Question about RCA D52W19 52" Rear Projection Television
TV rca hd 52w59 has convex picture. can I fix it.
Tv has convex picture. colors are mis aligned. tried auto convergence. it did not solve problem. Can you walk me thru a fix for this problem?
  • terryperry Sep 29, 2008
    What if I purchase a new board with ic's installed. would that save money
    please tell me the paet numbers that i need. thank you
    Genius:
  • 1,030 Answers
The d52w59 does not have convergence ics. it does have a convergence amp board. ok lets se if i can talk you through some of it. the bowing picture indicates you have loset complete or all convergence power. lets start first asking a few question. in your customer menu under setup does the unit have the convevergence. i think you said you tried this. if you do and did try to autoconverge. the next question during the autoconvergence what happen normal autoconvergence starts in the top left corner with a red block ang goes clockwise with blocks. red, green blue fast then red green blue slow...where did it fail. the first block of red. if this failed at the begining it might be convegence amp board... NExt question if you have convegence option did you try eather red or blue convegence. this give you a red or blue cross.. and does the arrows move them up and down left or right. if you get no movement at all. then you have a bad convegence power board. this board is becomeing harder to get. if you get any movement at all then possibley convergence amp board. so check out thes question and let me know and let see if we can get this going. you might be able to repair these boards i have to AT THE SHOP
Posted on Sep 29, 2008
  • Willie Howell Sep 29, 2008
    theres three possible cuircit boards that can cause this problem. form you descriptions so far the most likely will be what is called the convegence power, board other boards can be small signal board or the convergence amp board. i fix 10 of theses sets a week at the shop most time it will be the convergence power board if not the fl231 problem
    to identify these boards i will need to know what is known as family number on the label with the model number there should be another model number with extra letter like d52w19yx1 or d52w19yx38 like that these are important to locate the correct part number
  • 4,472 Answers
Buying the whole board will save you time and money. If you need help locating parts or professional repair service please let me know. If you have a moment please take a second to accept and rate this solution accordingly.
Thanks,
Lee
    Scholar:
  • 148 Answers
If convergence adjustment did not correct the problem likely the convergence IC's have failed and will need to be replaced along with a few defective resistors in that circuit. If you have never attempted TV repair this would not be a good repair to start on.
The only way to be positive of the problem is to have the circuitry diagnosed by someone with the proper TV test EQUIPMENT to determine what parts that are no longer within specs.
KEEP ME UPDATED..
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Sep 29, 2008
    yes... if you purchased you will less the fee for the labor.
MY TV I CAN SEE THREE IN ONE
Tv have a problems known as a convergence picture problems,it is dead.Tv have problems like any colors lines R,G,B mis alignments,tv have like colors shadows pictures or a 3D pictures look alike?Yes,than the tv convergence board it is dead to causes these problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 29, 2011 | RCA R56WH76 Projection Television
Showing irregular colors are red green and yellow and doubles
Tv have a problems known as a picture convergence problems,it is dead.Tv have colors R,G,B lines are mis alignments in pictures,have colors shadows pictures or 3D picture look alike?Yes,than the tv convergence board it dead,tv must require replacement on the tv convergence board like 2 STK conconvergence ICS and some or all of it resistors too,to fixed the tv convergence board to solved tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Jul 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
We had our tv in storage for a year and a half, now we plugged it in and it seems blurry and has a green tint to in.
Tries tv auto or manual convergence adjustment,see if that solved this problems.If still have the same problems.That mean ur tv have a dead convergence board.Tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead,must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost like $300-$350 for parts and labors.
Feb 14, 2011 | LG RU-60SZ30 60" Rear Projection...
There is a blue shadow (especially around on screen graphics, lettering etc.) when in HD mode. I attempted to align the colors through the color convergence but the blue alignment did not work. I also...
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
How do i fix a color alignment problem?
Tries push the button said FLASH FOCUS or manual + - convergence alignment adjustment?Yes,n o,used?The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?The tv have a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too on the convergence board,must replaced these parts to fix it.To solved tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 27, 2011 | Hitachi 46F500 46" Rear Projection...
My RCA Model number HD52W59 has color distortion and double image and sunk picture in the middle. Is there any way of fixing this problem. This tv is a projection TV
Yes.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be change to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 08, 2010 | RCA HD52W58 52" TV
Ihave a toshiba 43 inch hd 2002 rear projection the picture has shiffited to the right can I fix this
This tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows picture or 3D picture? The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,require changing to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 16, 2010 | Toshiba 51H84 51" Rear Projection...
Wavy color separation, auto focus doesn't fix problem. Doesn't have a manual focus.
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board it have dead 2 STK convergence ICS and some or all it resistors.These parts,must be replaced on the tv convergence board to solved tv picture convergence.
Oct 11, 2010 | Sony KP-57WS500 57" Rear Projection...
I have a 52" RCA HD. I turned it on and for a few minutes it played great. Now the screen appears warped on the top and bottom.
This is a 52" RCA DLP projection tv correct?Yes,than a problems,u have is known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have colors shadow pictures or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 14, 2010 | RCA Televison & Video
RCA D52W19 52" Rear Projection Television Logo
181 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
