Question about HP Office Equipment & Supplies
HELPPPPPPPPPPPPPPPPPPP! PLEEEEEEEEEZE! i HAVE AN HP OFFICEJET 6100 THAT JUST WON'T WORK ALL OF A SUDDEN! DAMN!!!!! When I turn it on it makes noise like a thumpity-thump and the screen reads, "Press enter to align cartridges" which I do to no avail! I've tried opening it and aligning it too. No luck! Can you, will you help me please? It has been doing this for weeks (literally) but now I really have something I desperately need to PRINT! THANX for any help you can give me. Truly! Lisa
    Novelist:
  • 169 Answers
Generally, when an HP printer continues the old "alignment" trick, but never seems to want to actually continue past that, it's done for. Considering the noises that you're hearing, I'd guess something internal has either gotten stuck (and the write head is butting up against it), or there is a mechanical failure.
My suggestion (after owning nothing but HP printers) ...put your file on a flash drive or CD/DVD, and take to a friend's house to print (or to a local Kinko's), then go shopping tomorow for a replacement printer. The cost to repair it will far outweigh just buying a new one.
Good luck - hope this helped!
Posted on Sep 29, 2008
Won,t power up
This will not be user serviceable. Either take it to a repair shop or replace it.
Jul 17, 2015 | HP Officejet 6100 Eprinter - H611a 1 Year...
HP Officejet 6110 - Scanning Error. Cannot connect to PC
Uninstall and Reinstall the software
1 On the Windows taskbar, click Start, choose Programs or All Programs
(XP), choose Hewlett-Packard, choose hp officejet 6100 series, then
choose HP Uninstaller.
2 Follow the directions on the screen.
3 If you are asked whether you would like to remove shared files, click No.
4 After the program finishes removing the software, disconnect your
HP OfficeJet, and restart your computer.
5.Do not reconnect the Officejet now
6 To reinstall the software, insert the HP OfficeJet 6100 Series CD-ROM into
your computer’s CD-ROM drive, and follow the instructions that appear.
7.After the software is installed reconnect the usb cable and allow the
computer to detect and install the software
If this doesnt work then get back to me
Nov 27, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Why will my hp officejet 6100 turn on it keeps blowing main fuses from mains plug
Short circuited component/s at it main power regulator board. Your printer needs service. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 17, 2015 | HP Hewlett-Packard - CB863AB1 Officejet...
How to turn on wi fi on hp 6100
here is a link of the manual on how to set up your wifi on the hp 6100 very easy to read
http://h10032.www1.hp.com/ctg/Manual/c03246247.pdf
Oct 12, 2014 | HP Hewlett-Packard - CB863AB1 Officejet...
Not printing
When printing from the microsoft word document, make sure the printer selected is right. By that, i mean the default printer selected in the printers icon under the control panel should be HP OfficeJet 6100 series and not HP OfficeJet 6100 fax.
So the reason why this message comes up " scanner failure ". is you are either selecting a wrong printer when printing from microsoft word document or probably the printer port is not selected right.
To check the printer port.
Click on start-->control panel-->printer & faxes-->right click on HP OfficeJet 6100 series--> select properties-->Select the top tab called ports-->
Check the ports selected here.
If you have a USB connected printer it should be your printer model with USB settings.
If you have a wireless connected printer it should be your printer model with wireless settings like IP address.
Apr 29, 2010 | HP OfficeJet 6110 All-In-One InkJet...
6110 officejet, power light blinks. display says "warming up" continuously?
Pls run the attached file to resolve the issue.
Description:
These all-in-one product firmware updates will resolve issues with receiving faxes, warming-up, certain printing issues and memory full messages with the HP OfficeJet 6100 series products.
Warming-up - Under certain circumstances when the all-in-one will display "warming up" indefinitely after pressing one of the "Copy" or "Scan" buttons
After downloading and installing this firmware update, the software will determine if the hp all-in-one would benefit from this firmware update and inform you of the results.
Installation Instructions :
Download the file "HpAiOFWUpdate2_2.exe" via http://www.printer-drivers.com/drivers/246/246484.htm to a local hard drive. Make note where (in which folder) the file gets copied.
The hp all-in-one software for the OfficeJet 6100 series must be installed on your PC before installing this firmware update. The OfficeJet 6100 series must also be connected to your PC and turned on before proceeding.
Locate the file "HpAiOFWUpdate2_2.exe" on your hard drive and double-click the file to install the firmware update.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Sep 15, 2009 | HP Office Equipment & Supplies
Officejet J5780 Every time I turn printer on I get error reading to align cartridge. Tried several cart. and get same reading
One "reset the printer" solution says:
1. unplug power cord
2. wait 30 seconds
3. hold down "#" key AND "6" key, plug in power cord and turn on
this theoretically should clear it. i had a similar problem with an HP 6100 multifunction, and the "reset" steps with that were similar (different keys) and worked.
Jul 18, 2009 | HP Officejet J5780 All-In-One InkJet...
I tried to install hp officejet 6100 series cd for my computer window Vista but it won't work. What shall I do?
Hi debprince45, there is no need for you to buy the CD. You can download it for free from HP. Click on the link below;
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=238398
Make sure your HP 6100 is connected to the computer & power for the printer is connected. Power on the printer. Click on the link;
Automatically check to see if you have the latest software and drivers
Follow the on screen instructions. You'll need to allow HP to check your system. HP will scan your system & download & install the most up to date software for your HP printer automatically.
Good luck debprince45!
Run into trouble, just post here.
Thank you for using fixya.
Merry xMiss!
Mike
Dec 16, 2008 | HP OfficeJet 6110 All-In-One InkJet...
112 people viewed this question
Seeker5211
Seeker5211
