KOSS KS2117 Home Theatre no power
My Koss Ks2117 Home Theatre will not power up using the power button on the unit or using the remote. I plug the unit into a different wall unit, but same problem. Unit worked fine yesterday.
Any suggestions?
  • rjspen May 10, 2009
    Koss Model KS2117 - would not power up. Found blown 4amp fuse on power supply board. Replaced fuse and it also blew instantly as soon as I plugged unit into wall outlet. Disconnected the two plugs going to the other two circuit boards from the power supply board to isolate the problem. I replaced the fuse again and it also blew as soon as I plugged the unit into the wall outlet. This means the problem is somewhere on the power supply circuit board. I examined the board and was unable to detect any damaged components (no brown spots caused by overheating or no smell of burnt components). Does anyone know where a replacement power supply board can be obtained???
  • 4 Answers
SOURCE: Remote stopped working
http://www.fixya.com/support/t320518-bose_321
Posted on Jan 13, 2008
SOURCE: Universal Remote Issues
I bought a universal remote that lists the code as "190". On a different manual online, I saw "373". Try those and see if it works.
Posted on Mar 05, 2008
Agent Jon
  • 100 Answers
SOURCE: KOSS HOME THEATRE
Salutations robn7499,
There are a few things that may cause this to happen. First I would check your connections for your center channel speaker. in movies with 5.1 surround sound almost all the vocal tracks come out of the center channel.
Otherwise there maybe an issue with the volume levels for the center channel as well, these can normally be adjusted through the setup of your home theater system.
I hope this helps.
Jon
Go Ahead. Use Us.
Posted on May 06, 2008
SOURCE: remote control for koss 220
Well, I had the same problem, so I open the control and clean with a little alcohol or acetone the panel inside. Now I got my Koss control working 100%
Hope this post help.
Posted on Dec 29, 2008
  • 8 Answers
SOURCE: KS3102 Digital Optical Input Problem
What I did was turn on the system, don't put in any dvd in, or select an output 1 or 2. Press Menu on the remote, the display on the system display, not on tv should show Speaker, and other options. Select Input, select the one you want to use as the Optical Sound by press enter, then it will ask you on the system display input or optical sound input. Select optical input and press enter it will then say saved. You can then hit exit til goes back to where the display is back on main screen, or just wait til it exit by itself.
Posted on Jan 11, 2009
Koss ks2117 home theatre i cant change the the sound mode from stereo when im using dvd. and when i play the fm i could change the sound mode. i cant find the problem?
i would advise you go back to your instructions manual guide as this will help you in areas you have problems. this will guide you on how to go about with the selection of the sound quality
Sep 17, 2011 | Televison & Video
Tip
Koss C220 remote DO NOT Damage it!!!
Treat your C220 remote control with gentle loving care!!! The koss c220 system is useless with out it. Do not order a replacement remote from remotes.com for this unit they do not work very well.
on Dec 11, 2008 | Koss C220 System
I need a replacement remote for a Koss KS 4192
hi! i have here a couple of codes for KOSS home theater system, just try them 4003, 2060, 4015, 2200, hope this helps!!! goodluck!!!
Jun 09, 2010 | Koss KS4192 System
Need owner manuel for koss KS5190 digital home theatre system
me too help bzaggy@bellsouth.net Do u need remote to set speakers along with other setting problems including, back speakers not working, tv not on surround sound, can play dvd and tuner still no back speakers, no remote. Do u need remote to set, please help!!!! email bzaggy@bellsouth.net
May 11, 2010 | Koss Audio Players & Recorders
TV Hookup
The TV is NOT a source of high quality sound.
For the best serious audio I would recommend drawing the audio-only digital feed from the Cable Box via its highest quality audio output. Then turn the TV's volume down. Also run the vanilla RCA stereo audio pair from the cable box to the TV in case you just want to check the weather.
Mar 05, 2010 | Koss C220 System
Surround sound speakers won't work
I have the same problem. This works for some people, it didnt work for me. 1. Remove any discs 2. turn the unit off and unplug 3. wait about 20 secs and replug the power cord. 4. turn unit back on .Press dvd button on the remote to take unit to the dvd mode. 5.Using remote enter 76419. The display should say GOODBYE and go off. Press the power botton again to turn on and good luck
May 24, 2009 | Koss KS3102 System
Remote control for koss 220
Jul 26, 2008 | Koss C220 System
Koss C220 System
Try to load up a basic CD audio disc and see it works?If it doesn't,you need to repair your unit or buy a GOOD brand new like panasonic,samsung or Denon.
Nov 16, 2007 | Koss KS2503 System
218 people viewed this question
 Grubhead
Grubhead
