Question about Microsoft Xbox 360 Console
X box 360 error????
My xbox 360 has an e 64 error and with one red light on. can someone guide me in the right way to help me fix it please?
  • 1 more comment
  • bscerejr Sep 29, 2008
    please help and let me know or guide me in the right direction in fixing my xbox 360
  • athiest117 Jan 16, 2009
    1022 AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
    Why has MS not made a quick fix????
  • sammysoto44 Apr 13, 2009
    the putton you press to turn on the x-box 360 thers a red light fashingad a green light in the middle
The specific type of hardware failure can be determined by a "hidden"
error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding
that button press the eject button.
The LEDs will now blink the first number in the code (as described
below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing
lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the
console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling
your console make sure to all 8 of the heatsync screws are tightened
securely to the board/heatsink holes.
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 DVD Drive Time out - Can be caused by problems with a firmware flash.
This is also speculated to sometime be caused by a problem with the
southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
0023 (not yet known)
0101 (not yet known)
0102 unknown error
though it's most likely GPU related literally means the console does not
know what is wrong. possibly a short or cold solder joint somewhere. So
far there is 1 major theory for what causes most of these errors is that
the Ram, CPU, or GPU are not soldered properly to the mother board due
either to poor manufacturing or excessive heat up and cool down cycles
that stress, weaken and eventually break the soldered connection.
There are two theories to fixing this one deals with the "X" clamps that
hold down the chips. The other involves re-Heating the chips. DO NOT
attempt either of these if your console is still under warranty. If your
console is still under warranty return it to the store where it was
purchased or call MS to have it replaced. I have also heard of limited
success by simply switching the AV cable from "HDTV" mode to "TV" mode.
0103 CPU Error/ CPU Overheating - see solution for error 0102
0110 Memory Error / Memory Overheating - see solution for error 0102
0200 (not yet known)
1000 (not yet known)
1001 (not yet known)
1002 (not yet known)
1003 Hard Drive Error... It could be a problem with the Hard Drive itself
or a problem with the internal connection to the hard drive, Try removing
the hard drive and playing without it
1010 Hard Drive Error, Can be caused buy a corrupt or missing eProm.
1011 (not yet known)
1012 (not yet known)
1013 (not yet known) possibly a dashboard update error
1020 (not yet known)
1021 (not yet known)
1023 DVD drive not connected, connect DVD drive to boot
1030 (not yet known)
1031 (not yet known)
1032 (not yet known)
1033 (not yet known)
1444 and up There is no "4" in the error codes four lights is a "0" go
back and check your code again.
Posted on Oct 01, 2008
I cant get into xbox live my ip address works but xbox live doesnt
Someone plugged there xbox 360 HDMI cable into the USB port in a laptop. Now they get a E74 and 1 red light lower right side . What can they do now.
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 14, 2011 | Microsoft Xbox 360 Console
Fix xbox360 red light
XBOX 360 Red Light error, or Red ring of Death RORD is a very common issue, and can happen anytime. There are different Error numbers related to RoRD, and appears on screen starting with "E".
Red light problem can be fixed! there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console. Please feel free to message me if you need further assistance click here
Dec 22, 2010 | Microsoft Xbox 360 Console
Red light come on xbox360 what is the problem
If you get red light around your xbox power button the you have red ring of death. This is when your Xbox has overheated. While im not all that famlier with Xbox I have read there is a 6 cent fix (cause you use 6 pennies) You would have to read up because as I sid before not great with Xbox. I'm sure microsoft would do it to but hey if you good with tools 6 cents sounds pretty cheap.
Im sorry for your loss
Good Luck and Happy Gaming-Koscoe
Oct 13, 2010 | Video Game Consoles & Games
One red light on the bottom right on the power button
click here to download repair guide......
Oct 07, 2010 | Microsoft Xbox 360 Console
Red ring
hi there,
your xbox 360 need service open it and remove all dust around the fan and prosseser every thing fine again.
Jul 11, 2010 | Microsoft Xbox 360 Console
My xbox360 has an error one red light on the bottom right hand side
Greetings,
Please go through the Website link mentioned below.
http://support.microsoft.com/kb/907536
Please let me know if you have any issues.
Regards,
Feb 09, 2010 | Microsoft Xbox Console
3 red lights on xbox360
3 red lights on the Xbox 360 is the most common error and it means "General Hardware failure. To fix this you need to stop the amount of heat that the GPU and the CPU is taking.
To do this you can use the recommended guide that has been on the market for 3 years or you can send it in.
Jan 25, 2010 | Microsoft Xbox 360 Console
My xbox360 keeps blinking red green why
is there something not plugged in right?
Nov 18, 2009 | Microsoft Xbox 360 Console
My xbox360 has one red ring in the bottom right corner.
if it wont work at all its fried and you need to send it in, but if it does work just has that circle im not sure sorry :(
Feb 17, 2009 | Microsoft Xbox 360 Console
3 red lights
it means you have a lose wire
Jan 04, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
692 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
