Question about Maytag Refrigerators
Maytag side by side doors hot
The sapce in the middle of the side by side doors very hot where door seals do you know why it seems to work just fine
  • 4 more comments
  • cen90 Sep 29, 2008
    yes i just looked in bottom behind draw there is a wht looks like a vent the cover was off and laying there dosnt look lie anything blocking it
    yes its am maytag plus side by side model # MSD2356AE
    ref is 4 freezer 3.5 both seem to be working find but the middle sapce is very hot where doors seal
    the seals are ok just so hot from the metal that tey seal against the metal strip where door seals hit are so hot
    should the metal strip be so hot to the touch?
    the cabnet metal strip i dont think as ever been this hot before
    Sergeant:
  • 409 Answers
you may have a clogged vent, preventing air circulation. is there are vent on the bottom by the crispers?
Posted on Sep 29, 2008
  • 3 more comments
  • Carmen Mikulic Sep 29, 2008
    can you supply the make and model # please?
    thanks
    can you tell me the temperature setting in both fridge and freezer sections?
    good, just wanted to make sure the temperature settings weren't off.
    both doors have rubber gaskets around them. the gaskets are removable and doors are adjustable, so no worries. this is a case of either one. if you have the use and care guide, you should be able to do this yourself.
    the reason they are hot is becase they are pressing too hard against the cabinet.
    here is the procedure for adjustment. have a look through section 3-1:
    http://www.servicematters.com/maytag_lib...
  • Carmen Mikulic Sep 30, 2008
    the metal should not be hot at all. go ahead and do the adjustment, as i provided earlier, as the door gaskets are rubber and will stretch out or melt with the heat.
Door seal is very hot
This may be a sign of a failed condenser fan or an overly dirty condenser that could lead to problems. Here is a link to instructions I put together on taking care of this. Let me know if this helps.
Thanks.
http://www.fixya.com/support/r4694132-hot_door_seal_rail_divider_strip_between
May 05, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
My Maytag side by side has frost that develops on freezer side
almost deffinately door seal.try hot cloth to warm seal and pull into shape ,close door ,if you look down seal it should stick to door frame all round.no air leaks...
Feb 11, 2010 | Refrigerators
I have a bottom freezer french door mode. The
remove both crisper pans and check the return are duct opennings. next check if there's a built up frost/ice on the rear wall of the frzr. is you frzr fan blowing air? if so, there's a small window inside the refrig's freshfood side back wall towards the cieling, make sure that's open.the cover should snap off. if window/damper is open, go ahead an pour hot water down the return air ducts behind the crisper pans. they look like grill slots in one or both coners
Jul 14, 2009 | Maytag MFI2568AE Side by Side French Door...
Freezer side is hot outside
There is no problem at all. The outside of the freezer is hot because it is rejecting heat from the inside of freezer compartment to the outside surroundings, this is a normal refrigeration cycle. As for the seals being hot, this may be to prevent the door from freezing shut. i know that commercial and industrial freezers have heated seals for this reason.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
Space between doors on cabnet is very hot to touch ref seems to work ok
hi. thanks for the question .the heat between the doors is normal . its hot to keep condensation from running down the doors .but pull fridge away from wall. remove back panel and clean all the coils. very important. thanks the appliance doc
Sep 30, 2008 | Maytag 23 cu. ft. Side-by-Side...
Whirlpool refrigerator side by side door seal very hot
when you said fans working....does it include the condenser fan? or it may have two evaporator fans..
if condenser fan is working, then it is just normal. if the compressor is running, that part would really heat up. and if it is too hot, then the condenser fan could probably not running.
its not constant because the compressor cuts off when ever the thermostat cuts off.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Whirlpool GC5SHEXNS Side by Side...
Kenmore side by side model 106.55512400 inside frame hot to touch
There is an electric heater in the center which is called a mullion heater. If you have an energy saver switch on your model turn it to the saving position.
Jul 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
254 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
