Question about Kenmore 22422 Top Load Washer
Kemore 80 Series stock # 26832
The washer will not go through the rinse cycle. For a time when it would stop I was able to firmly tap the top of the washer and it would continue. Now it just stops. I am able to turn the knob forward to just past the rinse indication and it will start again for 2 minutes, but then stop and not go on to any other cycles. I drained the tub and it did not continue to spin. Any solutions
  • 5,911 Answers
Yeah...check your lid switch. This is a very common description of a lid switch malfunction. In fact hitting the washer, or slamming the lid will make the problem progressively worse. The lid switch is located in the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first, then check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Top and Cabinet" heading for item number 11 (part number 3949238). If you do not wish to order online, take the part number provided and go to your nearest appliance parts retailer. This is a common part that most carry. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
Posted on Oct 01, 2008
I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Mar 17, 2010 | Kenmore 22422 Top Load Washer
Kemore 80 series, washing machine will not drain
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you have questions, or my advice does not match your symptoms, please let me know. I hope this helps you.
Jul 08, 2009 | Washing Machines
Kenmore 80 Series top loading washer--will not stop filling with water at the beginning of the wash cycle and for the rinse cyle. Is there an easy fix or should I purchase a new washer? How much can I
The pressure switch is failed - remove the tube from inside the top console area and blow it out. If you're lucky it will again work - with no charge.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
89 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
