Question about HP Computers & Internet
Everytime that I try to print a document, I am getting a lot of boxes. I am not getting the words printed that I need.
    Problem Solver:
  • 16 Answers
Hi Goody2Shoes6, what a great nickname!
If the boxes are a rectangle for every letter, try changing the font, especially if the printer is an old model and the font is recent, if it does it for every font, type up a letter (or type =rand(3) in word and it will put some blurb up for you) then press the Alt key at same time Print Scrn key. Then open paint and go to edit menu / paste. go File Print preferences and set the page to 1 by 1 pages, File / Print preview, if good Print.
The printer should print it, as it is taking it as a picture file, if that same font won't print straight from word (and gives you little squares) it means the printer doesn't have that font listed in it's memory
If it is the case, buy a new printer, or use an older font that works.
Posted on Sep 29, 2008
It keeps randomly printing the following: GET/DevMgmt/DiscoveryTree.xml HTTP 1.1 HOST:
To resolve this behavior, clear the Document Properties check box. To do this, follow these steps:
Word 2007
  1. Click the Microsoft Office Button, and then click Word Options.
  2. In the Printing Options area box, click to clear the Print document properties check box, and then click OK.
Word 2000, 2002 and 2003
  1. On the Tools menu, click Options, and then click the Print tab.
  2. In the Include with document area, click to clear the Document Properties check box, and then click OK.
Nov 05, 2014 | Dell 2335dn Multifunction Laser Printer
Printing Sections in Microsoft Word
Printing Word Documents with Multiple Sections You have a document with multiple sections. When you try to print specific pages, you get either one single page, or the whole document. What you don’t get is the two separate pages you need.
First, take note of which section has the first page you want to print, and in which section the second page resides.
You need to print Page 2 of Section 1 and Page 1 of Section two.
In this particular case, the command is the usual: File | Print:
The difference in this case is how you specify the pages to be printed. In the Pages dialog box, type P2S1, P1S2 and then click OK. The comma “,” separating the two pages indicates two separate pages. The result will print Page 2 of Section 1 and Page 1 of Section 2.
If, however, you wanted to print from Page 2 of Section 1 through and including Page 1 of Section 2, the command would be P2S1-P1S2. The dash "-" indicates a range of pages, which results in printing from Page 2 of Section 1 through and including Page 1 of Section 2.
on Mar 26, 2010 | Microsoft Word 2003 for PC
Word 2010 doc will not print. Will print with Wordpad.
Microsoft support describes several things to try. After checking to see if any new blank document you create could print or not, the next possibility is to rename the normal.dotm file that may be necessary to resolve this problem.
Procedure to check:
"Microsoft Windows 7
  1. Quit Word.
  2. Click the Start button.
  3. In the Search Programs and Files box, type or Normal.dotm depending on your version of Word.
  4. For each occurrence of the or Normal.dotm template that you find, rename it Normal.old. To do this, follow these steps:
    1. Click Normal.
    2. On the File menu, click Rename.
    3. Type Normal.old, and then press ENTER.
You can now print new documents that are created from the new global (blank document) template ( However, existing documents that were created by means of your old file may not print. If this is the case, go to the "Print the problem document" section to resolve problems with these documents.
If you cannot print this new document, there may be a problem that prevents Word from printing. If this is the case, go to the "Print the problem document" section.
Determine if the problem documents were created from the same custom template You may still not be able to print particular Word documents. Examine the problem documents to determine if they were created from the same custom template. To determine which template created the problem document, follow these steps:
Word 2010
  1. Open a document that you cannot print.
  2. On the Developer tab, click Document Template in the Templates section.
  3. On the Templates tab, look in the Document template box."
Jan 12, 2018 | HP Office Equipment & Supplies
No content prints on document when word document is sent to the printer
Is the problem only with Microsoft Word? If so you might have selected something else in the "Print What" box in the "Print" dialog box instead of "Document". See the below screenshot and make sure that the "Document" is selected. The Print dialog box will come up when you click the "Print" sub-menu from the "File" menu, i.e. click "File" and select "Print".
If this doesn't help, reinstall the printers drivers/softwares. That should fix your problem.
If the problem isn't only with Microsoft Word Documents, then there might be other problems with your printer, it could be cartridge/s, ink, drivers, etc..
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 14, 2011 | HP Officejet 6500 AllInOne InkJet Printer
Trying to duplex print a Word document as booklet on my MP160. (that is, each page would be 1/2 letter size sheet.) I had no problem setting up the doc, it just won't print. Word Help says I will be...
I am MS Offfice Systems as part of my degree. I have two courses in word. What you need to do is to click on the office button, click on print, and click print again. Click on the properties button on the top right on print dialog box. In the selection box about fourth option down where it say Two-sided (Duplex) Printer click on that. That should do it for you.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One Printer
Media is not picked up from the media tray
save the document to your desktop or copy and paste into word or notepad..
tell ya printer settings to clean nozzles.
remove paper.
place paper into tray area but not a whole lot....15-20 sheets...
now print...hows that..:-)
Sep 15, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Extra page gets printed showing file details everytime i print a file
in word, go to:
include with document
uncheck document properties
May 30, 2009 | HP Officejet 5610 All-In-One InkJet...
Mismatch paper size error
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print
on the bottom of that screen there should be a scale to paper size drop down box. Scroll to the bottom and your saved name and dimensions should be there.
You will have to setup each individual sized template ones and then just scale to fit each time. Hope this helps
Mar 26, 2009 | HP Photosmart C4480 All-In-One InkJet...
Printer problem
Well ... it sounds like you are printing from Micro$oft Word (or similar) and have the print options set to print the document properties.
If using MS Word, select "OPTIONS" from the TOOLS menu. click the 'Print' tab and unselect 'Document Properties' in the include with document section.
Nov 13, 2007 | HP DeskJet 940c InkJet Printer
Computers & Internet Logo
59 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
