Question about Philips Magnavox 15MF400T 15 in. LCD Television
DELL LCD SCREEN DARK SHADOW
From the center towards to the right the screen losses brightness progressively. Left side is good.
Any one knows how to deal with this?
  • 2 more comments
  • Anonymous Oct 14, 2008
    I have similar issues with my screen, the right side gets darker from the center of screen... left side is good... its annoying and don't have warantee. This laptop costed me around $2700 and is been nothing but POS...
  • Camilo Rojas Nov 09, 2008
    I will check the tft backlights for sure... thing is.. how do i know if these are broken or burnt???? i am going to venture on opening my computers screen. i hope i dont break it.
    could you advise me on how to check if they are broken?
    thanks
  • Camilo Rojas Nov 10, 2008
    thank you and i will try to change check the lamps soon. i will post the results of my trial here. thanks
  • Camilo Rojas Nov 14, 2008
    it is a dell, right. so i tried to look for the lamps and i removed like three different frames that held the screen until i got to the last two screws... which were of the size of a 2 mm dot... i could not find a screwdriver with such a small head... ... that was just an update.. BUT this weekend i am getting a set of scredrivers for small screws so ill let you know
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Check your tft backlights for burnt or breakage .
Posted on Sep 29, 2008
  • olayoju victor Nov 10, 2008
    remove the cover, then the earth sheilding cover then u unplug the tft lamps & interchange the left plugs to the right & the right to the left. test for ur result, if the right side is clear & the left is dark , ur tft lamp is bad.but if otherwise ,u change ur screen.
    for guest laptop, it has only one tft lamp .best solution is to remove ur lamp & check& if not possible u change ur screen.
Westinghouse
seems like a bad panel to me, sonys are know for that, also, check connection on t-con board,.
Jul 07, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
The Dell E17Fpf 17" TFT LCD Monitor power-on very dark with the left side of the screen darker than the right. After on for about a minute, the brightness comes up to near normal brightness. Please...
Your backlight inverter is about to go out. There are 2 small parts that need to be replaced. Check our web site at: www.ccl-la.com, we have a step by step repair guide to that model.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 21, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Dark shadow on left side of laptop screen
THE SCALAR OF YOUR LCD ARE LEAK IT'S RECOMEND TO REPLACE A NEW ONE LCD
Aug 18, 2009 | Computers & Internet
Dark area on left side of screen of Dell Inspiron 1525
ok , i have had this problem on bolth my dell inspiron laptops , on a 6400 and a 1525 . the 6400 had the lower left corner all dark and the 1525 was split right down the center . i fix bolth of em in a really simple way , turn on ur pc and go into windows , press the blue Fn button and the down arrow untill ur brightness from ur backlight is completely down . keep it that way with the screen on with a screen saver for about one hour then turn brightness back up but not all the way up cuz in my case the problem hapened again , but when i keep it just one click darker , boom problem fixed . from what i can figuere out is that the inverter aint powerfull enought to power the backlight and tends to over heat , so keeping the backlight a bit lower tend the keep em ok
May 28, 2009 | Dell Inspiron 1525 Notebook
Loss of light on screen Dell Inspiron E1705
Looks like the backlighting on the display has failed, sometimes it is just a lose cable, buy most often the LCD needs to be replaced.
to check the cable see the manual at http://support.dell.com/support/edocs/systems/ins9400/ for how to get to the LCD cables (usually just under the cover that the power button is on)
Jan 27, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Shadow down left hand side of screen
Is it an LCD or DLP? The Model below suggests it is an DLP. Sounds as if you have the dreaded light tunnel collapse common to all LG DLP TV's. Inside the light engine there is a square tube made up of four mirrors. These mirrors deform and crack with the heat of the lamp. They fall down over the light aperture and cause a shadow of varying degrees. It is fixable now at a realistic price ( used to have to replace engine) as LG have made the parts available. It would take a competent tech around three hours to complete or if you are technically minded you could do it yourself. I hope this helps. Good Luck.
Jul 30, 2008 | LG RU-44SZ51D 44" Rear Projection...
Shadowing
is this a color shadow like convergence problems or just dark?
Dec 26, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Philips Magnavox 15MF400T 15 in. LCD Television Logo
168 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
