Question about Gateway GT5220 PC Desktop
Arrow is viberating & screen is not as large as it should be
Pointer or arrow is vibrating, screen has become to small
  • 781 Answers
What operating system are you working on
try to configure your resolution to correct the small screen
and the refresh rate for the pointer you see vibrating..
I would also check your mouse configuration.
Posted on Sep 29, 2008
Why does my curser keep moving to the top pf the screen and then willnot move for for a couple of minutes then work again for 20 secs and then move back to the side of the screen? please help
To resolve this problem, disable the SnapTo feature, and then download and install the updated pointer files from the Microsoft Download Center. To do this:
  1. Press CTRL+ESC to open the Start menu.
  2. Use the UP ARROW key to select Settings, press the RIGHT ARROW key to select Control Panel, and then press ENTER.
  3. Use the ARROW keys to select the Keyboard icon, and then press ENTER.
  4. Press SHIFT+TAB, press RIGHT ARROW, and then press RIGHT ARROW to select the Pointer Activity tab.
  5. Press TAB three times, and then press SPACE BAR to clear the Snap pointer to default button in dialog boxes check box.
  6. Press TAB twice, and then press ENTER.
  7. Close Control Panel.
  8. Download and install the 11p32upd.exe file from the Microsoft Download Center.
    NOTE: After you install the 11p32upd.exe file, you can use the Mouse tool in Control Panel to enable the SnapTo feature.
The following file is available for download from the Microsoft Download Center:
Collapse this imageExpand this image download.gif Download 11p32upd.exe now (http://download.microsoft.com/download/easyball10win/update/1/win98/en-us/11p32upd.exe) Click on this link if all else fails: http://support.microsoft.com/kb/175400
Mar 17, 2010 | Toshiba Tecra M1 PC Laptops
Compaq notebook laptop: my mouse pointer or arrow is
If you have a manual for the notebook, check to see if you can use the function key and the similarly coloured key on the keyboard which enables/disables the touch pad. Usually you can disable the mouse pointer touch pad with this FUNCTION key + MOUSE key when pressed together. Often these keys have the same colour (usually blue). The purpose is to disable the touch pad when you are using an external USB or wireless mouse, then you press the 2 keys again together to enable the touch pad once you have removed the USB/wireless mouse.
If that doesn't work, borrow a USB mouse and attach it to your notebook to use temporarily while you diagnose the problem.
Dec 19, 2009 | Acer Aspire 5100 Notebook
When my screen is flip over, my mouse arrow icon will stuck on the corner of the screen. as if my arrow icon is continuously clicking the corner.
explain the issue in detail pls,
can u move the mouse pointer using an external mouse connected to ur USB port ?
Dec 09, 2009 | HP Pavilion TX2000Z Notebook
Compass in 3 parts on the screen
This is normal! The compass looks like this in "course pointer" mode.
When you're looking at the described compass screen, press the lower left button and notice the line "bearing pointer". When you select that line and push the front joystick, you'll notice that the compass needle is "normal" again . And when you push the lower left button again, you'll see that the line has changed into "course pointer". Pushing the joystick again toggles between those two modes. The shifted needle indicates how far you drifted from the course that your route follows. See page 31 of the English manual for details.
Jean-Marc Bouyeure
Jun 20, 2009 | Garmin eTrex Vista HCx Handheld GPS...
Display is gone, only pointer arrow shows
Try tapping the F8 key just after you power your machine up to see if you can boot to safe mode.
Mar 18, 2009 | Gateway MT6707 Notebook PC
In touch sensitive mouse in Dell 6000, I have problem
Move the mouse pointer to the right down or up arrow at the right bottom or top of the screen and press the button.
Hope this helps.
Good Luck.
Jan 04, 2009 | Dell Inspiron 6000 Notebook
Garmin gps 60 scx the games
This is a little funny.
The reason the arrow doesn't move within the game is because *you* are not moving. You have to go outside and start walking around to make the arrow pointer move. These are GPS games and they are best played outside in a large area where you are free to walk around in most directions (like a football field). Start the game in the center of the field.
The Maze game is quite fun, and you'll get some good exercise. Move over Wii Fit! ;-)
Jun 30, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Touchpad not working
Using your keyboard, press the windows hot key, then use the arrow keys to go up and to the right to control panel, then arrow over to the system icon, then arrow through the tabs to the hardware tab, then press TAB to select the "device manager" button and click enter....in the device manager, press tab again in order to highlight the first selection and arrow down to "mouse and other pointing devices" then press the right arrow key to expand that selection and see if it is recognizing your mouse pad, if it does, highlight it and press enter, arrow over to the "driver" tab and try updating the driver, if that doesn't work, try a troubleshoot from the first properties tab.....and if none of this works......the touchpad is most likely dead. Try contacting the manufacturer and see if they can replace the touch pad.....
Jun 27, 2008 | Acer Aspire 5100 Notebook
How can i change my mouse cursor??(flower)to the normal pointer just the arrow one..
ok fallow these steps
clike start menu>settings>control panel>mouse>pointer>go to scheme and select none and apply changes.
your mouse cursor will become normal.
regards
gaurav rajput
Feb 12, 2008 | Computers & Internet
Gateway GT5220 PC Desktop Logo
42 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
