Question about Haier Heating & Cooling
Brand new Haier HD656E dehmidifier keeps turning off and on - short cycling, like the humidity sensor is located in a bad place and can't decide whether it should be running or note.
  • 750 Answers
Haier HD656E
You have a 1 year warranty.
If you feel it is two short a cycle you can take it to a service person for free.
It is supposed to cycle off and on as needed!
This is normal!
Posted on Sep 29, 2008
  • Neil Golan
    Neil Golan Sep 29, 2008
    posted by Haier HD656E on Sep 29, 2008
    Report abuse
    Brand
    if(typeof LIB_LOADED == 'undefined'){document.write(''); }
    Add a Comment
    Post Solution
    Work Queue
    Have the same problem?
    I have the same problem
    I have the same problem.
    X
    This Problem has been added to the Share Your Expertise Page under "My Work Queue".
    OK
    Best Solution
    posted on Sep 29, 2008
    Rank: Wiz
    Rating: 82%, 82 votes
    Dear Haier HD656E
    I shared my professional opinion with you, a true and honest answer for you!
    Which is also a simple cost free solution for !
    A repair for free under your warranty.
    I do not understand why you rated me with an inappropriate????????????????????
    My advice was the best fatherly advice on this site today!
    We have been in the appliance business for over 65 years!
    And my father and grandfather always taught me the truth is the best policy!
    God Bless You!
    Huuum
    Work Queue --> Have the same problem? --> I have the same problem --> I have the same problem.
    X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Best Solution posted on Sep 29, 2008
    Rank: Wiz
    Dear Haier HD656E
    God Bless You!
    Huuum
Hi, is compressor suppose to start as soon as the component switched on?
If the humidity extraction level is set low enough, yes it will. In which case, it's operating as it should.
Hope this helped you and thanks for choosing FixYa.
Aug 10, 2011 | Haier HD656E Dehumidifier
I have a GE AHH50LMG1 dehumidifier. It is less than 2 years old. When I turn it on, it displays 20% RH. The fan runs but the compressor does not kick in. I assume that is because it thinks the humidity...
It could be just the sensor, but not likely... many times it is the circuit board that goes bad, making the repair almost prohibitive.. as the circuit board, if you can find one, is often half or more the cost of a new unit...
But you are correct... if the unit thinks the humidity is 20% then it will not bring on the compressor...that is what is happening...
heatman101
Jun 25, 2011 | Haier HD656E Dehumidifier
I need an owner's manual for my Haier dehumidifier model HD656E. Can you help me?
Here is a link for you to download the manual. http://www.retrevo.com/support/Haier-HD656E-manual/id/951dj390/t/2/
Please rate this post! Thank you!
Jun 10, 2011 | Haier HD656E Dehumidifier
It comes on and off very often is that normal, sometimes it comes on for 1 sec and goes off.
There is probably nothing wrong.
When the device senses that it is too humid in the room, it turns on. Due to a slight error in its humidity measuring system, it switches on, then it realizes that it isn't humid enough to be on, and turns back off.
I have had several and have heard other stories of similar items behaving in this way.
Or, it is perhaps that the adjustment the machine wants to make in the humidity level is low enough that it only needs to be on for a second.
Nonetheless, check to make sure everything is working properly.
May 28, 2011 | Haier HD656E Dehumidifier
Unit wont run but lights up. It reads low humidity even though its high
First, make sure the reservoir is empty. If you plug the unit in and see a green power light, but the unit won't run, make sure the reservoir is properly inserted. Many dehumidifiers have switches or sensors to make sure that the reservoir is placed so that it won't leak. Look for these sensors and make sure the reservoir is engaging them. If your dehumidifier has a float or switch to indicate a full reservoir, make sure this switch isn't being tripped accidentally.
Good luck.
Aug 13, 2010 | Haier HD656E Dehumidifier
Tyies to Start
It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers2_bing.gif that run but do not extract water from the air..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 02, 2010 | Haier 65-Pint Dehumidifier
Humidifier collects very little water
Check to see that the air is flowing freely through the dehumidifier. They will accumulate dust particles and become plugged. Also make sure that it is not freezing up (you would see ice forming inside through the vent openings). I have had to remove the case to clean lint from some units to get them to operate more efficently. Always unplug the unit to clean and service it.
Jul 03, 2009 | Haier HD656E Dehumidifier
Heating & Cooling Logo
51 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
