Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Out of range, buttons don't respond, battery won't hold charge
Bought phones(expandable 5 handset) earlier this year. New problems appear every month or so.
1. Similar to others, phone just suddenly loses signal and says it's out of range and searching no matter how close to the base it is. No major appliances nearby.
2. Two of the phones middle button that lets you scroll through the caller id listings or phone book are not functioning.
3. One phone won't hold a charge longer than an hour, despite being on the base all day and night and not in use every day. Don't look forward to buying a new battery for $20+
Tried resetting by unplugging battery and phone jack for 30 minutes. Tried 'cleaning' contacts where phone charges with eraser.
Like others, I didn't keep the recipt as I had great success with Uniden years ago. Should have went with another Panasonic and prob will soon rather that put money into this sinking ship.
  • wmgilbert Nov 25, 2008
    I don't have out of range or battery problems but the caller ID/phone book/scroll button on all three handsets stopped functioning within weeks of each other. I took the handset apart and checked the circuit board. I can jumper across the PCB contacts and make the phone scroll up and down, but the conductive discs on the rubber mat will not trigger any of the buttons.
  • Anonymous Nov 25, 2008
    All three Uniden Dect 6.0 phones read 'Out of Range' but they have been plugged in to their bases continuously.
    New problem for me.
    What is the 'fix'?
    Top Expert:
  • Uniden Master
  • 48,272 Answers
When you have a problem with anything under warranty, you take it back for new units or a refund and anything under 12 months old is under warranty
if you have lost the receipts get a copy of your bank statements as that shows where it was bought , how much it cost and when
That is a legal document to trigger a warranty action or refund
Posted on Mar 10, 2017
4 Suggested Answers
  • 201 Answers
SOURCE: base phone handset #1 holding charge
The base unit should not need a charge. It should be powered by the plug in adapter. It may have a battery to keep operation for a short time in a power outage. The adapter may be loose, the adapter could be broken or the plug in the phone may be broken.
Posted on Jul 07, 2007
SOURCE: UNIDEN Powermax5.8 cordless phone charging
Mine came with Nickel-Metal Hydrides. You can find them on the web.
Posted on Nov 08, 2008
SOURCE: On 2 of the 4 handsets on my Uniden DECT 2080, the
After having the same trouble with my DCX200 and not finding a solution online for the problem, I set out to find a solution of my own. The fix I describe below is probably more of a band-aid than permanent fix but it appears to be working great. The problem, I believe, is caused by the metallic compound that the manufacturer used on the push button contacts in this model of phones and more specifically with the large multi-function button. This compound appears to wear off quite easily with repeated use of the keypad. Along with this I think that the design of the multi-function button did not take into consideration the environment in which it would be used. Not everyone washes their hands and face before using a phone (does anyone?) and between grease, make-up and natural oils of the skin building up and eventually making their way down into the components, this may be a contributor to why these buttons are so susceptible to failure.
_889.jpg What you will need:
1) Small Phillips head screw driver.
2) Small flat head screw driver (not shown).
3) Goo-Gone, Isopropyl Alcohol or some other degreaser/cleaner.
4) Hole punch, preferably smaller than a "standard" hole punch. I found the one I used in my wife's craft supplies.
5) Cotton swabs.
6) Metallic or foil tape. Can be found at any home improvement or hardware store.
Step 1. Remove battery and two screws circled in red with your small Phillips head screw driver.
Step 2. Pry off the dark grey back of the phone case with your flat head screw driver. I found that starting at the base of the phone and working around the sides was easiest.
Step 3. Being mindful the the wires that attach to speaker take the dark grey back off of the phone. Next remove the screw circled in red below:
Removing this screw will allow you to remove the circuit board from the front face of the phone to expose the numeric keypad as shown below. There is a thin white plastic keypad component that will either remain affixed to the keypad or the circuit board when you remove the circuit board from the front face of the phone. Be sure not to damage that.
