Belkin Wireless G Plus MIMO  Router
Problem for Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Arimex comcast router won't talk to belkin wireless g plus mimo router
By ruby12 on Sep 29, 2008
Comcast put in a new modem "Arimex", and since then I can't get wireless to work. When I go through setup, it says the internet connection can't be found. Is this a comcast problem or modem problem?
With the previous comcast modem, I was able to set up wireless, although I was not able to set up security.
Solution #1
posted on Sep 29, 2008
Not Rated)
mspcrepair
Rank: Guru
Rating: 88%, 133 votes
Comcast has a little known "trick" that they use when setting up users. Here's how it works:
When Comcast first comes to setup your new cable modem service, they insist on connecting it to your computer and "testing" it. Most people think nothing of it, and that it's good customer service ...truth be told, what they are doing is attaching your computer's MAC address to that cable modem, so that you cannot create a wireless network. This is because they want you to pay them $150 to do this for you.
In this situation, since the modem is a modem/wireless router in one, my guess is that the MAC address on your machine now does not match the MAC address on the new router, which is what Comcast has stored in their database(s).
Try this: on your computer (while connected to the modem), perform a release on your IP address (start, run, cmd, then type "ipconfig /release"). Disconnect the ethernet cable from the computer. Turn computer off completely. Hold down the reset button on the cable modem until it performs a reset. Once it's back up and running, boot up your computer with the cable back in the ethernet port.
The cable modem should assign a new address to your computer. However, that may or may not work ...this is an easy workaround with a Linksys router, but not necessarily with the all-in-one devices.
Worst case scenario: contact Comcast and notify them that the new modem is not recognizing your computer's MAC address and that it needs to be updated in their system. They will scan your computer (through the telnet interface on your modem) and get your computer's MAC address, then (hopefully) make the necessary changes on their end.
After that, everything should work flawlessly. If not, insist on a Comcast tech to "fix" the service that you are paying for.
Good luck - hope this helps :)
Was this helpful?
Yes
No
Popular Solutions for Belkin Wireless G Plus MIMO
Questions and Unsolved Problems for Belkin Wireless G Plus MIMO
Do you recommend Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)?
Answer
Answer
Wireless Router and WiFi processes: Belkin Router □ Cannot disable or disconnect the... (More)
Answer
My laptop say's I am connected with excellent signal strenght but I still can't get on line!
Answer
purchased new mini laptom with my verizon phone. cannot connect to internet
Answer
Hi i have a belkin wireless g plus mino usb network adaptor running windows XP the computor finds... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Belkin Wireless G Plus MIMO ...:
Top Router Experts
Rank: Guru Guru
Solutions: 3608
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
