Question about Cell Phones
Dropped 3-G I phone in water - Cell Phones
    Problem Solver:
  • 7 Answers
I've seen this done a couple of times... by my brother in law, and my cousin. Take the battery out. Then, take a hair dryer and hold it pretty close to the phone and dry it out from every angle. Make the air flow into every crevice ( the microphone, the battery compartment, speaker, key pad, the sides, everywhere!) Keep doing it for 15 or even 20 minutes solid. With my cousin, you could actually see the water drying up inside the LCD display area. When we turned it back on it worked.
Posted on Sep 29, 2008
Can a Vtech cordless phone dropped in water be repaired?
Do it like a cell phone, put it in a ziplock bag with rice and hope it dries it out
Sep 16, 2014 | Vtech LS6225-3
Tip
Dropped the cell phone or mobile in water
Dropped the cell phone in water
If you would have accidently dropped your cell phone in water or it fell in water you can try fixing it be these below tips
1. Remove the battery of the mobile and try drying it with a hair dryer
2. Put the cell phone in a raw rice container for a day, the rice will soak the moisture and the mobile will become dry from inside
3. After that put the battery back on and try switching, there are more chances now that it will work
4. Never try to instantly switch on the cell phone after taking it out from water you should follow the above steps, switching it on instantly can lead to short circuit in mobile and the cell software can get damaged
5. You can also put the phone in light sunlight (not in very hot direct sunlight) after removing the battery do not put the battery in sunlight though
6. Also make sure you keep the SIM card out of the mobile
By taking these steps you can make a fair attempt to save your mobile from dying.
Regards
Vikram
on Dec 02, 2009 | Cell Phones
I dropped my iPhone in water. What should I do?
useually unrepairable but take the back off then remove battery and sim then use a hair dryer to try and dry out the moisture sometimes it works depends on how much water damage is in the main board
Sep 01, 2010 | Apple iPhone (16 GB) Smartphone
Dropped in toilet
Congratulations!!! remove every parts you can i.e. battery, SIM card and memory card. Make sure each and every single drop of water is out. Wrap the mobile phone thick with a piece of cloth and keep it on a warm place ( Not too warm ) like Above the TV( thats the best i can suggest) for couple of days, 3-4 days will be sufficient. Make sure you don't switch it ON while its wet otherwise the Flash IC might get fried by the battery. After 3-4days of evaporating the water from your Mobile, keep fingers crossed and switch ON the Mobile. If switched ON perfectly for 10-15 minutes (try checking all the feature in this time period) the mobile phone is in good status and if it doesn't kindly purchase a new Phone because i won't suggest you to get it repaired as once Nokia phone goes for a repairing it will always ask for repairing after 2-3 months.
May 05, 2010 | Nokia Intrigue 7205 Cell Phone
I dropped 1 of our uniden phones in water and it is not working. It is from a set of 3. The other two are fine, Whay should I do?
It might be too late. but...
1. Take out the battery from the phone.
2. shake an excess water from the phone.
3. Allow to dry for 48 hrs.
4. Replace the battery and maybe the phone will work.
I have a uniden that's been in a swimming pool and it came back to life.
Good luck.
Nov 19, 2009 | Uniden Cordless Phone
It is jammed and does not want to turn on
I think you have broken it.
1.Dont drop it in water
2.Dont drop it on hardware
3.Dont drop it anywhere
4.Dont do to much at the same time to make it freeze
If you did any of these things you have broken it
Dont panic
Oct 07, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
I dropped my sgh-d807 in water,the screens blank and wont turn on
u broke your phone becus i did the same thing and had to buy a new phone sorrythat happened
Jul 10, 2009 | Samsung SGH-d807 Cellular Phone
Water damage
1) Take the battery, sim card (SD card if there is one) out and dry
2)Dry the battery compartmant
3)For about 24 hours turn the phone upside down, or so the water will drip OUT
4) Then for about 2-3 minuets dry with a blow dryer, on low
5) YAY your cell phone SHOULD work, if not then the damage is serious
Dec 30, 2008 | Cell Phones
Sidekick 3 dropped in a cup of water. Water got into screen.
Is the screen blank all the time?
If you look really hard can you see the items on the screen but they are really dark? If so the back light for the lcd may have burned out.
Take a look at the following site for instructions on disassembly.
http://www.gsfx.org/disassembly/index.htm
If you feel comfortable with it, you can easily replace your own.
A new lcd runs about 50 dollars shipped. If you buy it from ebay, they will usually come with instructions and the screwdriver you need. A T6 torx driver is the type needed.
Sidekick LCD screens
Good job on drying it out and pulling the battery. Thats the best thing you can do when you get it wet!
Jan 14, 2008 | T-Mobile SidekickĀ® 3 Cellular Phone
Dropped in water
this happened to me for more then 3 seconds in water for the razor, turn off the phone, remove the battery and SIM card, let it sit in a dry place over night, and check again next day, it should be fully functional
Jan 01, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
242 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
