Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
Loss of suction bissell vacume
Lost suction on bissel lift off sweeper after sweeping flea powder from carpet. Cleaned all filters and still no suction
  • 1 more comment
  • krisleffew Oct 25, 2008
    My Bissel Lift-Off Revolution lost it's suction capabilities while in the middle of vacuuming. I emptied the filter because it was full at the time and still have no suction, but the brush is still functional. I went back to turn it on a few hours later and it was fully functional. Is this normal for the motor to over-heat and the suction to stop? The vacuum is about a year and half old, should I assume that this vacuum shouldn't last too much longer? It does get a lot of use since I own a dog. Can something simple be done to extend the life of this vacuum, since it is an expensive vacuum, I would hope it could last longer than a year and a half. Please help if you can. Thanks
  • jamies4 Jan 08, 2009
    My Bissell is only a couple months old. I dont' have a pet hair problem, but the vacuum has lost it's suctions and over heats/shuts off after only a few minutes. I clean both filters each time I empty the cannister. Am I missing something?
  • Anonymous Jan 17, 2009
    Same problem as all the others. Only 8 months old and has lost it suction and it over heats and shuts off.
Under the red flap in the water resevoir, there is a small screen. Pop that screen out and clean it. It is probably blocked with hair. I took my entire machine apart trying to fix this problem and I finally saw that screen. I cleaned it out and my machine works like new now.
Posted on Mar 10, 2009
    Problem Solver:
  • 7 Answers
That is normal for the vacume to shut off if the motor overheats you must keep teh dirt cup clean and empty and all the filters clean, when you empty the dirt cup if you have a lot of pet hair take the hose off and make sure that it is clean as well, and do not try to pick up any of those cleaning wipes that will stop it up real quick
Posted on Dec 30, 2008
Ther is no suction in the power tool hose . the soap is dispensed but no suction or at best a very very very faint suction
This sounds like a clogged Lint Filter. The filter (looks like a screen) is located on the Tank Cap. Remove it and clean and put it back. Don't run the unit without the filter. If that doesn't work then try the Flow Indicator Filter (Turn the Flow Indicator cap counter-clockwise to remove it, lift out the rotor and filter. Clean filter and reassemble in reverse order. You can contact Bissell Consumer Care at 1-800-237-7691 for a person to person contact if you need more assistance.
Sep 23, 2015 | Bissell Proheat Upright Carpet Cleaner...
My carpet cleaner wont stop leaking water after cleaning and i need keep vacumning up excess water
The unit works on suction and can develop a syphon if the filters get clogged. There's 2 filters that you should be cleaning after each use. One filter is located under the Flow Inidicator: Unscrew the Flow Indicator Cap to remove it. Lift out the rotor and the filter is under it. Lift out the filter and clean. Reinstall in reverese order. If that didn't help you may want to call Bissell Consumer Care at 1-800-237-7691 Hope that helps.
Dec 24, 2014 | Bissell ReadyClean DirtLifter Carpet...
My Bissel Lift-off Deep Cleaner is not taking up the water from the carpet
I try not to answer questions if I'm not positive of the answer, but I thought I'd give your question an educated guess... With a regular vacuum, if the filter is clogged, the vacuum looses suction. It makes sense, that if your Bissel is otherwise working fine... There's a good chance the filter is the problem. I hope I was of at least some help. Good luck and Merry Christmas, Bill
Dec 19, 2014 | Bissell Lift-Off Pet Deep Cleaner
High wine from my bissell lift-off
Hey, you may want to have your Lift-Off vacuum inspected by a qualified technician at one of our Authorized Service Centers.
Here's a link to locating one in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 10, 2013 | Bissell Vacuums
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
While vacuuming, the unit will stop/shut down. A short time later the unit will operate again but not for much longer. All filters are clean/new.
Check your hose for a clog. It's likely there is a plug somehwere. Run it (not while vacuming the carpet) with all three filters removed. See if you get good suction. If not then look around for a plug of dirt and hair somewhere.
Jul 24, 2010 | Bissell 3750 Lift Off Bagless Upright...
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
No suction on either vac or upholstery attachment...does spray
check to see if the red lint filter in the clean dirty water tank is clean and free from fluff if this is glogged this will resticted the suction ,check to see if the tank is seated corretly
May 24, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell carpet cleaner does not have suction like it should
Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch square) red plastic filter with a door on it. Flip open the door and it is probably clogged with hair, carpet fibre, etc.. Clean it out and you should have full suction once again.
Mar 16, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
967 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
