Question about Acer Computers & Internet
MY DESKTOP FREZZER'S UP - Acer Computers & Internet
  • 781 Answers
There're different things you can try (try in order):
1. virus/spyware: have your antivirus and anti-malware programs updated and run deep scans if possible or do several scans going deeper everytime in terms of location your virus/antimalware can search for threats. do the cleaning in safe mode. are you getting the freeze up condition in safemode as well??
2. memory - test memory and replace and test memory sticks one at a time (if you have more than one memory sticks)
3. some pci card or installed adapter may not be working properly (test your hardware with a software called SANDRA from sisoft.
4. something else on the motherboard - when there's hardware malfunctioning intermittently you may have to replace your motherboard.
freeze ups are hard to diagnosed and to isolate. you may also want to post specifically when you see the freeze up condition appear (what were/are you doing before the computer freeze up) that may tell us more about where the problem lies.
Posted on Sep 29, 2008
    Problem Solver:
  • 7 Answers
It needs to be restart if it freezes up...after restarting if it still freezes up clean your memory card or scan for viruses...
    Scholar:
  • 67 Answers
First try alt+control+delete option if u can reach on task manager. close all application from task manager and it should be good to go.
it might be number of reasons why your computer are freezing. but make sure about ur cpu fan if its stop working or not cooling your system 's processor. This fan is located on top of your processor.
that would be the worst one coz it could fry up ur processor.
Some other reasons may be faulty ram, any new hardware changes etc.
but next time please explain your situation little more thouroughly so its easy for anybody here to help you ..
Good luck !!!
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hi,i have fisher pakel E522B with frezzer on the bottom the fridge goes warm and the frezzer section is all iced up.pulled back cover of frezzer off and removed fan,tested fan across 5v ph charger fan...
HI,CHECK FOR CONTINUITY ON THE DEFROST ELEMENT AND B-METAL IF THOSE COMPONENTS PASS THE TEST MAYBE THE TIMER OR DEFROST CONTROL COULD BE BAD IN YOUR REFRIGERATOR..GOOD LUCK..
Jul 04, 2011 | Fisher and Paykel Active Smart E522B...
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water leaking from left side of frezzer out the
There is a restriction in the condensate drain. You should be able to press a piece of tubing against the drain opening (inside fridge) and BLOW (NOT ****) through the other end. this should clear the obstruction. The obstruction would be slimy goop, sooo again -
NO ****!
Sep 15, 2009 | Jenn-Air Refrigerators
Frigerator doesn't get cold but frezzer works frezzer gets way to cold have to defrost every now and then and fridge is warm? dont know what's wrong it's a kemore model # 10675929400 frezzer is on...
Check to see if interior fan motor is running and blades are forcing cold air down to the lower section. New fan motors can be ordered from repairclinic.com or local parts house. Also look for blocked air ducts at back of cabinet.
Jun 09, 2009 | Refrigerators
Dampness atound casing on frezzer
inside the refrigerator is a small switch which has energy saver and another side that differs with brands put the switch on the other dide (not energy saver) and this will energise a mullion heater which runs around the frame under the plastic mouldings. what causes the dampness? the difference in temperature between the fefrigerator and room temperature
Feb 05, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
New Sanyo Fridge not working
I have the sam eproblem but my freezer is very cool, but the fridge wont get cold, it is just chilled, my food still goes bad and the water and soda is room tem..this doesnt make sense!
Nov 25, 2007 | Sanyo SR-1030W Top Freezer Refrigerator
Computers & Internet Logo
46 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
