Question about Carrier 38BRC048 Air Conditioner
Carrier A/C Intermittent Shut-down Problem
I'm currently experiencing an intermittent problem with my Carrier A/C Model FC4BNF042. It shuts down completely and fails to restart. When in this condition, there is no LCD display on the thermostat indicating the unit is on. I've also checked but was unable to detect 24V from the output side of the transformer although the 220V input was fine. I isolated the transformer, thinking it may be bad, and performed a simple resistance check. The primary side read 74 ohms and the secondary 1.7 ohms. Even though it appeared a little high I assumed the transformer was okay since it did not have an obvious short or open coil. I proceeded to visually check all the wiring, components, fuses, etc. and all appeared to be fine in the air handler unit. I have a gut feeling the thermostat may be defective. Is there something that I may be overlooking and could check before I go out to and buy a new thermostat? By the way, the unit began working again about an hour after I last checked it.
    Scholar:
  • 121 Answers
It sounds like there is something in the system that is over heating. A t-stat will either work or it won't there are relays that have 24v coils and can become weak. If your air handler is shutting down it shut down the condenser, if the air handler is staying on but condenser is shuting down check the outside contactor. I am an a/c contractor and can be contacted at 504-722-3946 Eddie.
Posted on Sep 29, 2008
Windows shuts down unexpectedly
This problem has been solved. There was intermittent contact inside the power switch on the front of the case causing the motherboard to issue a shut-down request to the operating system. Switch replaced and system is now stable.
Oct 06, 2012 | ASUS M3N WS Motherboard
The tv shut off for no reason
It might be to the fault to its main power regulator section board. Your TV need a through checking, as intermittent fault like these are very difficult to locate and repair. Contact any experienced service technician.
Jul 15, 2012 | Panasonic Televison & Video
Computer wont start and when it does it shuts itself down
Sound like a power overload system is kicking in, which means either a bad power supply or shorted circuit else where. Disconnect the DVD, CD, and any other devices to narrow it down. Try another known good power supply. If all this fails, it's going to be a problem with the motherboard, by elimination. There can be an intermittent capacitor or electronic heat sensitive part that's shutting down the computer. There are diagrams and videos on the net that can guide you through possible problems, in case you want to fix it yourself. Google "Intermittent Computer Startup" and you will find some good suggestions. One site is this one:
http://www.ehow.com/how_5880187_troubleshoot-intermittent-shut-down-computer.html
Good luck.
Apr 15, 2010 | Computers & Internet
Loses internet connection I unplug or turn off the router then I will get the internet service for a little while it then shuts down. I contacted the cable service they sent a signal to the router box...
There could be a problem with this router's firmware that is why you are experiencing intermittent connection with it... Try hard resetting it and try reconfiguring it back again
Mar 15, 2010 | Linksys WCG200 Wireless Router
My prosine 2.5 charger inverter intermittent
First try blowing it out the unit with compressed air to see if there is large amounts of accumulated dirt inside, look for black soot on the center of the air outlet side.
Intermittent problems are the hardest to troubleshoot.
If you need more help contact me at sunyout@gmail.com
Thanks.
Sep 14, 2009 | Xantrex Technology XANTREX PROSINE 1800...
98 Saturn SL1 Intermittent Wipers stay on full
Have your intermittent relay checked.
Nov 29, 2008 | 1998 Saturn SL
TV goes off intermittently
sounds like an intermittent shut down which is heat related. some part , maybe one stuck on a heatsink is warming up and running too much current triggering shutdown.
to find it you can tell what is shutting down with a voltmeter, or you can heat suspected parts with a blow dryer to speed the shutdown .. or freeze spray to see if it goes beyond your shutdown time.
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
TV won' turn on
Solder, solder, solder! Shut down circuits protect crts to avoid permanent damage. If any of the deflection circuits are defective, or intermittent, shut down occurs. I have not only seen bad solder on deflection circuits, especially vertical, but also intermittent connections on the yokes themselves. I've also seen shorted convergence ics cause shut down. Don't forget solder connections in the power supply.
Jul 05, 2007 | Mitsubishi WS-55807 TV
Carrier 38BRC048 Air Conditioner Logo
287 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
