Question about Maytag Neptune MDG5500AW Gas Dryer
Scraping noise My Maytag Gas Dryer is scraping inside
  • mail2cjd Jan 01, 2009
    Maytag Gas Dryer makes a scraping noise, tumbler barrel has dropped on the front side about 1" and has excessive play. Can this be easily repaired?
    Sergeant:
  • 409 Answers
the scraping could be the tumbler itself. please check the belt around the tumber and make sure that it's not worn.
thanks
Posted on Sep 29, 2008
The back plate inside the dryer came off. Now the the drum is making a scraping noise.
That is the rear drum support you will need to get a new one and install the entire kit.
Dec 15, 2013 | GE Profile Harmony DPGT750EC Electric...
Maytag atlantis model MDE7600AYW is making scraping noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fsh4w2
Jun 23, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Ge DPSR483EA Electric Dryer was making a scraping sound when operating now a felt like belt has come out on the inside of the dryer. What do i do? Kris Long
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 11, 2010 | GE DPSR483EA Electric Dryer
Dryer drum is scraping something and black deposits are turning up on our clothes
Well there are two parts to the drum, there is the bearing in the back and the felt pads in the front which the drum rides on. There is also a belt, but if something is scraping it would not be that. Is sounds as though the cover on the felts has worn off and your getting felt material on your clothes, so those need to be replaced. You need to get the proper felts for your dryer than you need to look for any screws on your dryer casing that will allow you to remove the casing and get to the drum, as the pads are underneath the drum. (Note: Inside the door there may be screws on the underside of the upper deck, and the deck should tilt backward on hinges)
May 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Scraping noise while running??
heatman101
45w5ts
Jan 16, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Scraping noise from dryer
probably one or both the rollers in back of drum are no good these rollers are near the motor
Apr 18, 2009 | Maytag Dryers
My dryer squeeks when running
Hi, I've had a similar problem (I think) on my MDG7400 dryer. There was a cyclical squeak, metal against metal. It turned out to be the screw that holds the drum paddle to the drum. It had worked itself loose and was scraping against the inside wall of the dryer. Remove the front door lift the top, and tighten 'er up. Hope that helps.
Nov 19, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Loud scraping sound
If it was put on a dolly from the back or dropped on the bottom the blower housing could be in contact with the drum as it goes around.
Apr 24, 2008 | Maytag MED9600S Electric Dryer
Dryer is shooting sparks and making a scraping sound
hoover washer drier is making a scraping noise and a spark from the bottom of the machine everytime the drum spins, does anyone know what this cold be. thanks.
Apr 05, 2008 | Kenmore 83142 Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
193 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
