Question about RCA HD52W59 HDTV Projection Television
Convex picture - can I fix it myself
Picture on tv is convex. red & blue not alligned. I'm pretty handi with a soldering iron and following directions
    Genius:
  • 1,030 Answers
The itc222 has no convergence ics. they use transistors to do the same job. first determine if you have the fl231 problem listed in tip and tricks section., if you dont then it more than likely a convergence power board.
Posted on Oct 07, 2008
    President:
  • 4,402 Answers
Sounds like the convergance ic are bad
http://serviceman.site88.net/index_files/Projection.htm
Posted on Oct 03, 2008
I have an RCA 52" projection screen tv, model #
This problem is a commom Convergence failure. The circuit is composed of two output IC's or chips. They will both need replaced at a cost of around $350 from most shops. If you're handy with a soldering iron you can give it a try but it is a critical circuit.
Bill W
integrityhomeworx.com
Mar 23, 2011 | RCA P52937 52" Rear Projection Television
My Hitachi 50UX26B/27K red picture tube seems to be out of line with the blue/green tubes. When I press the magic focus it runs a short 30 second cycle then displays the number 3 in the bottom right hand...
Your convergence is fried go to ebay and order this item number 130475189383 copy n paste and put in ebay search.You will also need a delsolering iron, a soldering iron, some kind of skill soldering and patience.
Jan 18, 2011 | Hitachi 50UX26B/27K 50" Rear Projection...
The picture on an older 31 inch tube tv will go to a line randomly and if ya give it a slap it comes back. I did buy a new tv but I figured i would try to fix it myself. I do work with furnaces for a...
Your TV may need some soldering around the deflection circuit. It is too dangerous, to work on a 31" CRT TV due to its high voltage which, can kill you!. There is about 35,000 volts or more around, the deflection board and the tube. You need to resolder the components in the deflection board and you've got to have the right soldering iron and some soldering experience.
Good luck and be very careful
Sabre
Feb 22, 2010 | Sanyo Televison & Video
Red shadows in 48" JVC rear projection
Well you better be pretty handy with a soldering iron. The convergence output IC's need to be replaced. These are large plastic pack IC's with 18 or so pins that are soldered on the underside of the circuit board. These IC's are mounted to large metal heat sinks.
Jun 17, 2009 | JVC AV-48WP30 48" Rear Projection...
Red screen.
The IC's are bad. The parts themselves aren't expensive but the labor is. If you're at all handy with a soldering iron and willing to try, you will find a link below to a website with step by step instructions with pictures to help guide you. Otherwise, the repair costs $250-400 . Best of luck.
Greg
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jun 05, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony 51 inch Projection TV.
Dear AJ,
To be very Honest, i am not well conversant with Rear Projection TVs.
I suggest that you try with someone else.
Again from my personal point of view, i am of the feeling that itcan be fixed, and pretty easily. There must be a "Service Mode" which can be accessed by the remove, and then the Convergence Settings / Adjustments can be corrected.
But, I shall make additional enquiries and and let you know.
Cheers
Pravin
Dec 01, 2008 | Televison & Video
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
IT sounds like it needs to be degaused.
Before checking this, check for speakers placed by the set. this will cause it too.
The best way to avoid this situation is
  1. Don't place unshielded speakers near the set.
  2. Don't move the set while it is turned on.
The coil that is used is about $50 and can sometimes be found at industrial electronics stores. It's called a degausing coil. most TVs have a version of this built in and mutiple power on/off/ons may fix it, but don't hold your breath...
The trick is to turn the coil on with it right up to the screen. Move the coil in a big circular motion parallel to the screen as you S-L-O-W-L-Y move away from the screen. when you are as far away as you can get [about ten feet] turn the coil off. Caution. KEEP HARD DRIVES, CREDIT CARDS, AND FLOPPY DRIVES AWAY from the energized coil!
Good luck
Ken
Aug 15, 2008 | Akai PT5598HD 55" Rear Projection...
No Red- Intermittent
A short answer, YES. I suspect a cold solder on the red drive transistor. That transistor is one of 3 identical components (one for each of the blue & green). They are normally found in a small squarish PCB that is connected to the rearend of the picture tube. In some instances, they are also heatsinked. More often you need to remove the shield/screen protecting the foil side of the PCB. This has to be done gently since it can easily crack the glass holding the pins.
Cold Solders are corrected by applying heat from a soldering iron and probably a dab of solder lead. Solder joints should be shiny (not dull gray) with no air bubbles.
If your concern has not been corrected after completion of the above procedures, you may need to replace the red drive transistor. it might also be worth your while to check for any other component that may suffer from cold solder and/or any loose connection(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | Zenith A27A11D 27" TV
Mitsubishi VS-5059
ic stk392 110 replase chak resistors 2.2ohm
Aug 11, 2007 | Mitsubishi VS-5059 50" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
