Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Ultimate Care II spins only once in a while :-)
Our Whirlpool Ultimate Care II washes, pumps the water, but spins only one from about 10 times... Sometimes if I will relevel the busket it will spin. The motor works, but not spinning. And also it overfilled 2 times last summer. And love this washer - want to fix it!!! Please help!!! Thanks
Mod # LSB6300LWO
Ser # CM4214469
  • ignatusik Sep 29, 2008
    squishy2, thanks for your reply! I really want to fix my washer.
    Where can I find how to get to those switches?
    Thanks
    Sergeant:
  • 409 Answers
sounds like the timer switch. the switch is mechanical, so it's quite easily replacable.
also, the overfilling is a result of the pressure switch no engaging. this switch senses the water level and once it's up to capacity, it will shut off the water supply into the tub. check the switch and switch wire to make sure it's working correct. this switch is also mechanical and easy to fix.
let me know if i can be of more help.
thanks
Posted on Sep 29, 2008
Whirlpool Ultimate care II will not spin or drain
The primary promlem is draining. Make sure the drain hose is not kinked or blocked .Water flowing out when the hose is lowered ( the hose needs to be lower than the water level, inside the machine as well) would show if it's blocked. Another cause is a jammed or failed pump. Good luck....Nomess
Apr 19, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool ultimate II washing machine fills up and agitate but does not spin or drains the water out. how can I fix it.
You have a bad motor. Your washer is a direct drive machine. It turns in one direction to agitate and the other direction to both spin and to pump. You have lost one direction in your motor.
Oct 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Where are the fuses to the water pump
Hi there......the water pump does not have a fuse...it is not controled by a fuse....it is controlled by the programmer....the whole machine is protected by a fuse in the plug top...water pumps or drain pumps usually suffer from a damaged impeller...or damaged coil windings...either of would require you to relace the pump
regards Sir Galahad
Aug 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The washer doesn't spin out the water. Clothes come out soaked?
if it washes ,,check your lid switch,,if it doesnt wash and spin check your motor coupling...onthejob
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer leaves water
Water pump must not be running. Check if the belt is not broken or came off or the dial switch is bad or the clutch is not engaging.
Good luck
Dec 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer ultimate care
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate Care II will not spin and makes a loud noise, I did get it to drain the water.
The usual culprit is the motor-transmission coupler. This is located between the motor and the transmission. You need to remove the pump and then the motor to access it.
Oct 17, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Spins but water won't drain out.
clean out pump by opening and removing debris
Oct 10, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
160 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
