Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune - door locked, clothes inside, lights are on, no reaction to unplugging and replugging. Help! My work clothes are in there! Thanks a lot.
  • michele932 Oct 04, 2008
    thanks....I will try this. I pulled the emergency cord and that released the door and allowed the door to unlock. However, I have been unable to complete any other laundry. I will maybe try again with another loac and see if your fix works.....thanks a lot.
    Michele
The manual says that you should push the on/off button to turn off the machin. Wait for 2 minutes for the door to unlock. Then open the washer door.
Audioguy4
Posted on Oct 04, 2008
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washing machine is Neptune. The front door is locked and water is inside with wet clothes.
If you have a Maytag Neptune MAH3000, MAH4000, MAH5500A or a 2000 stacker then your wax motor might be the issue. See www.neptunehelp.com for info on the faulty door latch wax motor and how to fix it.
If unplugging machine does not allow the door to open then remove the 4 philips screws on the soap dispenser bezel ( under lid) and remove it. There should be a colored plastic cord in there you can pull on to unlock the door, It is an emergency pull cord.
May 17, 2009 | Washing Machines
Maytag Neptune washer error FL
There is a manual door release tab in the dispenser area. You have to take the screws out and remove the dispenser to pull the tab and release the door. This is a pretty common issue, if you haven't yet you should contact your Maytag authorized dealer and ask about a more permanent solution. Hope you can get your clothes out.
Thanks
Apr 29, 2009 | Maytag Neptune MAH7500WH Front Load Washer
My maytag neptune front load washer won't unlock. I may have to replace the wax motor per so many other blogs. I may be able to get to it in two days. Meanwhile, I have expensive clothes locked inside my...
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened.
Apr 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front load washer won't turn on
did you try unplugging the unit for at least 10 minutes?
Mar 23, 2009 | Maytag Neptune MAH9700 Front Load Washer
Won't drain all the way and door lock won't light up
Clean out the drain pump and check the pump motor while it is dis-assembled.
Mar 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune - died with clothes inside and door locked
hi there,
sounds like you may have had a power outage or tripped the breaker on the main electrical panel on your house. can you have a look for me please?
if not it's the main control board that is defective.
can you tell me the full model # & serial # (these will be located on your bill of sale, since you can't open the door).
i will check the warranty info and let you know if the board has warranty.
thanks.
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
My neptune does not extract.  My clothes come out dripping wet.
I am having the same problem, and have found that the door lock light is not on, and that the door lock does not seem to be working. This would keep the machine from spinning.
Is your door lock light on?
Jun 14, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
737 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
