Question about Refrigerators
GE S-Series Side-by-side refrigerator
My GE side-by-side is in trouble. The freezer is not working, while the 'frig side works Ok so far as I can see.
The foil tag reads : Model ZISW42DSC, Serial No. ML037182, "Listed 72RO". It is a side-by-side in stainless steel with the compressor on top that is commonly mistaken for a sub-zero.
I let the heat exchanger clog with dust, so the whole t hing stopped working. I vacuumed that out and right away it got back on track, dropping both refrigerator and freezer back into proper temperature. However within a day or two the freezer thawed itself back out.
Any ideas?
  • kengineer Sep 29, 2008
    The plot thickens. One of the posts here suggested that it might be a bad temperature control unit. So I cycled the temperature dial (located in the refrigerator) to zero and back up a couple of times. Each time I reached zero, I heard the compressor stop running, then start again as soon as the dial was above zero. Now the ice cube tray I put in there as a test is frozen solid. Am I done? Problem fixed? Or just waiting to loom up and defrost my freezer again when I'm not looking?
  • 1,543 Answers
In cases where the freezer temperatures range between
minus 20°F and minus 35°F, and the fresh food temperatures
are constant or range intermittently between normal and 60°F,
the fresh food damper may be stuck in the closed position. In
this case, the sealed system will continue to run, attempting to
cool the fresh food compartment. This will cause sub-zero
temperatures in the freezer compartment and may lead to
freezing in the icemaker fill tube.
The damper may have failed to close, failed to open, or may
be only partially open. To correct this situation, replace the
fresh food damper. For your model, use WR09x10084.
Posted on Sep 29, 2008
  • 1,029 Answers
You ll change the temperature control unit,since its not performing optimally
.thanks and godbless
GE SIDE BY SIDE ICE AND WATER. FRIG MAKES A LOUD MOANING SOUND . EVERYTHING WORKS OK, EXCEPT FOR THE NOISE.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 27, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a frigidaire gallery series frig side by side with ice and water in door. The frig part won't stay cold. It also seems to take long time to make ice. The frig part works ok for awhile and then...
Check for two things. Look under the refrigerator and make sure the compressor fan is turning.
Second, check inside the freezer for proper operation of the fan that moves cool air throughout the freezer and refrigerator. If this fan is working, you can probably hear it. It should be behind an access plate in the freezer (near the top). Remove the plate and look at the fan. If it's not turning, you will have to replace the fan motor.
Oct 17, 2009 | Frigidaire FRS23KF7AB Side by Side...
GE frig/freezer side by side about 5 yrs
Bad defrost timer, most likely. It is not defrosting the evaporator, and therefore, no air can be passed over it. Hope this helps
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore side by side frig not cooling in frig comparment and
Something has failed in the defrost circuit-
Defrost thermostat
Defrost heater
Defrost timer
Reply back if you know how to diagnose electrical circuits, and I'll help you further.
Feb 01, 2009 | GE GSS20IEP Side by Side Refrigerator
Frig side is not cooling.
Check if there is frost on the back wall of the freezer, if so it is not defrosting. Many GE fridges need a new defrost heater every couple of years. If it's not defrosting, you can get by for a while by unplugging the fridge and leaving the freezer door open for 24 hrs, then plugging back in.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side frig: JSS22JEMC WW
sounds like defrost or fan problem let me know and I can help you
Apr 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE ADORA Refrgerator :
The water line from the house to the frig works, however the water in the frig just stop working one day. Any suggestions?
Feb 09, 2008 | GE Profile PSW26P Stainless Steel Side by...
Side by side GE profile
I have a GE side by side refrigerater freezer. I thas the diagnostic center on the freezer door. The de symbol started flashing afew days ago and the refridgerater side isn't getting cold. the fan is on and doen't seem to cut off, If someone could steer me in the right direction I would appreciate it.
Jan 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
