Question about V, Inc. Vizio L6 HDTV-Ready LCD Television
Vizio P42 HD 2? red vertical line on the left side of the screen
2” red vertical line on the left side of the screen on my 42" Plasma Television.
  • 217 Answers
SOURCE: help - 15 mth old 42" edtv "plasma" black screen" have power and sound
it could be 1 of 2 things, the panel could be shorted or the logic main board could be out, you must open the back and take voltage measurements, check the panel voltages and then start pulling the connectors off one at a time, to see if the voltages come back up
Posted on Feb 17, 2007
  • 22 Answers
SOURCE: vertical red line on my Vizio plasma
Spent 3 hours removing all what seemed like 100 freaken screws.
Took out the OEM 038A, caution the factory placed some type of heat transfer silicon clear grease on the back of the board so it will feel like it is glued on. Just be very carefull and gentle when prying it apart.
Be warned, you will need a magnifying glas to check those little resistors. They all checked out, no broken solders.
What I did observe is the grease melted down the back of the board and puddled at the bottom of the board and where the resistors sit.
I used rubbing alcohol to clean it all up but left the reside on the square pads. Cleaned the resistors and used a dry paint brush to dust of any lint.
Placed the component back and after 10 minutes the Vertical Red Line Disappeared.
Turned on the set next morning it was still gone. 10 minutes later it re-appeared for a couple of minutes then went away.
I spoke to a kind gentlemen at, he stated that the 060Q is an upgrade to the defective proned 038A ( 038C is also an upgrade ). A tech in Cali stated the 060Q worked perfectly. He has had zero complaints about the 060Q in the Vizio plus he offers a 90 day return policy. Funny thing is the 060Q was designed for LG and Goldstar Plasmas but for some reason they do not work for them but do work for Vizio's. He even states that on his site.
As I type the red line is still gone and stayed off several hours last night.
I think I am going to pull the trigger and replace the 038A to the 060Q and be done with it.
Oh yeah, I asked him if the 060Q needs to be "flashed" with the Vizio program. He never heard of it requiring it.
He has 038C on order they are couple of bucks cheaper. the 060Q is $224 plus S&H.
I found on ebay for $184 free shipping but waiting for the guy to verify no "flash" requirement.
Hope this helps someone.
Merry Christmas and a Happy New Year!
P.S. use a power screwdriver, your wrist will thank you. I put mine on low torque as not to strip the heads.
Posted on Dec 23, 2008
  • 56 Answers
SOURCE: vizio p42 very dark screen backlight off
There is no back light in plasma TV, Base on the description, the Z Sustainer board is bad. Replace the board will fix the problem.
Posted on Feb 17, 2009
  • 1779 Answers
SOURCE: VIZIO P42 plasma, half screen ok, other half showing blank
First you have to check if voltage and data are ok at the Y sustain board and the Y driver boards are not running hot. Even if you know how to replace these panels you must have a scope to adjust the v-set up and v- down. Not just a simple PNP. Trouble shooting a plasma is not a short time process to do it correctly. Please let a service center look at it for you.
Posted on Feb 18, 2009
  • 93 Answers
SOURCE: Red 2 inch vertical line on right side of Vizio TV
That problem caused by a connection between LCD crystal and matrix driver,no tools yet to reconnect that metal to crystal connector,Claim warranty right away that will multiply or became larger.
Posted on Aug 30, 2009
Our Vizeo P42 purchased in July 2005 has had a red vertical bar on the left side for about two months. About a week ago it developed vertical lines across the left half of the screen with no picture...
sadly no.
either your panel has been hit and damaged or the panel itself is failing.
without some sort of warranty coverage, your repair cost would exceed the price of replacement.
Apr 12, 2011 | Vizio P42HD Television
I have a 42" Vizio picture has an annoying thick red line
Ur backlight inverter video board is dying.
Need a new one.
Sep 22, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Vertical red line on my Vizio plasma
If the line is horizontal then it could be a y-drive panel ( depending on from ctr where it is ) whether it is the upper or lower board. Time to let a service company look at it, don't wait, more damage is possible the longer you play it.If it goes vertical ( up & down ) then it could be one of two buffer boards.
Feb 17, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Vizio P42 Plasma HDTV10A
May 19, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vertical green lines on screen
Feb 21, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Vertical black line on screen
Your set has either a bad driver board or more likely a bad plasma panel.
Oct 18, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
V, Inc. Vizio L6 HDTV-Ready LCD Television Logo
244 people viewed this question
Top V, Inc. Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
