Question about Kenwood Car Audio & Video
Touch screen won't open
I have this in dash system and it will not open to display the screen. How do I fx this problem? I have already check the ground wire and fuses are good.
  • 98 Answers
This sounds like a defective flat cable from the face to the main PCB (A common defect on the older in dash systems.
Posted on Oct 02, 2008
How to replace display of ir2800
  1. Open the Right door.
  2. Open the two screws Marked as 1and 4.
  3. Open Last One screw Left side a hole in Display.
  4. Remove the connector with safety.
  5. Open the 4 Screws back side of the display.
  6. Disconnect all the Connectors.
  7. Remove all the Circuits.
  8. Remove all the Self threaded Screws.
  9. And Remove the Iron Base Plate.
  10. And Safely replace the Display with new one.
  11. Place the Touch Screen Properly.
  12. And reinstall The Iron Base Plate.
  13. Place all the Circuits.
  14. Connect all the Connectors as connect they before disassemble.
  15. Reinstall Properly the Display as Before It Place.
  16. Now on the machine and check it...boom boom..
Do not Do That:
  1. Do not use Thinner and Hard stain remover Acids.
  2. Do not clean the circuits with liquids.
  3. Connect all the Connectors at Proper port.
  4. Place the screw well fit to display and touch screen to work touch screen properly.
  5. Do not give room with Display and Touch it may not work properly.
May 14, 2016 | Canon Ir 3300 Black & White Copier
Sharp fx plus screen unresponsive
Sounds like the touch screen is dead, the crack most likely broke the touch screen sensor
Jan 20, 2014 | Sharp FX Plus
CD changer won't open. Mechanical Error on display
There is a small hole just above the door on most CD changers. Unwind a small paper clip and GENTLY push it into the hole. This should release the door, and let you look inside. Don't force it because you could damage it more than it is already.
Jun 15, 2012 | Yamaha GX-700 Shelf System
Black screen won't boot
From the description it is the motherboard that has major issues, sub out the ram memory one at a time and test each, If there is no change! the motherboard unfortuneately is the problem, only option is to replace board or laptop.
Apr 22, 2012 | Gateway P7908u FX Notebook
I droped my lg virgin rumor touch and The touch screen cracked but when I turn it on it stays black. What could I do?
If you won't see anything on screen,check if the phone is booting or turning on,if it turns on,display is probably the problem.but if doesn't power?software problem is the main cause.and with this,need to replace LCD as well as touch screen that was damage too.
If your mobile has a warranty,you can bring it to the service center for spare parts replacement.If you try to open it and it's under warranty,this will void you warranty and unable to benefit free of service charge.
Jun 15, 2011 | LG RUMOR Cellular Phone
How do you get the answer in decimal form?
Set the default Input/Output mode to LineIO.
Press [SHIFT][MODE] to access the (SETUP) screen. (see the screen capture below)
Select [2:LineIO].
If you want still to use the MthIO but just want your results displayed in decimal form press [SHIFT][=] or if the result is already displayed use the [S=D] key to toggle between formats.
Jul 27, 2010 | Casio fx-300ES Calculator
My Casio fx-85v Super - fx solar power calculator shows a erratic
Yeah I had the same problem, you need to open your calculator and check if all the screen cables is alright, i had just put sellotape on the back of the screen from inside so that the screen hold better, and it works for me if for you not maybe something broken in the schema but try it. The thing I know for sure the problem is in the screen or from where it get the data the schema. Tell me if it's working
Jul 01, 2009 | Casio FX-115ES Scientific Calculator
Can't get the DVD player to wok in my 2006 Lexus GS300
Repair Procedure
1. Confirm the customer's complaint of DVD RSE system inoperative.
2. For vehicles with Lexus Navigation System, perform the following procedure to turn OFF the RSE Lock function:
A. Press the INFO button to display the "Information" screen on the navigation unit.
B. Press the "Screen Setting" touch button on the navigation display.
C. Under the "Rear Lock" option, press the "OFF" touch button and then press "OK" in the upper right part of the display.
D. Press the DVD switch on the RSE system, (If a DVD is NOT already in the player, insert one) and confirm screen is "ON" and the system will play DVD's.
3. For vehicles without Lexus Navigation System, perform the procedure to turn "OFF" the RSE Lock function.
A. Push the audio control knob multiple times to cycle through the various options (Bass, Mid, Treble, etc.) until "Rear Lock" is shown on the screen.
B. Turn the audio control knob so the display says "OFF" next to "REAR LOCK".
C. Press the DVD switch on the RSE (if a DVD is NOT already in the player, insert one.) and confirm screen is "ON" and the system will play DVDs.
4. If the above procedure resolves the concern, explain the system operation to the customer. This procedure is described in the "Audio/Video" section of the vehicle owner's manual.let me know lf this helps.
Jun 14, 2009 | 2006 Lexus GS
Installation problem
UR recovery cd is not getting the operating system recover properly.................... u need to again install the operating system................Sameeraryan
Jan 16, 2009 | Sony VAIO PCG-TR3AP1 Notebook
Car Audio & Video Logo
77 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