Take the white plastic sheet and affix it to the circuit board side (if not already on it), with the small black button contact points facing down onto the circuit board as shown below:
Now soak one side of your cotton swab in your Goo-Gone or Alcohol solution and clean both the four small black push button contacts of the large multi-function button on the back side of the keypad and also the contact points on the circuit board. Then take the dry side of the cotton swab and remove any excess cleaner on the button contacts and the contact points. This step is critical. This cleans the surfaces and makes the push button contacts on the back side of the keypad ready to receive the foil tape.
Pictured below is the cleaning of the push button contacts of the multi-function button on the back side of the keypad:
Also clean the contact points on the circuit board using the white plastic sheet as a guide to where to clean. Don't forget to use the dry side of the swab to remove any excess cleaner:
Now the part that requires of bit of dexterity. Using your hole punch punch out four pieces of the foil tape. If you do not have a hole punch or are using a "standard" sized hole punch, you will want to try and use a scissors to cut out a small piece of foil tape that will fit over the black push button contacts of the multi-function key on the back side of the keypad:
Harvest the small circles of foil tape that the hole punch punched out of the foil tape.
You can see a couple of them on my finger below:
Now using your finger nail, gently remove the foil tape backing on these small circles. Yes, this can be a bit tricky, but I found it to be easier than I expected. With the backing off of the foil tape, affix your small foil circle onto the push button contacts of the multi-function button on backside of the keypad as shown below. Do not affix these to the circuit board contacts:
Do this for all four contacts of the multi-function button on the keypad. The picture below shows the finished repair to the push button contacts. I also placed the white plastic film component onto the keypad side to underscore the fact that you place the foil onto the keypad and NOT the circuit board:
Now place the circuit board back onto the front side of the phone (silver side) and fasten down with the screw you took out in step 3 above.
Affix the dark grey back of the phone onto the front side. There is a small plastic tongue at the top of the dark grey back that fits into a groove on the top of the front silver side of the phone. Get that tongue into place first then the rest of the back will snap into place.
After the back has been snapped back onto the front of the phone, fasten it down with the two screws you took out in step 1 in the battery compartment.
Put the battery back in, wait for the phone to turn on and try the keypad out. Below, you can see that I am checking the caller ID side of the mult-function button:
This fix appears to work quite well. I don't know how long the repair will last but it would be easy enough to do again if needed.
Posted on Mar 06, 2011
Why do my VTech phones says outer range or no base on both of my phones
Out of range OR No power at base is shown in the handset ...
VTech Communications Inc.Out of range OR No power at base is shown in the handset display window. Why don't ... Tip 1 of 5. Confirm proper installation of the telephone base and charger power adapters, and handset battery. You should only use the VTech power adapters provided with your telephone. ... Next Tip This solved my problem. Tip 2 of 5.
FAQs - VTech Communications
VTech Communications Inc.Have a question about VTech cordless phones? Visit our ... How do I find my model number ... My battery pack does not last very long between charges.
VTech CS6429-4 DECT 6.0 Expandable Cordless Phone ...
Jan 08, 2016 | Vtech Lands Phones
Uniden xdect 7015 won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Jul 28, 2012 | Uniden DECT 6.0 Cordless Telephone...
I have Uniden DECT1480-3. I purchased two expandable handsets, but I cannot figure out how to get the new handsets to register with the base unit.
Up to 6 handsets can be registered with the DECT 1480 phones. I have the 5 phone unit and needed to add the 6th phone. All I got was "Searching" in the display and the battery wouldn't even charge!
So here's what you have to do to get additional phones (up to 6 units) to work with the base. If you can get past step 1, it's a snap...
Step 1: Place a charged battery in the handset. This could be a problem if all your handsets are not registered, since unregistered phones don't charge (who thought of that design?). What I did was SWAP the battery from an already registered and charged phone with the new unregistered phone.
Step 2: Here's where the magic happens. Press the 'END' and '#' keys simultaneously... hold them down until a System Reset menu appears. Select "Deregister HS" and press Menu.
