Question about Dryers
Dryer wont come on may be wired up wrong. - Dryers
    Sergeant:
  • 409 Answers
it may be wired right, the problem may be with something electronic. can you tell me the model # please?
thanks
Posted on Sep 29, 2008
Changed top thermostat 11060832990 and now pops breaker
Sounds like incorrect wiring, like you have a "hot" wire going to the chassis somewhere. I'd double/triple check the connections. If you only pulled off the 2 thermostat wires, and reconnected them directly back, then it's unlikely that's the problem, but if you disconnected the thermal fuse or other connectors along the way, it sounds like something is hooked back up wrong. Good luck!
Dec 04, 2013 | Kenmore Dryers
I wired my timer switch wrong i need to know which colors go where
The fuse is located on the heater housing we4x800 is the part number on most of these. Look closely at the wires on the timer each one has a letter on it the letters on the wire matches the terminal markings.
Dec 27, 2012 | GE DBXR463EDWW Electric Dryer
I started my dryer for 10 minutes. opened the door, put another load in to dry and my dryer does not work now. what is wrong?
might be the door switch or a wire in the front panel or some other things, here is a website that may help, Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 24, 2010 | Roper REX4634KQ Electric Dryer
My dryer wont start at all...
Did you check the door switch. If it is open (not making contact) the machine will not run. Could be the motor start/run switch which could be stuck with lint (clean it) or worn out ( replace the motor).
Sep 18, 2009 | GE DSXH47GGWW Dryer
Changed high temp thermostats, maybe hooked wires back up wrong?
you should have a wiring schematic diagram somewhere on the machine otherwise the limit switches are normally wired in series w/element
Aug 15, 2009 | GE DVLR223 Dryers
Just hooked up outlet. Dryer tumbles, wont heat. Have I wired the outlet wrong?
Hi, Did you put red and black wire to the outer posts? White wire ti center and green to ground screw on cabinet? Dry will run on 120V but needs 240V for heat. Make sure there is 240V to the outlet as well.
Hope this helps. If so, please feel free to rate my answer so that I know how I am doing.
Vic
May 10, 2009 | Dryers
Changed from 3 prong to 4 prong wont run
You wired the plug wrong so that you just shorted out the dryer with 220 volts going where the ground should have been.
Unless you supply more details, as to how you wired the prongs, can't be more specific, but before you even try to use the receptacle to the house wiring, you should get a certified electrician to look at it or you could burn down your house, which is a bit more damage than your fried dryer.
Sorry for the bad news, but the Good News is that you are still alive.
May 09, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My ge dryer wont start
Hi thanks for the question. You could have a problem with the door switch, On that dryer theres a belt break switch.check that
Dec 16, 2008 | GE DWXR483EBCC Electric Dryer
Ge electric dryer light blew out and now the dryer wont turn on
Apparently you had a short on the case. I'd look at that cord again. 3-wire is Black on right, Red on left, Green in center.
Mar 26, 2008 | Dryers
Dryers Logo
Top Dryers Experts
