one by unplugging the power cord and then plugging it back in.
If you want further support you can avail free technical support on http://tinyurl.com/m7ghqz
Was this helpful?
Yes
No
Solution #4
posted on May 18, 2009
Not Rated)
vo_bike
Rank: Wiz
Rating: 74%, 30 votes
have you tried changing the printer mother board i think that could be the problem of your printer
Was this helpful?
Yes
No
Popular Solutions for HP PSC 1210v All-In-One InkJet
Questions and Unsolved Problems for HP PSC 1210v All-In-One InkJet
Do you recommend HP PSC 1210v All-In-One InkJet Printer?
Answer
Answer
check print cartridge error despite replacing the print cartridge
Answer
I put in new ink cartridges and now I get a blinking cartridge light and the computer says the... (More)
Answer
had paper jam. unhooked power source from back of printer to remove back door, now printer will not... (More)
Answer
hp 1210v all in one printer will not scan photo. scan message says that printer won't communicate... (More)
Answer
i just bought a new ink cartridge and it keeps saying check printer cartridge
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP PSC 1210v All-In-One InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
