Question about Dishwashers
Kitchenaid dishwasher electronic control panel problem.
Hello -  We own a Kitchenaid Superba dishwasher (model KUDS01IJ) with an electronic control panel. Some lights remain lit but each pad is unresponsive therefore washer does not work. No change if door is locked or unlocked. When unplugged  and re-energized, same lights come on but still unresponsive. I am handy but not sure whether to call a technician or try something myself. Regards, Michael Price
  • Anonymous Dec 22, 2008
    the dishwasher here is stuck on 'light china' setting which does not work for pots and pans.
  • 878 Answers
SOURCE: Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. back.
Posted on Mar 08, 2007
SOURCE: Control Lock light remains on
This solved my problem, but the questions is what created the light to be stuck
Posted on Sep 16, 2008
SOURCE: Kitchenaid Dishwasher Latch Broken
Posted on Nov 02, 2008
  • 188 Answers
SOURCE: Child lock shut off
Hold the button with the lock until the light turns off. Consult the manual.
Can you provide a model number?
Posted on Feb 18, 2009
SOURCE: blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
Posted on May 08, 2009
My dishwasher will work only on "baked on cookware" cycle. What is wrong??
Your timer or control unit whatever you want to call it has probably failed.
Dec 13, 2014 | KitchenAid Dishwashers
Not draining properly
Hello, I would look for a kink or a blockage of the drain hose. Also check the drain pump belt for looseness or breakage.
Jul 30, 2014 | KitchenAid Kitchen Aid Superba Series...
Status light blinking
Please do a full clean up of the machine after checking in all the connections to the mains panel.Please check this link for tips to go about:
Mar 12, 2012 | KitchenAid KUDS01IJ - Multiple Color...
How do I turn off the childproof lock on my KitchenAid Superbua dishwasher?
This depends on the exact model of the KitchenAid Superba dishwasher. There is a button on the control panel that will indicate the Control Panel Lock. Usually this is labeled Control Lock (Hold 3 sec) or 4 Hour Delay (Control Lck 3 Sec). The phrase in parentheses is below the key in a smaller font.
Press and hold the button to toggle the lock on and off. Sometimes you have to hold it for more than the listed 3 seconds.
I hope this helps.
(my reference was the manual for the KitchenAid KUDE40FXSP . Other KitchenAid appliance manuals are available here: . Just enter the model number and the type of person researching the documentation (consumer).)
Jul 14, 2011 | KitchenAid Dishwashers
The easy solution is to try pressing the Energy Save Dry button & hold it in for 3-5 seconds. This should turn the child lock on & off.
If this doesn't work, then it's likely that one of the pads on the control panel is stuck, and it (the control panel) will have to be replaced.
If you don't have the manual, you can download one here (PDF format). Good luck!
Mar 02, 2011 | Dishwashers
KitchenAid superba dishwasher leaking
heres a link to your part pook up, pg 6 number 4-5-6 is what i would assume your talkin about, its where the water comes into machine itslef, easy enought ot do your self, simply held on from the inside with gasket and nut. call local parts dist or whirlpool direct for parts
Nov 09, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
333 people viewed this question
Top Dishwashers Experts
