Question about Maytag Neptune MAH5500B Front Load Washer
Maytag MAH21pddww door locked
Display shows 1 minute to complete cycle but washer is not doing anything and door locked tried switching off and on still no joy -
can you reset washer to unlock door ?
Regards
Chris
  • 943 Answers
Hi thanks for the question to unlock the dor manually open the soap door look to the right top inside its a small piece of string pull on it. that should unlock the door thanks the appliance doc
Posted on Oct 01, 2008
I have a maytag model mah21pddww it shows 20 minutes all the time on the display but will not start..
Hello James;
My name is Peter. I am a retired field service appliance technician.
Your problem could be any number of things. You may have something very simple, a bad push button, bad door switch ...
I do not think you have a bad control board. Your control board is waiting for a signal or the closure of a circuit.
I work on the side. I charge $25.00 for diagnostics and $25.00 for the work plus parts.
Call me.
Peter Goodwin
Glen Burnie, MD
443-306-1362
Mar 19, 2015 | Maytag Washing Machines
My oven door will not shut, i have a code of F9 showing
it MAY be your oven door lock is jammed..
I found this information for you:
  • Wait at least one hour after the oven has completed a self clean cycle to attempt to open the oven door, as the oven remains locked until the interior temperature has cooled sufficiently.
  • 2
    Press "Cancel" and wait a few minutes if the oven is cool and wait until at least one hour has elapsed since the completion of a self-clean cycle.
  • 3
    Open the oven door and check the door lock switch. Move the switch back and forth with your fingers to return the switch to the original position. Check for dirt or debris that may be causing the switch to stick or lock and clean as necessary.
  • 4
    Contact an authorized service technician if the problem is not resolved, as the door switch may need to be replaced.
  • Perhaps you can get some advice from Maytag
    Call the dealer from whom your appliance was purchased or call Maytag Appliances Sales Company, Maytag Customer Assistance at 1-800-688-9900
    Sep 12, 2011 | Maytag MGR5870 Gas Kitchen Range
    My machine is showing the code FL machine has problems locking. How do I resolve this problem
    Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
    The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
    Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
    1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
    3.Replace responsible component.
    Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
    Washer won't start, stopped at beginning of cycle and the door lock flashed. after about 5-6 flashes the display read: FL. Tryed to start again, unplugged it for a while several times. nothing happens....
    FL:
    Failed to lock.
    Trigger:
    Action to be taken:
    If you need to open the door.
    Maytag's Neptune washer has a latch and lock on the door. If this lock fails to open when the cycle is finished. You can rescue your clothes by:
    1) Remove the bezel from the soap/bleach/fabric softener dispenser.
    neptopbezel.jpg 2) Locate the red cord near the right front corner of the dispenser opening. Pull on this red cord. This will unlatch the door so you can rescue your laundry. Then call for service.
    Best of luck, Any questions just ask
    Nov 26, 2009 | Maytag Washing Machines
    Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
    Please see the following Whirlpool / Maytag service manual for Neptune washers.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
    On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
    "Shuts OFF In The Middle Of The Spin Cycle:
    During the spin cycle, the machine control
    monitors the door lock mechanism to ensure
    the door is locked. This is done through the
    door lock enable switch. During "lock mode,"
    the shaft of the door lock mechanism is
    pressed forward by the door lock wax motor,
    and the shaft presses in the button of the door
    lock enable switch. If the machine control
    board sees the switch OPEN during the spin
    cycle, the machine control board will automatically
    shut the washer OFF. This is caused
    by a weak spring in the door lock wax motor.
    Replace the complete door lock mechanism.
    Oct 25, 2009 | Washing Machines
    Can't interrupt the washing cycle on coin operated Mah21pddww
    Unplug the washer, wait three minutes for the door to unlock then do what you need and plug it back in. Should still have the time left on it that was there when you unplugged it.
    Aug 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
    My Whirlpool Duet washer showed F22 error; we followed manual instructions; disconnecting power, etc. but door remains locked and washing cycle won't restart. Help!
    If Pause/Cancel does not work:
    1. Unplug the washer or disconnect the power for one minute.
    2. Plug in the washer or reconnect the power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
    Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washer won't run through a complete cycle-stops at 29 minutes
    There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
    Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
    Maytag Neptune MAH5500B Front Load Washer Logo
    544 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
