Question about Acer Aspire 5600 Series 5630-6951 Laptop
I need to obtain Acer erecovery software on CD/DVD
I have a Acer Aspire 5601 and wish to upgrade the HDD but need the erecovery software on CD/DVD to be able to install the OS on the new drive.
Do you know where I can get hold of this software or can you offer some advice on how I might achieve this goal.
Any help will be greatly appreciated.
John A. Brinkley
Driver wireless a telecharger pour Acer travelMate C110
Posted on Sep 29, 2008
  • Acer Master
  • 787 Answers
The eRecovery software should be installed on your computer and you can use it to burn the disks yourself.
Click Start, Programs, Acer Empowering Technology, Acer eRecovery Management.
The management windows will open.
At the bottom click on Burn Disk
Click Create Factory Default Disc - good idea to have this because it put the machine back to new state - warning, you will wipe out any existing data from the hard drive if you boot of this disk.
You can also burn a driver and application backup disk and a current system configuration backup
If you click on Backup on the bottom you have the choice of doing a full system backup,this is probably what will work best for you but I do recommend having a set of factory default available.
Acer aspire one -- windows failed to start. it says to insert windows installation disc and restart computer. I do not have a disc drive or disc. Status: 0xc000000f is the code Info the boot selection...
Hi ljcoppes...
If you have to use the CD/DVD's for recovery then you will have to buy or borrow a usb connected CD/DVD reader/player.
Using Acer eRecovery by following these steps:
1.Click Start, and then All Programs
2.Click Acer, and then Acer eRecovery Management
3.You may be prompted to enter or create a password. This password will be required to use eRecovery in the future.
4.In the next window on the left toolbar, select Restore.
5.Choose Reinstall Drivers or Applications
6.Choose Contents
7.Choose the driver or application you wish to install
8.On the right, click the Install link and follow the prompts.
9.The computer may restart when installation is complete. If it does not restart, manually shutdown and restart the computer.
Note: For older Acer products, the Acer eRecovery Management program may not be available.
If you do not have a set of Acer Recovery Media, they may be purchased from our Acer Recovery Media Order Form.
Please take time to rate me thumbs up
Sep 18, 2011 | Acer Aspire One Netbook
I formatted my Acer Aspire One and installed Fedora Linux, but I need to re-install Windows 7 Starter. The shop I purchased it from gave me 3 Acer Aspire D255 Windows 7 Starter DVD disks which I...
To reinstall you need an external DVDROM drive and run directly the windows 7 installer as boot up disk. Because it need to run alone as boot up disk and surely it will not run when you just copy the files to external HDD.
Jan 04, 2011 | Acer Aspire One PC Notebook
I have acer aspire 4520.I have upgraded to windows xp sp2. The empowering technology does not work.It says " the specified file is not found".I cannot find the empowering technology software...
Acer Aspire 4520 Notebook Technical Specifications:
Operating System Genuine Windows Vista Home Premium Processor AMD Athlon™ 64 X2 Dual-Core Processor TK-57 (512KB L2 cache, 1.9GHz) Chipset NVIDIA nForce 610M Memory 1GB (1GB installed in one of two memory slots) DDR2 667 SDRAM User upgradeable up to 4GB (one 2GB memory card in each slot)* subject to availability of 2GB cards
*If upgrading after initial purchase, one or more of the memory cards provided with the system may have to be replaced with optional larger memory cards in order to achieve the maximum capacity.
Storage 120GB* hard disk drive Integrated variable-speed Super-Multi drive (DVD+R, DVD-R, DVD-RAM):
-Read - 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
-Write - 24X CD-R, 10X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
5-in-1 card reader for optional MultiMediaCard™, Secure Digital card, Memory Stick, Memory Stick PRO™ or xD-Picture Card™
Surely to load XP is a DownGrade. As this notebook is dual core, I would run Vista 64 or better still Windows 7 64.
If you wish to persist with an old system, you require SP3 for XP.That may be available from a software store but is no longer supported by Windows.
