SOURCE: OSD lock out
i am having the same problem, i opened up the monitor ( very easy) and checked the swithc board to see that all buttons arfe working. Ang movrd all of my ( i have about 15 things attached to the computer) gadjets far as possible ( maybe it wasn't shilded properly). As far as i know i am using it for over an hour now and it hasn't falsed the osd locked out yet. I will post again if this goes away for good
SOURCE: HP w17e monitor
if you go to the menu and you will see the on screen display (osd) press select and u will be able to change the values of it here ok
SOURCE: HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
SOURCE: f1703 monitor - OSD Main Menu keeps popping up on
I would try using a different keyboard temporarily and see if the problem continues. If not, you know you're probably hitting a key by mistake that's setting off the OSD menu. Here's your keyboard manual: http://www.microsoft.com/hardware/documentation/default.aspx?type=Keyboard&sku=B2M-00012
