Question about GE WBSR3140DW Top Load Washer
GE WASHING MACHINE MODEL WBSE3120B1WW Spin Cycle too SLOW
Was washing towels this morning, washer was off balance.. I removed all towels and rebalanced, when spin cycle restarted it never went into high speed and I noticed a burn smell (electrical) I unloaded machine to see if it would go into high speed unloaded.. will not
fanny
  • 146 Answers
SOURCE: Washer out of balance ALL THE TIME...
Remove front panel and check the springs that hold the bowl down onto the base. One of them may be broken or detached. On the base, the bowl assembly fits into a plastic collar. This collar may be worn, causing the machine to go out of balance. My guess is that the collar is worn or broken. You should be able to see plastic "dust" or pices on the base or the floor under the machine.
Posted on Nov 09, 2007
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 02, 2009
  • 151 Answers
SOURCE: GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
Posted on May 03, 2009
SOURCE: Burn Smell (electrical) from my GE WPSE4200A0WW
We have the same problem, and found out the the electric motor is running very hot. Replacing the motor seam to cure the problem, but the motor is not inexpensive. $200 to $350.
Posted on Aug 01, 2009
hiltonjug
  • 612 Answers
SOURCE: GE washing machine leaks at bottom
If this machine has a place to put pour fabric softener in that's sits under the lid on the cabinet? If so, the hose that allows the softener drain into the tub is either leaking or is disconnected.
Please rate this solution if helpful
Posted on Aug 21, 2009
G.E. WBSE3120B1WW Top Loading WASHING MACHINE
Pull the back off and see where this stuff came from, it is my guess the transmission is gone to lunch.
Sep 20, 2016 | Washing Machines
Will not spin the clothes dry it's seem it is not balanced ?
You may have One wet heavy item (one sweatshirt or one bath towel) that is not evenly dispersed within the wash tub, and this will prevent the machine from reaching and completing the spin cycle.
Jul 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Anytime this machine goes into a spin cycle it is grossly out of balance. we have tried adjusting the load; reducing the size of the load; we have gone to just one towel in the washer and still out of...
Are the locking nuts tight on all 4 legs? If not, tighten all locking nuts after leveling machine. Also, place a glass of water about 18" in front of machine while spinning and see if water moves. If it does, you may have flooring issues.
Sep 11, 2010 | GE Energy Star WCVH6260F Front Load Washer
GE Front load washer spinning too slow????
A couple of things come to mind,if the micro-processor senses the load is out of balance enough, it will control the RPMs(reveloutions per minute) or slow it down in order to avoid damage to the suspension system, so readjusting the spin speed manuallly probably would help. Although that machine should be able to handle 9 large towels easily! Next thing, have you cleaned out the trap inside the lower access panel, if it is restricted you will have draining problems. Good luck !
Jan 07, 2010 | Kenmore 22422 Top Load Washer
Water in clothes after spin cycle
need to open washer and check the DRAIN MOTOR PUMP , usually gets clogged with lint and debris , usually located at the bottom side , small motor w/ propeller ,where the drain hose is connected, AJ
Nov 11, 2009 | GE WJRR4170E Top Load Washer
Wont fill or spin runs dry
Check the water pressure switch for proper operation
Oct 19, 2009 | GE WBSE3120B Top Load Washer
Bosch Nexxt 800 washer won't drain clothes fully
There is not a Spin Only Cycle BUT there is a REFRESH cycle that will take about 10 minutes.
Sometimes when the load is unbalanced and the machine can not balance the load by itself, the clothes will remain soaked. To avoid this, make sure you always have a balance of small and large things and when loading your machine, do not shove the items in so they ball up.
Dec 27, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
GE model WCVH6800JMS front load washer spin cycle
My washer is 1 1/2 years old and I have the same problem.
Nov 11, 2008 | GE WBVH6240F Front Load Washer
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
Washer turns slow loaded or not
front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
May 11, 2008 | GE WBVH6240F Front Load Washer
GE WBSR3140DW Top Load Washer Logo
287 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
