Question about EuroTech EWC177 Front Load Washer / Dryer
Clothes come out oily after wash
I have a Eurotech front loader. Lately we have observed that our cutton materials come out with oily spots after wash.
What can one use to address this problem
  • 750 Answers
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said,you have a Eurotech front loader. Lately you have observed that your cotton materials come out with oily spots after wash. What can one use to address this problem.
In most front loaders when this happens it is usually either of two things.
1.Front loaders must have HE detergent for their use and if you do not use HE detergent you must cut your detergent and bleach in half.
Because to much detergent destroys your seal and eventually your bearings! And any other rubber seals like the rubber door seal in the front opening.
These degrade and get into the wash and depending on the color of the rubber (Black or gray) are found to stain your clothing or leave a residue in those colors.!
Those washers with Grey rubber like Maytag's have gray stains and or residues!
I have people asking me about this problem every day!
Call the manufacturer and ask if they have any cleaner that you can run once with out clothes to put an end to this!
And then use HE detergent and or half the dose of bleach form now on!
I hope this brings some lihgt to your problem. Please let me know what the Eurotech proplr tell you to use to clean it out of your washer!
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
What is needing done to stop oily smears on clothing after being washed in beko washing machine
beko front loaders use sealed bearings ..
would suggest try doing several empty hot washes with a strong liquid detergent
and as a tester ..put in a white piece of material
check for oil sludge in the lint filter
if oil persists
have it looked at by a professional
May 27, 2016 | Beko Washing Machines
I have a Eurotech EWF150 frontload washer that does not spin. The drum will turn for rinse and wash cycle, but not spin. We checked the motorboard and there are 2 spots that appears burned. Hubby is trying...
I am not 100% sure your problem is the same as the one i had with my frigidare front loader but my door lock switch went bad. it would wash fine but when it came time to spin it only would tumble.
Jan 02, 2012 | EuroTech EWF150 Front Load Washer
My washing machine leaves little spots/dots of rust on my clothes...help?
if this is a top loader, there is a seal that seals your agator shaft from water going down and oily grease from comming up. if you remove your agitater and have excessive play in your shaft you may need seals
Sep 21, 2011 | Washing Machines
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
New LG2101 front loader drum noise
Try rotating the drum by hand and see if you can feel a 'hard spot' If your machine is new you should have a warranty. If so, ring the service line and ask a consultant about the noise. The may even be able to listen via the phone and advise you...Good luck .....Nomess
Apr 19, 2010 | LG WM2101HW 4.0 cu.ft. Washer
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
I have a Frigidaire front loader washing machine. If there are only a few lightweight pieces of clothes, the water will not spin out. Also some of my clothes have spots on them after washing. What do I do?
For the odor, you might try running a cycle with a strong bleach solution (no clothes!!!). Leave the door open when not in use to air out.
Certain Frigidaire models will not spin out if the door switch is damaged or is defective.
Unplug the machine first before doing this!!
You can access the switch by removing the top (remove two screws from the back of the panel). To remove the switch, remove the two screws from the front of the machine where the door latches. Locate the switch and observe how the wires plug into it. Replace with new switch.
Jun 04, 2009 | Frigidaire ATF6000ES Front Load Washer
Can you use Oxyclean along with detergent in front loaders?
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
Jul 26, 2008 | Frigidaire ATF6000ES Front Load Washer
Eurotech MA66 front loader user manual
Click on washing machines (below FIXYA )on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line. If available that is.
And rate me pl if helped............
Feb 08, 2008 | Washing Machines
EuroTech EWC177 Front Load Washer / Dryer Logo
272 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
