Question about Philips 46PP9302 46" Rear Projection Television
Philips tv the power went out and then came back on the tv was on for a 1 min and then shut off it comes on but no picture no sound a light chirpin noise in the back for about 3 months the picture has been in double and looks like warped and its like double vision its a 2003 philips rear projection tv and it is a 55inch flat screen
  • Philips Master
  • 3,459 Answers
Sounds like your convergence chips are shorted which would make the set shut down. Its also possible that the flyback has failed but because the first symptom was the 3d look I would start with the convergence repair.
Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
No audio or video - typicaly occurs after having the distorted color problems listed above.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Ed
Posted on Nov 28, 2008
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
DLP HDTV shut off, sound but no picture
replace light bulb,
if you are hearing a click like the stove is because the lamp balast is trying to power on the lamp,
if you need part number and vendor please send me the model number
Apr 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips 37pf7320a/37 picture issues.
control boards on LCDs and PLASMA tvs are causing no picture , missing area , and other wierd symptoms , it will need to be tested to determine the true problem
Sep 20, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
The problem is the small signal board that is the video processor.
Mar 27, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
Mar 10, 2008 | Philips 60PP9352 60" Rear Projection...
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
No picture or sound - TV makes chirping noise
Rich that chirpin noise is somthing over loding it try checking your horzotal output for short and diodes around the transformer...
May 20, 2007 | RCA P60921 60" Rear Projection Television
Philips 46PP9302 46" Rear Projection Television Logo
170 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
