Question about Home
Bath tub installation
I just bought an "aqua glass" bath tub it's the fiber glass hollow kind and is the same size as the one I just removed out the same spot. Having said that, I can't get the tub to fit in the spot! It seems to be to large to get in there. No matter how I angle it, it just wont wedge down in there. What do I do?
  • Anonymous Apr 22, 2009
    On the inside of my jacuzzi bathtub there is a bubble, and I can push it in. What is it?
  • 374 Answers
Okay lets start with the most obvious: Check all studs to ensure they are plumb. I am assuming all sheetrock and tile has been removed. if so measure the distances from the bottom plates on the end walls. it should be 60 inches in the clear. measure the height of the tub from the edge of the skirt that contact the floor to the top of the skirt then measure this distance off on the front and rear studs on both end walls and mark it off. Now measure to see that you still have 60 inches in the clear at both the front and rear locations. Now measure the tub as well to ensure it wasn't mis-manufactured. If all your measurements come in at 60 inches you should be able to bring the tub in and slide it in as it is when it is finished. If you find out that you have less than 60 inches in the clear for the tub you can use a drill and jigsaw to remove additional wood from the studs to get it to drop in. Once in you can fir the wall back out to the original dimension and sheetrock and tile. One thing you need to remember is that you may need to take wood out of bot ends to get the drain to rough in correctly.
I hope this helps you out and thanks for using Fix Ya.
Posted on Oct 16, 2008
Hot Tub won't Turn On.
First check the breaker box for the house and see if it has power.
Jun 26, 2015 | Home
Which side is the motor on of an aqua sense tub made by aqua glass that jets the water
when approacing a spa for the first time i allways use my ear to listen for the loudest noise area when spa is running before i remove skirting , then its usually self evedent that mfg has added a access panel that was previously hid from normal view
Sep 25, 2014 | Pool & Spa
Aqua Glass whirlpool, Indulgence collection, pump turns on and works briefly, then jets stop.
First of all, what you have is a WOW pump that has an E-switch for a control.
There is a knob on the top lip of your tub that you turn a 1/4 turn to turn this pump on/off.
There is a small circuit board inside the box on top of the motor. This is likely the source of your problem.
Here is your biggest problem. That little circuit board is not made anymore. We have the e-switch but you will be better off changing out the pump (which you have to do anyway) with a new WOW pump with an air switch and change the switch on the top lip of the tub to an air button which will turn the pump on/off.
Rod
US Parts Center
Apr 13, 2014 | Whirlpool Safety Bath Walk In Bathtub -...
Can't find a pump for Aqua Glass model 566042BC
What model of pump? Pumps are changed and identified by the model and brand name of the pump, NOT the model number of the bath tub.
Rod
US Parts Center
888-521-6183
Mar 22, 2013 | Home
I have an Aqua Glass Jaccuzzi that I haven't used in 10 years. The last time it was used it worked perfectly. Now I can't turn it on at all. I don't remember is just the round dial that
Check the circuit breaker and make sure you have power to the pump.
If you have power to the pump and it is not operational when the tub is full of water and you are in it then I would say you have a serious problem.
Most all of the older control that Aquaglass has used in the past have been discontinued.
You may want to visit this link and identify your control before you begin t trouble shoot your system.
Rod
US Parts Center
888-521-6183
Feb 27, 2013 | Whirlpool Safety Bath Walk In Bathtub -...
I need a replacement pump and motor for an older Bath Tub Whirlpool The motor is an Emerson 1/2 HP 115 vac (Model # SA55NXKHC-5590) and the wet end Part # is 91040810.
that is an Aqua Flo bath pump model TMCP 1 hp model. that has been replaced by the NEW Mfg with a pump called the WhirlMaster.
You may find that pump at www.uspartscenter.com
Feb 12, 2011 | Home
My Aqua Glass Whirlpool tub has stopped working. The motor comes makes a sound when I turn it on but the jets are not working
Your motor is shot. you need a new pump. If it comes on and you can hear a hum then it is bad. If you can get us a model number of the pump we can recommend a replacement model for you.
US Parts Center
Jan 05, 2011 | Whirlpool Safety Bath Walk In Bathtub -...
I bought a house with aqua glass whirlpool tub (14 yrs old). Motor won't come on and I can't find reset button or serial number. Where are these items?
will have to remove access panel or make one the motor /pump assembly is mounted to the tub test for power to the switch and pump the numbers u are looking for are their by pump
May 03, 2010 | Kohler 1209-LA-0 Hourglass Whirlpool with...
Aqua glass jetted tub quit working
Hello. There are two reset buttons in the mechanical space or your tub. You should be able to access that area from the front by removing a few screws. it is not uncommon to have to push those reset buttons after a power outage. If you do need a repair I recommend that you call a store that sells hot tubs as they will have a technician on staff or be able to guide you to one. Regards, Joe
PS kindly rate my answer as helpful.
Feb 13, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
Home Logo
870 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
