Question about Olympus Cameras
When I turn on my Olympus FE-190 camera it shows the "card setup" screen with two choices: Power Off (highlighted) or Format, and gives a 3-ring alert sound. (It does this no matter what is set on the program dial: auto, guide, etc.) If I press OK to "set" with Power Off highlighted, it turns off. If I highlight format and press OK of course it warns me I'll be reformatting the XD card. When I attach the usb cable the screen on the camera shows PC highlighted but when I press OK it says "one moment" and then shuts down. The battery is freshly charged and correctly seated. While the FE is attached to my Mac with the USB cable if I select "transfer images--from camera" the application claims the camera is not connected. The camera has been religiously stored in its case and respectfully handled, has not been exposed to temperature extremes, etc. It just suddenly started misbehaving. I bought the camera December 2006 and it has worked flawlessly until now. I don't use it frequently. Thanks in advance for your help.
Fixed it by reseating the xD card. Voila! Back to normal.
Posted on Sep 30, 2008
Card format gone, camera works fine with different card. can card be reformatted? camera wont show any screen but blue "card not formatted"
Try formatting the card in a computer card reader and then format it again in the camera. If that won't work, the card needs to be replaced.
Feb 17, 2010 | Olympus FE-190 Digital Camera
I HAVE AN OLYMPUS MASTER (FE-190 )AND I HAVE LOST SERIAL NUMBER
I looked up the FE-190 and it says it uses XD Memory Cards not discs. Several companys make a card reader that plug into the USB connector
on computers. 2 are Targus and Lexar. You could probable find an XD card reader at Walmart or Radio Shack. The XD memory card will then show up
on your computer screen as a regular folder that contains JPG files, which are the pictures.
Nov 27, 2009 | Olympus Camedia D-425 / C-170 Digital...
Card setup
take the card out and see if the same thing happens, most likely it is the card and it is corrupted in some way
Apr 07, 2009 | Olympus FE-230 Digital Camera
XD card setup
Try to clean contacts with 70% alcohol and q-tip.
Mar 29, 2009 | Olympus FE-210 Digital Camera
Olympus FE-210 Camera Problem
Format the card, this error idicates that some required data is missing from the card .
Feb 26, 2008 | Olympus Camedia C-350 Digital Camera
Write Project?!?!?
If you camera has some internal memory remove your memory card and see if the camera works. If so, check the memory card and see if the little switch is in the "lock" position.
Feb 21, 2008 | Olympus FE-190 Digital Camera
Well, I had same issue and call the crapus support and they told me to format it. That is solution they recommend. it happen to me three times already had a camera less than 2 month. Well time to sell crapus and get me a real camera, I had Nikon and Canon almost 8 years and never had issue with memory card. I was stupid to take chance on crapus, by the way if you are not using none olympus brand memory card you are out of luck, they do not support.
Thanks
Dec 09, 2007 | Olympus FE-230 Digital Camera
Cameras Logo
102 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