Try http://www.notebook-driver.com/laptops-information/acer-aspire-4520-notebook-technical-specifications/ for drivers that you will require to have support from Acer.
Hope that clarifies your situation.
Dec 09, 2010 | Acer Aspire 4520-5582 Notebook
My acer aspire 4315 stuck at boot with white screen, when using external monitor it show acer boot screen and stuck there. I can press F2 for setup but nothing happen.
http://tim.id.au/laptops/acer/aspire%204715z%204315.pdf
Above is a link for your Service manual, inside is everything you need to know to troubleshoot and repair your machine, this is the manual that us engineers use to repair these units.
This could be your HDD, failed. Work through, the troubleshooting procedures.
Anyway try this below first. Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
May 14, 2010 | Acer Aspire 4315 Notebook
How do I do a full recovery with the disc
Turn your computer on.
Insert the Disk and choose to enter BIOS, should be F2 but watch the screen to see the right function key.
Change the boot device order to: CD-ROM, HDD in that order.
Save changes and restart the computer.
The Recovery Disk would boot up and a wizard will guide you through the recovery process.
Follow the instructions to recover your computer.
Apr 03, 2010 | Acer Aspire 3050-1733 Notebook
I have an Acer Aspire 5720, ive had it for a year now and it is starting to slow down. I have lost the booklet to it and i need to do a master reset on it. Ive already backed everything up im just finding...
This was taken straight out of the manual for your model, which can be found here.
Acer eRecovery Management is a tool to quickly backup and restore the system.
You can create and save a backup of the current system configuration to hard
disk, CD or DVD. You can also backup/restore the factory default image, and
reinstall applications and drivers.
Acer eRecovery Management consists of the following functions:
1 Create backup
2 Burn backup disc
3 Restore and recovery
This chapter will guide you through each process.
Note: This feature is only available on certain models. For systems
that do not have a built-in optical disc burner, plug in an external
optical disc burner before entering Acer eRecovery Management
for optical disc-related tasks.
When using Acer eRecovery Management, you may be prompted to enter the
Empowering Technology password to proceed. The Empowering Technology
password is set using the Empowering Technology toolbar or when first running
Acer eLock Management or Acer eRecovery Management.
Create backup
You can easily create full and fast (incremental) backup images of your system
configuration to hard disk from the main Acer eRecovery Management screen.
Note: Fast (incremental) Backup is only available after a Full
Backup is made.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 In the Acer eRecovery Management window, select the type of backup you
want to create using Full or Fast.
3 Follow the instructions on screen to complete the process.
83
English
Burn backup disc
Using the Burn Disc page of Acer eRecovery Management, you can burn the
factory default image, a user backup image, the current system configuration,
or an application backup image to CD or DVD.
2 Switch to the Burn Disc page by selecting the Burn Disc button.
3 Select the type of backup (factory default, user, current system,
application) you would like to burn to disc. Choosing to burn a user backup
will burn your most recently created backup image to disc.
4 Follow the instructions on screen to complete the process.
Note: Create a factory default image when you want to burn a
bootable disc that contains your computer's entire operating
system as it was delivered to you from the factory. If you wish to
have a disc that will allow you to browse the contents and install
selected drivers and applications, create an application backup
image instead — this disc will not be bootable.
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
Dec 20, 2009 | Acer Aspire 5720 Notebook
Cant open acer eRecovery Management?
the problem here happened to my PC as well, whenever I tried to run eRecovery manager, either the computer hangs or it restarts. Usually the recovery software should be used when the drivers fail
Possible Solution: 1) Reinstall the eRecovery manager from the CD/DVD provided 2) Download by going online: http://support.acer-euro.com/empowering_technology/utility.html
Hope this helps
Nov 09, 2009 | Acer Aspire One PC Notebook
How can i reformat my laptop on CD acer aspire 3000
Using Acer eRecovery Management
You can launch Acer eRecovery Management in a number of ways:
Acer eRecovery Management requires a password to activate. The default password is six zeros (0s).