Step 3: Now, do the same thing again (hold down END and #), but this time select Base Unavailable and press Menu. You will see Base Unavailable Yes/No... Select Yes. Then place the handset in the base, wait a few seconds, and Voila!. it's registered. You can even change handset numbers using this menu if you play around with it.
Thank you, helpful employee at Costco for supplying the magic code. And hey there, UNIDEN... including this in the operation manual would have saved many customers much grief with de-registered phones!
May 14, 2011 | Uniden DECT 6.0 Cordless Telephone...
My phone is display out of range
  1. hi..
  2. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
Jan 03, 2011 | Uniden Cordless Phone
My uniden phone says - out of range
Uniden wxi477 out of range fix
This problem arises when the handset does not communicate with the base.
These are the steps:
1: Deregistering the handset
2: Registering the handset to base
Deregestering clears the stored (incorrect) base information on the handset.
Reregestering allows the base to assign a new ID for the handset.
Deregistering- press and hold the OFF (red button) and the # button on the handset for 5 seconds. select base unavailable and press OK. Are you sure appears. select yes and press OK. you will hear a confirmation tone. The handset will delete its own base information without trying to contact the base. It will now display MODELS VARY PLACE HANDSET ON THE BASE FOR REGISTRATION.
Registering the handset with the base- Make sure the tel. line and power is plugged into the base.
Press an hold the register button under the base (located between the tel. line and yellow power socket under the base) for 5 seconds until the red light flashes. At the same time press and hold the # button on the handset for 5 secs. You will hear a tone and It will now display REGISTRATION COMPLETE.
If it says registration failed: Retry the registration steps. Make sure the handset have enough battery power. If not charge for 15-20 hrs.
Check your connections on the base and make it is getting power.
The Steps above was my fix for the uniden wxi477 out of range problem.
Good luck.
May 25, 2010 | Uniden TRU9585 Cordless Phone
Problem with my Panasonic phone cordless handset.
Wow, that's a great record for any cordless phone! The battery probably only needs to be replaced. The battery can no longer hold a charge.
Apr 18, 2009 | Lands Phones
Phone keeps dropping calls
Same issue here. Have you checked the battery? I found out that on mine the battery was leaking and corroding the contacts. Need to call Panasonic to find out if they can do something (about 5 month old phone)
Apr 02, 2009 | Panasonic KX-TG9333T Trio Cordless Phone
Phone holds charge from 12-55 min. and then goes dead
Your handset or charger has gone bad (provided you installed rechargable batteries), or both. The previous user may have installed alkaline batteries (is their a white powdery residue in the the charge compartment?), and that can ruin the charge circuit. Either way, you probably need to contact repair. You can go to
May 23, 2008 | Siemens Gigaset 4000 Phone
Motorola MD400
Take battery out of handset for one minute.
Unplug base unit (power and phone line) for one minute.
Plug base unit back in (power and phone line).
Put battery back in handset. Place hangset on base for
one minute. This got my phone up and running.
I had no battery power in the base unit, but if I did, I think
you have to remove those as well.
Apr 17, 2008 | Motorola Mobility MD41 Expandable Handset...
Just bought an additional handset for GE 27951 expandable 6.0 DECT Cordless. I press and hold the Page button for 5 seconds but the new handset will not register. Error keeps occurring "no base."
This exact thing happened to me. Same model number. No matter what I did, the new handsets would not register.
The solution? Reset the entire system:
1. On the BASE - Unplug from wall both power and phone line. Unplug battery from base handset.
2. ON the Extension phone - unplug from wall and unplug battery from handset.
3. Wait AT LEAST 5 minutes.
4. Plug back in BASE power.
5. Plug back in BASE phone line.
6. Plug back in EXTENSION handset battery. Don't plug in BASE handset yet.
7. Follow steps to program EXTENSION. When successful:
8. Plug back in BASE handset battery.
Apr 02, 2008 | Lands Phones
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
980 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
