Question about Logitech 967233 Keyboard
Keys not working properly
I recently formated my hard drive and now; for some reason or other some of my keys arent responding properly.... Ive tried checking drivers and reinstalling my Control Center discand I cant figure it out! I go to type one thing and it types another! It worked fine before so Im almost ready to reformat which sucks cause this is the only unresolved issue I have.
Buy a new keyboard
Posted on Oct 01, 2008
How do i reload windos and format my drive i only have one hard drive and all my usual solutions arent working a virus appeared some how through hot mail or fb and if i boot from disk drive to reload win...
First go into BIOS SETUP and make sure that your CD drive is set to be your first boot device, and your hard drive is the 2nd boot device. To do this, start tapping on the DEL key as soon as you turn your PC on. (On some machines it's the F1, F2, or F10 key). Once you get into Setup, use the arrow keys to check the boot device menu and change it if necessary. Then save your settings and exit.
Hopefully tou have the system restore CD that was provided with your PC. If you do, put it in the CD drive and restart your system. The system will boot from the CD and you can choose the option to completely restore your PC and format your hard drive. (Of course, all data on the hard drive will be lost)
If you do not have the system restore CD you will have to insert your Windows CD instead. You will be given the option to format your hard drive. Format it and Windows will then be loaded onto your hard drive.
Once you are up and running again you will have to go to the MIcrosoft website http://www.microsoft.com/updates and download all high priority updates.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 18, 2011 | IBM ThinkCentre S50 8183 - P4 3 GHz...
We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this. If your computer stopped responding, restarted unexpectedly, or...
did you recently install a new hardware ?
did you recently install a new software?
if you answered yes to any of these questions above you need remove it.
therefore if you installed a new hardware safely shut down and remove cables and remove hardware.( if it is hardware the hardware is not compatible with windows)
if it a software boot in safe mood then uninstall software. ( to boot in safe mood, press F8 while computer in turned on )
Sep 27, 2010 | NEC VALUESTAR T (VT900/8D) PC Desktop
My maxtor external hard drive stop responding. How do I getit back? I've changed it from it's original USB slot. I have the Maxtor OneTouch II, 100GB, 8MB CACHE, 7200 RPM
Usually Matox is very fragile, it responds to any little error. Does it make any funny sound inside it?
Check the usb wire if it is ok, or you leave it for a while and try it later to see if it responds.
Plug it to your system using an IDE cable, go to your computer setup to see if your system recognizes it. If it does not then try setting the jumper at the back of the hard disk. But if your system recognizes it, use a start up to format it and monitor the formatting if it shows "recovering allocation unit" if it does, it means the hard disk has Bad sector(s) which might be the reason why it is not responding. So you will have to partition it and use the part of the hard disk that does not have bad sector.
What usually cause an hard-disk to have a bad sector is:
  1. When a system is not shut down properly
  2. When power goes off the system unexpectedly
  3. When you remove from the usb without ejecting or safely removing first. (That is while using it as an external drive). and so on.....
I wish you the best.
Nov 10, 2009 | Maxtor Hard Drive
Keys arent functioning properly
Reset RAM . If keys are not working properly, calculator is of no use to you. You should have it repaired.
Hope it helps.
Sep 12, 2009 | Texas Instruments TI-84 Plus Silver...
Ok, my laptops keyboard is going weird
The keyboard is retiring. The keyboards are not terribly expensive. You can obtain one from your local agent and replace it or have it replaced by them
Jul 06, 2009 | Computers & Internet
Hanging problem
hi
there are a couple of reasons why your phone might be hanging
1. some software that might a problem
2. memory card problem
3. if u have recently changed the cover and/ or keypad which might not be fitting in properly
well of all things try a soft reset by dialing (*#7780#)
>>beware to loose all data on the phone with the following step so backup before u do so
the hard reset (phone format)
hold the three buttons Green&3&* and power button
hold the keys till a display FORMATTING appears on the screen
u will loose all data on the phone
cheers hope i helped
Jun 23, 2009 | Nokia 3230
Keys not working
The following table shows the possible reasons for performing a hard reset on a BlackBerry device Keypad is not functioning correctly. For example, keys do not work, the trackwheel is not functioning correctly, or the handheld does not turn on. Handheld display is hard to read. For example, the display shows lines obscuring text. To perform a hard reset on BlackBerry smartphones
  1. Remove the battery cover.
  2. Remove and reinsert the BlackBerry battery to reset the BlackBerry smartphone.
  3. Replace the battery cover.
Sep 22, 2008 | RIM BlackBerry Pearl 8100
Connection problems
Your drive is most likely either secured or formatted for Mac. Try installing the Mac format driver on your Dell and see if it can recognize the drive afterward.
Download and install Macdisk from the below link and see if it works, let us know if it doesn't.
http://download.cnet.com/MacDisk/3000-2248_4-10061804.html
Hope this helps FixYa,
Chris
Sep 14, 2008 | LaCie (301015) 120 GB Hard Drive
G15 key board
There is nothing wrong wuth the installation method only the key connection with the Printed circuit boards are not proper
Jan 23, 2008 | Computers & Internet
`Caps Lock` Key not working
It's likely that the key is simply broken and usually you need to replace the whole keyboard as it's hard to find just one or two keys for replacement. If it's under warranty, it would of course be better for you to just send it in for repair. The issue is almost definitely not a software issue.
Jan 05, 2008 | Acer Aspire 2023wlmi PC Notebook
Logitech 967233 Keyboard Logo
100 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