Note: These steps will return the system to the original factory installation including all factory installed drivers and applications.
Back up all data prior to using this procedure.
  1. Plug in the AC adapter and battery.
  2. Turn the system on
  3. Immediately, press ALT on the keyboard and start tapping F10.
    Continue holding ALT and tapping F10 as the unit boots up.
  4. A screen stating "Starting Acer Erecovery" should appear.
    (Release ALT and stop tapping F10 at this point)
  5. There will be 4 options:
    1. Restore system to factory default
    2. Restore system from user backup
    3. Restore system from cd/dvd
    4. Exit
OR
From the Start menu, go to Start > (All) Programs > Empowering Technology > Acer eRecovery Management.
Or try this By clicking on the Empowering Technology icon from your desktop, or pressing the key to launch the Empowering Technology user interface. Select the Acer eRecovery Management icon.
Oct 11, 2009 | Acer Aspire 3000 Notebook
Install the eRecovery drivers for aspire 5715Z
First ensure you have enabled D2D from Bios, If bios settings are OK then that message often comes up when E recovery partition is damaged.
Possible solutions are calling Acer and getting a disk to restore recovery partition (best way to proceed)
Or downloading and installing drivers from acer website
Here is recovery procedure from manual, to ensure you are doing corrrectly:
Create backup
You can create and save backup images to hard disk, CD or DVD.
1 Boot to Windows XP
2 Press Alt + F10 to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery settings and
click Next.
5 In the Recovery settings window, select Backup snapshot image and
click Next.
6 Select the backup method.
a Use Backup to HDD to store the backup disk image on drive D:.
b Backup to optical device to store the backup image on CD or DVD.
7 After choosing the backup method, click Next.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process
Here Acer download page: Acer Service & Support
May 05, 2009 | Computers & Internet
Keyboard stops responding after a powersave on laptop ACER 5715Z
The issue is that several of the Acer software products don't support Vista. You need to remove these programs.
Follow the instructions in this link
http://global.acer.com/support/winvista/t-faq.htm
Due to architectural changes to Windows Vista®,some Acer applications are not supported anymore. Below is a summary ofthese applications. Uninstall these applications before the upgrade.
Acer eRecovery Management The new version of Acer eRecovery Management, which is compatible with Windows Vista®,requires repartitioning your hard disk drive, causing data loss. As aresult, the Wizard will not reinstall the new version of eRecovery onyour computer under Windows Vista®. However, you will be able to find similar features in the built-in Backup Utility of Windows Vista®, including full system volume backup to a HDD or CD/DVD. Acer eAcoustics Management Windows Vista® supports similar functions of eAcoustics so Acer will no longer provide this utility for Windows Vista®. Acer ePresentation Management You can easily manage your external monitor settings via Windows Vista® Mobility Center. As a result, we do not support an upgrade to Acer ePresentation Management. Acer ePower Management Due to architectural changes to Windows Vista®,Acer ePower Management cannot be upgraded for some models. However, youcan easily manage your power settings via Windows Vista® Mobility Center instead. Acer ePerformance Management For notebooks only. Since Windows Vista® provides similar resource management functionalities, we will no longer provide this for notebook models with Windows Vista®. Acer Arcade™ Deluxe 3.x
Acer eNet Management 1.x
Acer eDataSecurity Management 1.x Due to architectural changes to Windows Vista®, these applications cannot be upgraded.
Alternately (not recommended) you can change your settings with the following method. I would recommend removing all the Acer software though as keeping them might cause problems.
Check under Advanced Power Options-> Multimedia Setting -> When Sharing Media. By default onBattery and Plugged is set to "Allow the computer to enter AwayMode" Changing this setting to "Allow Computer to sleep" should solve theproblem. On Battery the Away Mode "does" allow the computer to sleepproperly.
Jan 27, 2009 | Computers & Internet
Acer Aspire 5600 Series 5630-6951 Laptop Logo
154 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
