Question about Yamaha Full-Size Keyboard
Keys not sounding as loud as others
Hi, I noticed the your recent post describing the contact problem on yamaha keyboards. Mine is similar, I have a Yamaha YPP-50, and it seems to all be in one " area " of the keyboard, 2-6 keys. Could you please help me by pointing me in a direction of part(s) #'s etc. ? Many Thanks.
  • bigsteve1911 Nov 20, 2008
    Got the same problem on a Yamaha YPP-50.  Some keys suddenly sound much louder, with no change in playing style, and others occasionally freeze - it's only for a nano-second, but enough to notice it.
    Anyone in the UK know where to get replacement contacts & how to change them?
    thanks!
Hi, BHOWDY.
Probably the best thing to do is call the Yamaha service center nearest you. I live in the Los Angeles area, and the Yamaha service center closest to me is in Buena Park. I called them on the phone and told them what the problem was, and they knew immediately what parts were needed and they shipped them out that same day.
The contacts that seem to wear out the fastest are the ones near the middle of the keyboard. On my CLP-170, it's the keys between middle C and the G above that -- probably no more then 4 or 5 keys. However, I ordered replacement contacts for all 88 keys because once you take the piano apart to replace the contacts, you may as well replace all of them.
Good luck, Howard
Posted on Sep 29, 2008
The third G key on my Yamaha YPT 300 does not cooperate with the touch response feature. Regardless of how hard I press it, it plays the note loudly. All of the other keys are fine.
Below the keyboard, there is a rubber contact (see figure 1).third-g-key-yamaha-ypt-300-not-cooperate-shyexoo0xcste5eq310zs3ot-4-0.jpg Damage to the contact rubber can cause:
- Note plays loudly or
- Note does not plays at all.
It is caused by:
1. Carbon rubber contacts dirty / dusty (yellow arrow). Clean with a pencil eraser (or cloth). Gently rub it.
2. Contact shredded rubber. If this happen,it can not be repaired or glue. So, you have to replace one octave as in Figure 1.
The yellow arrow indicates the side that is often torn.
Sep 27, 2015 | Yamaha Music
One key sounds louder than the others
Hi, This is very likely to be a dirty key contact.
If the loud key is not touch sensitive or by turning the touch off, if all the keys are the same volume then this points to a dirty key contact.
All the best, Chris the Fader.
Mar 08, 2014 | Casio Privia Keyboard Case
Yamaha psr 295
Hi, This is probably due to worn rubber contacts. The sound is switched by pressing a key which in turns press a carbon contact on the PCB under the key. In time these wear out and need to be replaced.
Firstly open up the keyboard and locate the rubber contacts, check to see if each one is seated squarely, if they are not seat straight then this can create the problem you mention.
If all are OK then you will need to replace the strip which is causing a problem.
Spares are available from many sources including :
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=16049
Jul 20, 2013 | Yamaha PSR-295MS Portable 61-Key...
Dead keys yamaha psr e413 keyboard
Dead keys on Yamaha PSR e413 keyboard: Flip keyboard upside down, remove cover screws (use marked cardboard template to remember where they came out), spray suspect key-contacts with fast-drying contact cleaner, (usually a PCB with a matrix of contacts under keys), re-assemble base cover, wiggle faulty keys as far as possible to 'scrub' any dirt or oxidization. If this cleaning trick doesn't work, get a pro to check it.
Dec 08, 2012 | Yamaha PSRE413 Keyboard
I have a Yamaha PSR-S700. Recently, the touch sensitivity in one of the keys stopped working. Very little pressure applied would cause the note to sound as if the touch sensitivity was off completely. Now...
You MAY be confusing touch sensitivity with VELOCITY sensing. Touch sensitivity is PRESSURE put on AFTER the note sounds that causes modulation. VELOCITY is what is used for example to control the loudness of pianoo notes depending how fast they are struck. VELOCITY sensing is done by using TWO contacts at every key... one closes first. IF one of these gets dirty, FULL velocity will be sensed and it will be LOUD. The contacts can be cleaned using ONLY 99% isoprophyl alcohol and Qtips after MUCH disassembly of the keyboard. The contacts are conductive rubber pills in silicone rubber domes. Clean boththe contacts and the circuit traces they pres down onto.
Apr 02, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
Yamaha pt300 keyboard. only make loud humming sound. Keys register on monitor when touchedas do change in song etc...but no sound other than humming.
If the unit uses a wall transformer, make sure you have the right unit.
The Yamaha correct ones are branded Yamaha. Use of the wrong one can damage keybooard or be inoperative.
The PT300 did not come up as a valid keyboard. Suspect the number is either YPT-300 or a P-300..
Sep 27, 2009 | Yamaha Music
Yamaha PSR-GX76 musical keyboard problems
Does it have onboard speakers?
If so, try to tighten down (fix firmly in place) the wire mesh that protects the speakers, if it's loose, it will vibrate and cause distortion in the sound.
I once had to repair a portasound which sounded really crappy when a group of keys was struck at high volume, and it would only calm down when i fixed the speaker mesh so that it didn't vibrate with loud sounds.
You may want to put some rubber or similar into the groove where the mesh edge fits in to prevent it from vibrating (i solved mine just by tightening up the mesh strips where they protrude into the housing).
If this doesn't help, then it's something else (possibly a bad or dirty connector contact or a bad solder contact).
regards
3rq8 (Triarcuate)
Jul 30, 2009 | Music
Psr e303 yamaha double sounds
Do you cover the keyboard when not in use as small particles of dust can make their way in between the keys?
You can try blowing any obstruction out with a can of compressed air, may solve your problem.
As I'm not familiar with this Model, does the keyboard have 'touch response' on board? If so there will probably be a 'Contact' strip made out of tubular rubber under the keys and this can sometimes 'burst' especially on a certain key that is played most of the time. For example if you play mostly in the key of 'G' or keys that use that note....
Hope you find this helpful......
Dec 28, 2008 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
404 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
